Go to Post For guys, is the appropriate term "manpris". ? - Chris Fultz [more]
Unread 24-06-2002, 04:09
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
shafts, gears and wheels....
Posted by nick237 at 05/09/2001 10:43 PM EST
Engineer on team #237, sie h2o bots, from Watertown high school ct and sieman co.
I had a thought last year but to late in the game to try it but I am going to see if I can cure the whole " GRUB SCREW or KEY WAY " issue.
Most people have long pondered the thought of HOW to get things to stay on shafts for a long time now and I would say we are equaly divided between the main two. I intend to try a third way and see if this works better. EDM machines are now becoming practical house hold objects so why not EDM the gears and or sprockets with Square holes, the ends of the shafts can be ground or milled to fit and fixing a square peg in a square hole is easier than round.....
Is this a worth while idea?
nick921
[IMG] code is Off
Drivetrain, what did you use? maclaren Technical Discussion 42 15-02-2004 21:09
"Automatic Transmission" Madison Technical Discussion 70 24-11-2003 09:03
how does crab drive work? Soukup Technical Discussion 13 25-04-2003 11:31
To shift or not to shift? sanddrag Technical Discussion 61 15-04-2003 22:56
Best source for gears? Smallparts? drivetrain advice wanted! Frank(Aflak) Technical Discussion 11 10-01-2003 17:22
