Go to Post Hearing about the beginnings of 842 was truly inspirational and has really stuck with me through the years. After following you guys for so long it was crazy for me to play with you. Thank you for all that you have done for FIRST in Arizona. - Saberbot [more]
Unread 17-05-2009, 15:33
ShaunT ShaunT is offline
FRC #0217 (ThunderChickens)
Team Role: Driver
ShaunT has much to be proud ofShaunT has much to be proud ofShaunT has much to be proud ofShaunT has much to be proud ofShaunT has much to be proud ofShaunT has much to be proud ofShaunT has much to be proud ofShaunT has much to be proud ofShaunT has much to be proud of
Send a message via AIM to ShaunT
Re: Did Lunacy really level the playing field?
Originally Posted by Jon Jack View Post
3) Lack of pinning rule or vehicle for pinned robots to get out of a pin
I don't know how it worked for robots like your narrow body, but with a wide body you can get out. It might take more time than you have to be stuck in one spot, but you can eventually spin out using the carpet on the edge. And if you had crab, you really were not pinnable as you could always just drive away using the carpet. (Of course, this all assumes one robot is trying to pin you. If it's a two on one, game over.)
Lunacy playing field. Captain banana General Forum 2 10-01-2009 18:31
See the playing field in 3D Glasses General Forum 2 20-06-2005 20:57
Metal can touch the playing field surface. Madison Rules/Strategy 3 02-03-2003 00:31
Building the Playing Field AJ Quick General Forum 15 13-01-2003 19:15
Equal Playing Level? archiver 1999 1 23-06-2002 21:51
