Go to Post And, learn to collaborate, 'cause it works. - DonRotolo [more]
Go Back   Chief Delphi > FIRST > Rumor Mill
Thread Tools Rating: Thread Rating: 7 votes, 5.00 average. Display Modes
  #256   Spotlight this post!
Unread 13-05-2009, 12:58
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
Re: Next Year's Game?
Originally Posted by JaneYoung View Post
This is going to go over like a lead balloon.
I was thinkint the same thing. If you want 1/3 more robots on the field, you could reduce the robot sizes by 1/3.
OCCRA in MI runs at about 2/3 the FRC dimensions. Much smaller than that and I think the bots loose too much presence. OCCRA fans are allowed to be pretty close to the Action. Going much smaller would seem too close to VEX, FTC, or BEST.
  #257   Spotlight this post!
Unread 13-05-2009, 13:10
Onward through the fog.
Yup. I was thinking about 1/3 smaller, no more. Not VEX, FTC, or BEST size.
But a little smaller if the competition were to go 4 vs 4, would be interesting and less confusing, visually. It would also add new challenges. I do like the idea of mixing up the sizes a bit but for a multi-purpose/layered event but I really do like the GDC folks and wouldn't want to give them any more headaches than they already have.
That said, I'm thinking kind of like tag-teaming and FLL put together. This robot has to perform this task, then go back and tag its alliance partner to perform the next task. Points would be awarded for completing tasks and could be awarded for time taken to complete as well. During build, the robot could be designed to be able to complete all the tasks or specific ones.
~ Helen Keller
(1880-1968)
  #258   Spotlight this post!
Unread 13-05-2009, 13:25
Ryan Caldwell's Avatar
Ryan Caldwell Ryan Caldwell is offline
217 Alum, 2851 Founder, 469 Mentor
FRC #0469
Ryan Caldwell has a brilliant futureRyan Caldwell has a brilliant futureRyan Caldwell has a brilliant futureRyan Caldwell has a brilliant futureRyan Caldwell has a brilliant futureRyan Caldwell has a brilliant futureRyan Caldwell has a brilliant futureRyan Caldwell has a brilliant futureRyan Caldwell has a brilliant futureRyan Caldwell has a brilliant futureRyan Caldwell has a brilliant future
Send a message via AIM to Ryan Caldwell
There could be bonuses for thinking inside the limits and outside the refrigerator box.
Would be a pain in the butt administratively but weight classes would be cool, alliance consists of 2 full size and 2 smaller bots
or
Is it within 2/3 of max dimensions? yes = Bonus
Is it under 90lbs? yes = Bonus
or
the field could be designed to make being smaller an advantage at some point (2003 had the limbo bars on the sides of the ramps)
Might make it interesting not having 6, 120lb refrigerator boxes out there.
Insane and Insight are just about the same thing if you squint and turn your head ever so slightly
  #259   Spotlight this post!
Unread 13-05-2009, 13:36
Not at all. If you made both the robots and fields smaller, it would probably reduce cost per student AND the cost of putting on regional events.
  #260   Spotlight this post!
Unread 14-05-2009, 09:13
IKE's Avatar
IKE IKE is offline
AKA: Isaac Rife
no team (N/A)
Total Chaos.
OCCRA last year played a football related game that was rather interesting. One of the most interesting aspects was the footballs did things that no teams were expecting that created interesting mobility issues.
3 vs. 3 or
4 vs 4.
In my game, the field would be divided into 2 halves with only a line down the middle and a 6 foot circle in the center. Each side would start out with 20 footballs on the floor. For every ball scored, 2 balls will be thrown into the opposing alliances 1/2 by a random launcher. Bots are not allowed to go Off-sides during the first minute. The second minute is wide open. Bonus for any bot completely inside the circle at the end of the match.
Also, I would go back to a 2 bot classification system. Tall bots (standard size), but 100 lb limite, and squat bot (under 3 foot), but they can be 120 lbs.
  #261   Spotlight this post!
Unread 14-05-2009, 09:39
Joining the 900 Meme Team
FRC #0079
Total Chaos.
3 vs. 3 or
4 vs 4.
So sort of like a SUMO competition? How would the balls be scored? What about adding heavy objects that the robots can use to gain traction in the end game? I like it.
  #262   Spotlight this post!
Unread 14-05-2009, 10:04
IKE's Avatar
IKE IKE is offline
AKA: Isaac Rife
no team (N/A)
Scoring, I was thinking like Aim High but use a field goal instead of a hoop. Possibly have two lower goals like aim high also.
It is totally derivative of the OCCRA game last year, but the football was a really neat and challenging game piece.
yeah the end bonus would be if you crossed Sumo with a Rugby Huddle (I forget teh name). 2 to 8 bots trying to occupy the same 6' circle for the bonus. With it being 6', this would make it too difficult for a team to take in the first minute without taking a line fault penalty.
I love the idea of bonus weight playing pieces! Maybe have several 16LB of bowling balls out there that teams could use. Really available, toungh, and difficult to handle. Or you could have a bowling ball ( hard and round so it will be dynamic)(16 lb), a box of rocks (partially filled for a shifting CG piece) (20 lb), and a kevlar bag of sand (heavy and amorphous) (40 lb).
You could be light and agile during the first minute, and then put one your robot Sumo suit (bag box and ball would add 76 pounds!).
What if the center circle was a different material than the carpet?????
  #263   Spotlight this post!
Unread 14-05-2009, 11:36
FRC #0079
Im really liking this idea. Maybe you should suggest it for OCCRA next year. I would love to see this game played out.
  #264   Spotlight this post!
Unread 14-05-2009, 14:09
IKE's Avatar
IKE IKE is offline
AKA: Isaac Rife
no team (N/A)
I will talk to the organizers. I really liked their game last year. It was a lot of fun to watch. They couldn't do footballs 2 years in a row, but I am sure we can find an equally interesting game piece.
I am still holding out for a game with CONES!!!!
Picture a stadium full of cone-heads.....
  #265   Spotlight this post!
Unread 14-05-2009, 15:36
jpmittins
Posts: n/a
I really like the idea of heavy, unwieldy game pieces. It would be great if they didn't have to be handled to make points, then that would allow more bot designs, if there was another aspect to the game. Only problem is that 40 lb. Kevlar bags of sand and 20 lb. bags of shifting rocks would be incredibly difficult for teams to get for personal practice.
Heh, that would be funny. It would be like this year, all of the people with the hats made of white and pink trailer pole jawns.
  #266   Spotlight this post!
Unread 15-05-2009, 22:37
Robert Cawthon's Avatar
Robert Cawthon Robert Cawthon is offline
Robert Cawthon is a splendid one to beholdRobert Cawthon is a splendid one to beholdRobert Cawthon is a splendid one to beholdRobert Cawthon is a splendid one to beholdRobert Cawthon is a splendid one to beholdRobert Cawthon is a splendid one to beholdRobert Cawthon is a splendid one to behold
Footballs? Maybe Nerf Footballs? LOVE IT!! Easy to obtain and hard to predict! GDC, pay attention!
Formerly a mentor with Team Stealth, 1802. Thanks, kids. It was fun!
2008 Greater Kansas City Regional Winner (Thanks 476 and 1806)
2010 Greater Kansas City Regional Gracious Professionalism Award
2012 Greater Kansas City Regional Imagery Award
"It doesn't hurt to be smart as long as you don't out-think yourself." -- Steve Fujita Former KC Chiefs player.
  #267   Spotlight this post!
Unread 16-05-2009, 21:55
afowl's Avatar
afowl afowl is offline
Forever a Mercurite
AKA: Amanda Fowler
FRC #3929 (Atomic Dragons)/FRC #1089 (Mercury)
afowl is a jewel in the roughafowl is a jewel in the roughafowl is a jewel in the roughafowl is a jewel in the rough
Maybe you could have a game with like a bunch of really tall posts of varying heights throught the field or in the center and have to shoot rings on to them?
Or like having to shoot frisbees into bins high off the ground? Like frisbee-golf or ultimate frisbee or whatever its called...
And I love the idea of ridiculiously large or small objects... or how about both? All pieces are the same shape but there are a ton of small ones, a bunch of normally sized ones and a few monster sized pieces?
2007-2011: [ Team Mercury 1089 ]
2012-????: [ Atomic Dragons 3929 ]
FF: The Machine
@frc1089
  #268   Spotlight this post!
Unread 17-05-2009, 22:14
jpmittins
Posts: n/a
This would be epic. I would love to see a field covered in little tiny pieces, being massively scored, while a few boulder sized pieces get rolled around by the more able robots. Would make for interesting spectating.
  #269   Spotlight this post!
Unread 17-05-2009, 22:21
Ruswolf Ruswolf is offline
FRC #2866
Ruswolf is an unknown quantity at this point
I want too see more speed and robot contact something that involves pinning and so on...
Less human interaction
and yes traction
  #270   Spotlight this post!
Unread 17-05-2009, 22:26
Alex_Miller's Avatar
Alex_Miller Alex_Miller is offline
2175 College Mentor
AKA: Alex Miller
Alex_Miller is an unknown quantity at this point
Send a message via AIM to Alex_Miller Send a message via MSN to Alex_Miller
[quote=Mark Rozitis;856768]
Originally Posted by StevnIndustries View Post
Echoing a whole bunch of other people:
1. Not getting penalized for being good! (Is your boss going to punish you for blowing away the competition and making the company a lot of money?)
Only in communist nations
Next year's game? petek Rumor Mill 111 26-04-2008 02:59
Next year's game hint..... ggoldman General Forum 1 21-02-2008 11:00
pic: Next Year's Game Element? Greg Marra Extra Discussion 9 03-02-2007 20:47
Next Year's game idea.... Gusman1188 General Forum 92 25-04-2004 22:57
Infared in Next Year's Game Paradox1350 Rumor Mill 45 02-04-2004 20:45
