Go to Post Which puts us precisely where we were six months ago, but slightly more entertained. - cadandcookies [more]
Unread 18-05-2009, 15:45
Re: Failed attempt to explain JAG linearity
Chris,
Again I ask you to consider that the diodes only conduct IF the EMF exceeds the battery voltage which is rare or when the inductive kick attempts to raise the voltage. I multiplied the jag by 10 only to allow the two graphs to appear on the same scale. The average current for both controllers will be far less except at 100% duty cycle when average and peak are approx. equal. If the diodes do not conduct there is no EMF induced current. The graph simply shows the calculated current through the motor due to the effects of the pulse width (calculated at and for the length of the pulse due to the duty cycle). You cannot see the voltage developed across the inductor but a current probe or other method of looking at current would demonstrate this phenomena.
2009 Camera and Jag inventor models problem Creator Mat CAD 5 08-03-2009 14:05
1 Jag and 1 Victor not responding correctly. elbuo NI LabVIEW 4 17-02-2009 22:57
Joystick Linearity NinJA999 Control System 4 28-01-2007 18:49
pic: Yet another attempt at Photoshop Cody Carey Extra Discussion 1 08-04-2006 23:13
pic: Failed attempt at simulation CD47-Bot Extra Discussion 5 17-06-2004 11:03
