Go to Post FIRST: there is no second. - BandChick [more]
Unread 17-05-2009, 23:54
The Lucas's Avatar
CaMOElot, it is a silly place
Re: **FIRST EMAIL**/Java and Orbit Balls
Originally Posted by Alan Anderson View Post
I don't understand the point (!) of your example. What part of it should I focus on? None of it appears to show me a reason for preferring to use explicit pointers.
I generated assembly for both of the examples with the relevant instructions bolded
Originally Posted by Chris27 View Post
 1 #include <stdlib.h>
 3 int main()
 4 {
 5   int *array = malloc(10 * sizeof(int));
 6   int *ptr;
 7   int i;
 8
 9   for(i = 0; i < 10; i++)
10     ptr = array + i;
11
12   return 0;
13 }
.L2:
        cmpl    $9, -12(%ebp)
        jg      .L3
        movl    -12(%ebp), %eax
        sall    $2, %eax
        addl    -4(%ebp), %eax
        movl    %eax, -8(%ebp)
        leal    -12(%ebp), %eax
        incl    (%eax)
        jmp     .L2
.L3:
Originally Posted by The Lucas View Post
 3 int main()
 4 {
 6   int *ptr = array;
 7   int i;
 8
10     ptr++;
11
12   return 0;
13 }
.L2:
        cmpl    $9, -12(%ebp)
        jg      .L3
        leal    -8(%ebp), %eax
        addl    $4, (%eax)
        incl    (%eax)
        jmp     .L2
.L3:
So 4 instructions are necessary for ptr = array + i; and only 2 instructions for ptr++; in this assembly language.
Isn't pass by reference exactly what Java lets you do in such cases? I guess I'm completely failing to understand what you're trying to explain here.
I Googled "java swap" and this site explains it pretty well. Basically when you pass by reference to a function in Java it gives the function a new (different) reference to the object and there is no way to change the original reference in the passing function. In C++, the pointer is like an absolute reference (memory location) that is the same everywhere and you can even use pointers to pointers (no references to references in Java).
Robot Inspector
Unread 18-05-2009, 00:39
Chris27's Avatar
Chris27 Chris27 is offline
AKA: Chris Freeman
FRC #1625 (Winnovation)
Chris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant future
Originally Posted by The Lucas;860118
So 4 instructions are necessary for [B
ptr = array + i;[/b] and only 2 instructions for ptr++; in this assembly language.
So what's your point? Of course an expression that contains multiple variables will generally be more complex then an expression that contains a single variable. ptr = (&(ptr[0])) + 1 will again compile to the same assembly. Array indexing is just an encapsulation for pointer arithmetic as I explained earlier. Any pointer arithmetic expression will have a matching array index expression and both of these expressions will compile to the exact same instructions.
If you want to change a reference to an object, just have the method return a new reference. If you want a series of references, just encapsulate the references in objects. If you absolutely need to have access to the virtual address of an object, then Java just isn't the right language for the job.
Here is swap with references:
public class MyInt {
	int data;
	public MyInt(int x)
		this.data = x;
	public static void swap(MyInt a, MyInt b)
		a.data ^= b.data;
		b.data ^= a.data;
		a.data ^= b.data;
Unread 18-05-2009, 03:05
The Lucas's Avatar
You can't dereference (&) and do pointer arithmetic like that in Java.
There is no matching array index expression for this:
ptr = 365;
Array indexing requires a symbol (base of array) and a type (size of element). When an integer can be cast to a pointer, pointer arithmetic can be done without an array.
	int data;
	public MyInt(int x)
		this.data = x;
		a.data ^= b.data;
		b.data ^= a.data;
		a.data ^= b.data;
I know you can create a new class, a similar example was on the page I linked. I just said it was simpler in C. Creating new classes or returning multiple references doesn't sound simple to me.
Again, I understand both languages and the reasons why Java doesn't allow explicit pointers (source of bugs, reference counting for garbage collecting, sercurity, etc..).
Lets revisit how this whole conversion happened (with me paraphrasing)
Billy: Yuck Java. Pointers ftw
Jared: What cant you do with Java references?
Me: Pointer Arithmetic.
Jared: Granted, but you better have a good reason.
<Long posts involving example code by Chris, me and Alan>
I thought twice before pressing Submit Reply on my first post because I knew it wouldn't be my last on this thread Programming debates are interesting (for me atleast) but time consuming. Maybe I should have just let Billy reply or learned from C++ vs LV threads.
Robot Inspector
Unread 18-05-2009, 09:30
Right. The whole discussion here is based on the lack of pointer arithmetic in Java. But I'm still trying to find out why some think that pointer arithmetic is more efficient than using arrays. My understanding is that they compile to exactly the same thing, since in C a[i] is just syntactical sugar for *(a+i). I used to confuse people by writing i[a] instead, which gives exactly the same result.
ptr = 365;
Without significant context, I'm at a loss to understand why you'd want to write it. With the exception of using memory-mapped I/O, I have yet to see any examples anywhere where using absolute pointers gives any improvement in efficiency over using arrays.
Unread 18-05-2009, 10:24
Bharat Nain's Avatar
More importantly, how much does it matter in our application? What difference will it make?
-= Bharat Nain =-
Whatever you do, you need courage. Whatever course you decide upon, there is always someone to tell you that you are wrong. There are always difficulties arising that tempt you to believe your critics are right. To map out a course of action and follow it to an end requires some of the same courage that a soldier needs. Peace has its victories, but it takes brave men and women to win them. - Ralph Waldo Emerson
Unread 18-05-2009, 10:39
Jared Russell's Avatar
Taking a year (mostly) off
Because if you don't use pointer arithmetic, you can't be a real programmer.
(I know that's not Brian's argument, but it is a good excuse to post one of my all time favorite programming urban legends)
Unread 18-05-2009, 10:52
REVving up for a new season
FRC #2848 (All-sparks)
Re: **FIRST EMAIL**/Java and Orbit Balls *****JAVA DISCUSSION***
I split this conversation into 2 threads into a java discussion and an orbit ball one.
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 18-05-2009, 13:53
The Lucas's Avatar
Sorry for the extra work Greg but it was bound to happen.
It is clear I haven't been a targeting my statements well.
Alan, to show that pointer arithmetic can be more efficient than array indexing, I used ptr++ (cant use in Java) instead of array indexing in Chris' example loop. The generated assembly showed:
Basically when stepping though an array, you can avoid a multiply(or shift left) op that is need to multiply the index variable by the sizeof that type by simply adding the sizeof to a pointer each time. Incrementing a pointer in a loop is the only pointer arithmetic that I regularly use and the ptr can be even be used as the loop control variable eliminating i.
So basically I am saying (since my first post here) is pointer arithmetic (that can be done in C not Java) can be slightly more efficient in some situations. Nothing major that will make a significant difference in our robot code. Can we agree on that?
Exactly all array indexing is pointer arithmetic. However, not all pointer arithmetic is array indexing. More on that next
I accidentally stuck my explanation in the next Chris quote, I fixed it, this is how it should have read
ptr = 365;
As you said, memory map I/O is the only use I can think of for that expression. However, that wasn't even meant to be a practical example. It was just meant provide an simple example of pointer arithmetic that didn't have a matching array index expression to refute Chris' statement:
Great story
Robot Inspector
Unread 18-05-2009, 14:30
Bharat just won this thread.
An instruction cycle here or there makes zero difference in the face of the larger picture. If you want to have a truly useless argument, just remember that our new processor is pipelined AND has a double dispatch with multiple ALU elements.
So while you are all optimizing the instructions, I'll be working on what I want the code to do.
As a point of interest, I know someone who wrote his own graphical programming language that compiles to something that is on average twice as fast as C for embedded power and motion control applications.
Unread 18-05-2009, 16:12
Foster Foster is offline
Engineering Program Management
VRC #8081 (STEMRobotics)
Foster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond repute
Right. We now have CPU cycles and memory space to burn, so a cycle here and a cycle there does not make that much difference.
I get calls on a regular basis to "make it run faster." I always ask "Does it run correctly now?" since there is no reason to optimize a program that does not work.
There are two optimizations here. The custom language is focused to help solve motion control applications. C is a general purpose language, an electronic "hammer" so to speak.
The second is that there is most likely a set of libraries that he uses for the down and dirty interfaces. He optimized them to work with his target platform.
Speed in Java the last few years has come from:
  • Improved VM processing - the actual runtime environment of the system
  • Improved "code generation" by the compiler
  • Improved library functions. By far the biggest speed pickups has been in the optimization of data structures in the system. Sorted lists are about 150% faster due to algorithm improvements (no longer the bumble sort) which then reflects back into the application.
You saw the same things with C and the IFI controller. You could roll your own code to do all the functions, but most of us took Kevin Watson's or the WPI library. Those key functions had been optimized first for "they work" then for "make them fast."
If you optimize the algorithm you seldom have to bit fiddle to make it faster.
Foster - VEX Delaware - 17 teams -- Chief Roboteer STEMRobotics.org
2010 - Mentor of the Year - VEX Clean Sweep World Championship
2006-2016, a decade of doing VEX, time really flies while having fun
Downingtown Area Robotics Web site and VEXMen Team Site come see what we can do for you.
Unread 18-05-2009, 23:46
Uberbots's Avatar
Uberbots Uberbots is offline
Mad Programmer
AKA: Billy Sisson
FRC #1124 (ÜberBots)
Uberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond repute
What is it that you want to do with pointers that Java's pass by reference system can't do exactly?
Before i answer this, wow what a discussion this simple pointer thing turned into.
Anyway, it just bothers me that java turns the idea of pointers from a more numerical approach to an object-oriented approach. I like knowing that the variable i am passing into a function is explicitly a pointer, not something determined by java. Its also bothersome that for primitive datatypes such as int's an entirely different datatype (Integer) is required if you want to pass it by reference into a function (i know there is a system to go around this but god knows how much overhead it incurs, along with the garbage collection of the implicit object).
I'm a C man. i need to know what is happening with my code at all times. It helps (me) with debugging and low-level optimizing a lot.
also: double/triple/quad/etc pointers.
A few of my favorite numbers:
175 176 177 195 230 558 716 1024 1071 1592 1784 1816
RPI 2012
BREAKAWAY
Unread 19-05-2009, 05:38
Wetzel's Avatar
Wetzel Wetzel is offline
DC Robotics
FRC #2914 (Tiger Pride)
Wetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond repute
Send a message via AIM to Wetzel
Our programming mentor is excited, because his AP classes use Java. It never hurts to give the school a really obvious reason why the time commitment is beneficial now.
Wetzel
Viva Olancho!
Unread 19-05-2009, 07:36
GeorgeTheEng's Avatar
GeorgeTheEng GeorgeTheEng is offline
Former Lord of the Vex
AKA: George Marchant
FRC #0087 (Red Devils)
GeorgeTheEng has much to be proud ofGeorgeTheEng has much to be proud ofGeorgeTheEng has much to be proud ofGeorgeTheEng has much to be proud ofGeorgeTheEng has much to be proud ofGeorgeTheEng has much to be proud ofGeorgeTheEng has much to be proud ofGeorgeTheEng has much to be proud ofGeorgeTheEng has much to be proud ofGeorgeTheEng has much to be proud of
Send a message via AIM to GeorgeTheEng
In my experience, when pointers are no longer part of the equation... There is a LOT less debugging that ever needs to be done. And the debugging that does need to be done is usually simplier. When code crashes there is a traceable route to it rather then having a line of code in a random unrelated location in a separate thread give unidentifiable errors in the code running at this moment.
Granted the rules with Java references can get odd at times as well.
Honestly, working on a team where the school has no programming courses at all, I welcome being able to work with the kids using an industry standard language that does not involve having to address pointers and pointer arithmetic. Labview is not bad, but I see it as a niche product. C++ and Java have a much wider user base.
George Marchant - Lockheed Martin Engineer & General Nut Case
FIRST Credentials: Team 87 Mentor | Former Director FIRST Vex Challenge
NJ FIRST Planning Committee Member & NJ FVC Committee Member
Philadelphia Alliance Regional Corporate Advisory Board Member |
FRC and FTC volunteer at too many places to list (NJ, VA, DE, PA, NY, Championship)|
"Hi my name is George and I'm a FIRST-aholic. I've been a FIRST-aholic since 2000..."
Unread 19-05-2009, 10:37
This is a truism. When you use C, particularly when you use pointers, you must have a constant deep understanding of exactly what your code is doing. A whole category of bugs is possible that only the programmer is capable of tracking down and dealing with.
When you don't have the option of using pointers, you can usually trust that the compiler is keeping track of things for you appropriately. Debugging is a lot easier when your tools can show you how things are going wrong.
Unread 19-05-2009, 12:13
Uberbots's Avatar
Mad Programmer
AKA: Billy Sisson
And i do. So whats the problem?
RPI 2012
BREAKAWAY
**FIRST EMAIL**/Java and Orbit Balls *****Orbit Ball Discussion**** Pjohn1959 FIRST E-Mail Blast Archive 44 18-05-2009 20:19
"Java, Sun SPOT and the FIRST Robotics Competition" pogenwurst Programming 54 02-05-2009 23:37
Amazing Circuit Build and Simulation Java Applet Chris_Elston Electrical 2 26-06-2008 19:36
Eclipse Plugin, Linux, and a Java Loader shtylman Programming 5 17-01-2008 14:44
Learn C, C++, and Java with new board game. Elgin Clock Programming 8 04-11-2005 13:28
