Go to Post My favorite is always "The Next One!" - Bill Moore [more]
Unread 19-05-2009, 10:22
Swarf - The Sparkly Killer
I received a PD recently for failure analysis. I've attached a word document that contains 5 pictures of what I saw on first opening the case.
I'd like to take this opportunity to remind teams to protect (or remove!!) their electronics when working on the robot. This one "looks like it was placed under a drill press to catch the shavings", according to one of my co-workers. The conformal coating of the boards greatly reduces the likelihood that they will be damaged by swarf. However, you really shouldn't rely on it - belt and suspenders, as they say.
Surprisingly enough, this PD works just fine after being cleaned. The boards are designed to fail safe, so it likely protected itself. On the other hand, I am glad I wasn't on the team that saw their robot grind to a halt mid-match.
Unread 19-05-2009, 13:58
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
Re: Swarf - The Sparkly Killer
At the end of the season, our team had a WGA that we thought was intermittent. It had dropped out a few times halfway through the GTR, and for the remainder of the season, we used loaners at the events.
A few weeks ago, we opened it up, and the PCB was absolutely covered in filth.
We generally take great care to cover up all our electronics whenever we remove material on the robot - regardless of whether it is near the electronics board or not. We always blow everything out with compressed air afterwards as well.
However, I thought this year the dirt/swarf problem seemed a lot worse. It seemed like the static buildup from running on these wheels/regolith/carpet turned our electronics into dust and dirt magnets.
Has anyone else bothered to crack open their WGAs? Was yours incredibly dirty, despite thinking your electronics housekeeping was pretty good?
After vacuuming, brushing, and blowing it clean, the WGA works great again!
In life, what you give, you keep. What you fail to give, you lose forever...
Unread 19-05-2009, 14:27
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
You could just attach the .jpg images to your post, so we don't have to use Word to see them
Looks like normal dirt to me...I was expecting to see something like the floor of my shop under the drill press!
Unread 19-05-2009, 15:11
Sorry Jim, I got in a fight with my work computer and decided this was the easiest way to compress the images.
If you look in between C8 and C9 in the image you reposted, you can see some rather evil looking swarf.
Unread 19-05-2009, 18:43
I'm not sure where "between C8 and C9" really is; the one tiny dot I can make out there is dwarfed by junk elsewhere on the board. Without any depth to the image, it's not easy for me to tell what's debris and what's just blemishes in the conformal coating. It probably looks a lot worse in person.
Unread 19-05-2009, 19:14
AKA: Mr. Lim
Alan, I think the biggest culprit are the two metal "hairs" that start in the gap between C8 and C9 (but closer, or even touching C9), run down and across the R38a label, and almost underlining the C8 label.
To me, of all the debris on the board, those particular pieces scream loudest in their readiness to release magical smoke.
Unread 19-05-2009, 20:05
Are we looking at the same photo? I don't see anything remarkable between the C8 and C9, and I don't see a R38a anywhere (though R38 is near). However, your description of "underlining the C8 label" does a good job of pointing to what I had originally interpreted as a wrinkle in the conformal coat -- is that truly metal shavings? Yoicks.
Unread 19-05-2009, 20:59
AKA: Mr. Lim
My not-so-old eyes do deceive me...It's R38, and the dirty via beside it looked like an "a"
Of course that would've been the first time ever I've seen a layout labelled with trailing letters, but I digress =).
Unread 19-05-2009, 22:03
NorviewsVeteran's Avatar
NorviewsVeteran NorviewsVeteran is offline
Precision Driver Extraordinaire
AKA: Richard Raitt
FRC #1793 (Pilots)
NorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond repute
We covered our control board with an old team T shirt a couple of times, but we might want to figure something else out- the shavings stick to to fabric.
Name:	Stephen Colbert swarf.jpg
______
I was in Scouts but I wanted out by the third meeting. I was in TSA, but I quit after a couple of weeks. I don't go camping with the SCA anymore. I was in taekwondo but I had to leave because I got sick.
I joined FIRST and stuck with it. It was nice enough to return the favor.
pic: What?! The Killer Bees are team 47? Tim Baird Extra Discussion 1 15-07-2007 00:33
pic: The X-Cats Killer arm design Koko Ed Rumor Mill 36 28-02-2005 17:09
pic: The X-Cats Killer arm design Koko Ed Robot Showcase 9 02-02-2005 21:53
THE ULTIMATE KILLER AdamT Chit-Chat 4 15-04-2002 13:19
just call me the thread killer Dave_222 Chit-Chat 13 09-04-2002 18:43
