Thread Tools |
Rating:
Display Modes |
Re: T-Shirt cannon pnuematic set ups
what's the wall thicknesss? |
About a foot of reinforced concrete.
I think he may have been asking about the pipe.
In fact I was
and I never thought that bats could "pop" like that ![]() |
Our Lunacy robot this year used a catapult to launch moon rocks up to 35ft, so it is ready to go as a t-shirt launcher with no changes! Just need to bundle up the shirts into an approximate ball.
I don't know the wall thickness. It's class 150 Galvanized Steel. |
#7
Our team built one about three years ago for school. With the exception of 2 parts, the entire thing is PVC. The tank has been preasure tested up to 60 PSI with no problems. We only need about 20 psi usually, though. Our first attempt, the tank blew off. That was my fault. I didn't clean the PVC well and didn't use primer. Those are very necessary. Now it works great. If the towels (we use rally towels because they are a lot cheaper than shirts) are rubber-banded before they are loaded into the barrel, the go much farther. Our bleachers are built into a hill at about a 60 degree angle below the horziontal. From the bottom,. we can shoot over the booth with only 30 pounds of air. If you want, I can send you preformance statistics, videos, adn a few pictures on what not to do.
Good luck |
#8
This is a double post, but I think you guys might like to read it over here, as well.
Hey all... I just wan to clear some stuff up about PVC, and there really isn't a better way to do that then to borrow Some words from a physics prof on a forum I frequent. Quote:
I'm not saying this is a good Idea, but people in my local offroading club have been using PVC as air tanks for portable systems for years. They mount these on bottoms of bumpers, roll cages, and other places where they are almost sure to get hit, and HARD. When I went to my first meeting and saw that, I remembered threads like this from when I frequented CD and asked if they'd ever had any blowouts or problems associated with this, and I was surprised to find that there had only been one... And it had happened when the guy forgot to put PVC cement on an end cap. Hows that for working in the real world? As a side note, the reason he says to test the system with liquid is because at pressure, the main difference between water and air is that air will explosively expand when a crack or weak spot is formed, and water won't. This means that if you have a leak and fill it with water, you won't have any sort of explosion, and if it holds up for five minutes at 200 psi, you know you won't have any problems below 100. Then again, It's pretty easy just to weld up a steel tank. |
#9
Guys, its not difficult or that much more expensive to just use steel.
I would have thought by this point of the thread everyone's opinions would have drifted that way, and I'm really surprised that it hasn't. Steel is far stronger, safer, and tolerant than PVC is. Long story short, if you want an air cannon, you want steel. |
| pic: Fully Automatic Tee Shirt Cannon - Pic 2 | artdutra04 | Extra Discussion | 23 | 26-07-2015 13:20 |
| pic: T-Shirt Cannon at Purdue's Homecoming | jtdowney | Extra Discussion | 10 | 08-11-2007 19:48 |
| IRI T-shirt cannon | Kyle Love | Off-Season Events | 6 | 17-07-2007 12:09 |
| pic: 549's t-shirt cannon and ballon inflator w/ horn | griff549 | Extra Discussion | 2 | 06-05-2007 00:36 |
| pic: UPS with UPS | Kevin Kolodziej | Extra Discussion | 10 | 04-05-2005 12:57 |
