Go to Post You're not on your own, use your team members. They are the most valuable source of ideas that you have. - fr05ty27355 [more]
Unread 16-05-2009, 05:20
m3rc1l3ss m3rc1l3ss is offline
FRC #1178 (DURT)
m3rc1l3ss is an unknown quantity at this point
Battery powered DS help
My team is planning on changing our DS and wireless router to enable it them run on battery power instead of just off of the adapters, so I would like to know if anyone knows what the mAh rating and the full charge on the old 7.2volt backup batteries is?
I haven't been able to see what the normal voltage is, and picking out resistors is slightly difficult without this information. Also I would appreciate knowing if I can just ignore the fluctuations in total voltage caused by a full charge and just use a 2.4 volt change in my calculations.
Unread 17-05-2009, 12:49
Re: Battery powered DS help
I don't know what kind of "changing" you plan, and I don't understand your reference to picking out resistors.
The Driver Station will run perfectly on 9 volts, and it has no problem being supplied with 12 volts. The router is designed for 12 volts, and will probably work with 9, though it's not specified to be able to.
Unread 17-05-2009, 20:12
FourPenguins's Avatar
FourPenguins FourPenguins is offline
Back in the Game
AKA: Ed Venator
FRC #2399
FourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud ofFourPenguins has much to be proud of
As I interpret this, you want to use two of the old 7.2V backup battery (14.4V total) to run the DS and router, and you want to make a voltage divider with a resistor.
I have two better ideas for you:
First, you could go to RadioShack, a hobby store, or numerous internet sites and buy a larger NiMH rechargeable battery pack and charger. A ten-cell pack will have a nominal voltage of 12 volts.
Second, you could purchase a voltage regulator chip (such as the LM317T) from a supplier like DigiKey or Mouser, and rig up a 12V regulator circuit. This would be far more reliable, even as the batteries discharge or if their is a current fluctuation in either the router or DS.
MORT 11
-2005 New Jersey Regional Chairman's Award Winner
-2006 Palmetto Regional Winner
-2007 New York Regional Delphi Driving Tomorrow's Technology Award
-2008 New Jersey Regional Finalist, Chesapeake Regional Winner, Championship Event Overall Top Seed
HB 2399
-2009 Buckeye Regional Delphi Driving Tomorrow's Technology Award, Pittsburgh Regional GM Industrial Design Award
Unread 17-05-2009, 23:56
Since both the Driver Station and the Linksys WRT610N router are customarily powered by 12 volts DC, why get fancy? Just use a robot battery wired to a couple of Size M power connectors and be done with it.
Unread 18-05-2009, 08:45
viking's Avatar
viking viking is offline
Viking Robotics
AKA: Robert Dudek
FRC #1777 (Viking Robotics)
viking will become famous soon enoughviking will become famous soon enough
Thats exactly what our team members did, they used a previous years battery and hooked it up with quick disconnects.
Our team was at the public library recently for a Science Night, where we ran the robot for over 2 hours constantly. We had to change out the robot battery every fifteen minutes, but the Driver Station battery lasted all evening long.
Viking Robotics Team #1777
2006 FRC Colorado Regional Rookie Inspiration
2007 FRC Greater KC Regional Daimler Chrysler Spirit
2007 FVC St Louis Connect Award
2009 FRC Greater KC Best Website Award
Unread 18-05-2009, 08:55
I agree with Alan on this one. However, you could use a PD to boost your 7.2V up to 12V.
In general, using resistors for power regulation is a BadIdea(TM). Since they don't have any feedback mechanism, they vary wildly with input and output conditions. If you use a series R, you need to know your load current well - unfortunately, most logic devices only draw power when they need it, so you will swing around quite a bit. If you use a resistor divider, you can partially alleviate the low idle current problem by replacing it with a high idle current problem.
Use a linear regulator or a switcher, (almost) always.
Unread 19-05-2009, 18:51
lcoreyl's Avatar
lcoreyl lcoreyl is offline
WittyTitleGen can't link to library
AKA: Milner
lcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud of
Angry Re: Battery powered DS help
Hmmmm... just lost SECOND router using battery power. I think we are going to start using fuses; I would recommend the same to you...
Anyone else lost a router?
Unread 19-05-2009, 19:29
jspatz1's Avatar
jspatz1 jspatz1 is offline
AKA: Jeff
FRC #1986 (Team Titanium)
jspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond repute
Send a message via AIM to jspatz1
Our pneumatics this year needed to be charged as close as possible to the match time, so we operated our DS remotely with a robot battery all the time. Just paralleled the DS power cable into a battery quick connect cable. I believe we operated the router this way several times also and never had a problem.
Unread 20-05-2009, 11:03
I'm curious to know what failure you believe a fuse would prevent.
Unread 20-05-2009, 11:15
lcoreyl's Avatar
AKA: Milner
excess current
Unread 20-05-2009, 18:02
excess current
Excess current is not a failure. It is the result of a failure.
It is also the cause of additional failures, most notably burned wires, and it is those secondary failures which a fuse protects against. But the original fault which led to too much current in the first place won't be affected one way or the other by the presence of a fuse.
Unread 21-05-2009, 09:45
lcoreyl's Avatar
AKA: Milner
Both routers had the symptom of plug it in and nothing happens and I've ruled out polarity as the problem both times and >12V the second time. at this point linksys has accepted router 1 under warranty, so I have no plans of opening router 2 to inspect. The only other thing I can think of is a difference in impedance from power supplies. Worst case a few ohms difference, in which case the router is designed to handle that change in current, but that's my only theory at this point. That is what leads me to fuses. This will also protect against someone using the rig with battery power >12 V in the future. true, I won't be able know for sure what the actual failure is, but at least I won't have to worry about $160 secondary failures.
So, unless anyone can tell me what we're doing wrong, I'm going to be using fuses, and I stand by my suggestion that others do the same.
Unread 21-05-2009, 15:04
FRC #1178 (DURT)
I am looking for mobility, so I was looking more towards using 2 of the 7.2 backup batteries from past years, but I cant find the amp hour rating them. Does anyone have any idea what it might be?
After looking around I think I will do a LM317T circuit on the batteries, but I would hate to buy all of the stuff and then find that it lasts for 10 minutes or something.
Unread 26-05-2009, 23:32
J-Mech's Avatar
J-Mech J-Mech is offline
FRC #1361
J-Mech is an unknown quantity at this point
Well the fuse would protect against a device failure. So it would make a difference by protecting the router.
http://en.wikipedia.org/wiki/Fuse_(electrical)
Unread 27-05-2009, 03:03
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
To draw enough current to blow a fuse there would already have to be some sort of failure in the router. While a fuse may prevent further failures from occurring, the router does not have any components that are user serviceable for most teams so the extent of the failure is not really relevant. Fuses are meant to prevent further failures and fires, they do not prevent the initial failure.
Also, odds are that there are one or more fuses already contained in the router to prevent a fire in the case of a failure resulting in over-current.
EDIT: The link you posted actually does a pretty good job of describing what a fuse does and doesn't do.
(help)battery chargers Yoel2630 Electrical 19 16-10-2008 08:59
Battery Help ZachKahn Electrical 5 06-03-2008 18:55
backup battery charger circuit help babylyn90 Electrical 4 06-02-2008 18:11
Need help with build a custom circuit for the backup battery midway78224 Electrical 7 09-01-2008 20:17
Help!!! Battery question trollin1st General Forum 7 12-02-2003 08:48
