Go to Post In real life, you paint the number on your OWN forehead. How you dress, how you look, what expression you have on your face, your body language, etc. You may not see the number but it is there. - Joe Johnson [more]
Unread 20-05-2009, 18:48
bobwrit's Avatar
bobwrit bobwrit is offline
//No Comment
AKA: ...
FRC #1977 (Loveland High Robotics)
bobwrit is just really nicebobwrit is just really nicebobwrit is just really nicebobwrit is just really nicebobwrit is just really nice
pic: Modified vex(Read: Drive Train)
BTW, it's 4 wheel direct drive with the largest gear I can find in the vex set's or the advanced gear kits attached(series) to the smallest gear I could find attached(pararell) to the largest wheels I could find.
Unread 20-05-2009, 19:37
Re: pic: Modified vex(Read: Drive Train)
Have you tried driving this robot yet? With this gearing you might find out that it won't turn very well, and won't achieve anything like its theoretical maximum speed. You'll get a lot better performance by replacing that 12-tooth gear with a 36.
Unread 20-05-2009, 19:45
bobwrit's Avatar
//No Comment
AKA: ...
I have tried to drive, but I haven't changed the code that was origonaly in the controler so it's only 2WD and I haven't changed that yet. It still drives... kind of.
FRC Team 1977 Alumni
Has Attended:2008 Colorado regional
2009 Colorado Kickoff
2009 Colorado Regional
2010 Colorado Kickoff
2010 Colorado Regional
The most exciting phrase to hear in science, the one that heralds new discoveries, is not "Eureka!"(I found it!), but rather, "Hmm.... That's funny" ---Isaac Asimov
Chance favors the prepared mind ---Louis Pasteur
And you can tell me, that I can't make a diffrence because I'm just one, but one is all it takes to start it. And you can tell me, that I can't change the world because I'm too young, but I wont stand here and be your target. ---FM Static
Unread 22-05-2009, 05:00
Mr. Freeman Mr. Freeman is offline
Put better title here.
AKA: Kellan
no team (CSM Robotics)
Mr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to behold
Doesn't the fact that you're using gears make this not a direct-drive system?
"Time is an illusion, lunchtime doubly so."
-Douglas Adams
“Why is it that I can walk into Wal-Mart and buy boxes of bullets and black powder, but I can’t buy potassium perchlorate to do science because it can also be used to make explosives?”
-Theodore Gray
Unread 22-05-2009, 08:29
Joining the 900 Meme Team
FRC #0079
Im going to second the notion of swapping your gears or going with a smaller ratio, right now it is at 3:1 which means every 1 rotation of the motor output shaft you get 3 rotations of the wheel. When you first see this you think, "Sweet I want to go fast that sounds great" the catch is you will not be able to accelerate quickly. This stems from the fact that when you increase speed you decrease torque. Force = torque /(radius*sin(theta)) Using that and F=MA we can calculate your max acceleration to be A = motor_torque/(wheel_radius*robot_mass*sin(theta)) For the sake of simplifying we can assume that sin(theta) = 1. Using that our equation goes to A = motor_torque/(wheel_radius*robot_mass)
Here is the my issue with the way you have this system geared, you may have a top speed of 3*motor_speed but you will more than likely never see that unless you run down a long hallway. Recall v = v_0+a*t, assuming v_0 is 0 (starting from stand still) you could calculate how long it would take you to reach any speed.
As for the turning issue, I'll let someone else show you how to work out the math for that.
Last edited by Andrew Schreiber : 22-05-2009 at 08:31. Reason: I wrote this far too early in the morning
Unread 22-05-2009, 19:39
bobwrit's Avatar
//No Comment
AKA: ...
Yeah, I've ran through the math on this before, so I recognize the problems with it. My own way of getting around the acceleration problem is just pick it up, because it's a demo robot anyway(hold it while demoing it, it still works.).
And yes, it is still direct drive, only modified a little bit.
Unread 28-05-2009, 11:10
RoboTIP RoboTIP is offline
AKA: Jackie Moore
FRC #1739 (Chicago Knights)
RoboTIP will become famous soon enoughRoboTIP will become famous soon enough
Keep the math coming! Even if bobwrit has already "done the math," I think it is an excellent idea to highlight the math for others. So, how about it? Who wants to "do [share] the math" for turning?
Unread 28-05-2009, 11:20
FRC #0079
I would work it out for you but honestly I am only ~50% sure how to do it. I will try to figure it out when I get home later tonight if no one else has posted it.
Unread 28-05-2009, 11:44
Collin Fultz's Avatar
Collin Fultz Collin Fultz is offline
no team (IndianaFIRST)
Collin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond repute
http://www.chiefdelphi.com/media/papers/1443
This is a white paper by Chris Hibner that cannot be pimped enough. It will walk you through why it won't turn based on wheel selection/position and motor/gearing selection.
Teach a man to fish...
Collin Fultz
Unread 28-05-2009, 11:56
FRC #0079
Thanks, Im glad to see my thoughts on how to do this were pretty much right on. Chris does a much better job explaining than I can though.
Also, fishing? I'll pass, not a fan of fish, I'll keep my vegetables thank you very much!
Unread 28-05-2009, 12:08
Ok, fine.
Teach a man to plant...
Collin Fultz
Drive Train Components: the inner working parts of a drive train naruto137 Technical Discussion 3 10-12-2008 21:14
pic: FRC488 - 80/20 Drive Train Madison Extra Discussion 30 07-11-2008 12:59
pic: Jester Drive:Mecanum Wheel Drive Train Ken Delaney 357 Technical Discussion 64 29-03-2006 22:16
pic: 1493 Drive Train 1 Dan-o Robot Showcase 15 17-02-2005 14:59
pic: 350 drive train CD47-Bot Robot Showcase 4 16-02-2004 00:05
