Go to Post It goes back to what Dave said last year--you can be legal and graciously professional, but still dumb. Play smart. - Billfred [more]
Unread 30-01-2009, 18:56
travis travis is offline
FRC #2091
travis is a glorious beacon of lighttravis is a glorious beacon of lighttravis is a glorious beacon of lighttravis is a glorious beacon of lighttravis is a glorious beacon of light
Re: P60 planetaries gearboxes
I pressed on the pinions with two 0.005" shims to keep the back from bottoming on the motor boss. Three out of four pinions were still ~0.6" proud of the front of the motor case. I filed all the faces to just under 0.57" and now all of the motors (including a RS-454/256:1 combo) draw <5 amps, no load. With the stock RS-454 shaft and the FP motor shaft cut to the same length, the end of the motor shaft was still recessed below the pinion face with that ammount of filing. If you don't have acess to shim stock, a piece of paper is about 0.003" thick.
Thanks to Banebots for speaking with me at length on the phone the other day, offering several suggestions to combat my issue.
Travis
Unread 31-01-2009, 13:15
nnfuller's Avatar
nnfuller nnfuller is offline
AKA: Alumni
FRC #2733 (Pigmice)
nnfuller is on a distinguished road
The FP motors come with a gear attached to their shaft do you have to swap out the gear on the end of the shaft to get it to work?
Unread 31-01-2009, 21:35
Ice Berg's Avatar
Ice Berg Ice Berg is offline
Seth Berg
AKA: Seth Berg
FRC #0694 (Stuy Pulse)
Ice Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to behold
Send a message via AIM to Ice Berg
Yes, you have to swap out the pinion gear with the 3.2 mm shaft pinions from banebots. You also have to shorten the shafts on the fisher prices.
Mens et Manus
Unread 04-02-2009, 18:10
FJJ III FJJ III is offline
FJJ III is an unknown quantity at this point
Any updates on the 3" shaft availability?
Also, we have some of the 5mm pinions for the 42mm gearboxes still. Will these work for the new P60 gearboxes?
Unread 09-02-2009, 05:31
banebots banebots is offline
banebots has a brilliant futurebanebots has a brilliant futurebanebots has a brilliant futurebanebots has a brilliant futurebanebots has a brilliant futurebanebots has a brilliant futurebanebots has a brilliant futurebanebots has a brilliant futurebanebots has a brilliant futurebanebots has a brilliant futurebanebots has a brilliant future
The 3” shafts are now available as well as 4.5” blank shafts for making your own.
All the old 42mm pinions will work with the new P60 gearboxes.
BaneBots
Unread 09-02-2009, 15:08
Great! Thanks!
Unread 26-03-2009, 16:49
Any news on when replacement parts will be available for these gearboxes?
Also, any chance that the back mounting plate can be revised to have four motor mounting holes instead of just the two? This was easy to fix on the 42mm gearboxes, but the material is cut away on the P60's, making it trickier
Unread 22-05-2009, 18:49
David Guzman's Avatar
David Guzman David Guzman is offline
AKA: Dave
FRC #1251 (The Techtigers)
David Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant future
Now that "most" competitions are over and everyone had plenty of run time on their P60 gearboxes. I want to hear some comments about their performance at different loads.
How did you use your planetaries? What motor?
How did it perform? Any issues? (even if minor)
Any input you can give from you personal experience will be appreciated. I am looking into using some of these for a personal project and would like to hear from the CD community first.
Thanks.
Dave
Team 1251 The Techtigers
2010 FL Regional Winner (BIG thanks to 86 and 1612)
2009 FL Regional Finalist (BIG thanks to 79 and 744)
2008 FL Regional Winner, FL GM Industrial Design, SC GM Industrial Design
2007 FL Regional Winner, FL GM Industrial Design, Palmetto Regional Finalist, Palmetto Motorola Quality.
2006 Palmetto Regional Winner, Daimler Chrysler Team Spirit Award
2005 FL Regional Judges Award, FL Regional 3rd seeded and finalist, Palmetto Regional Xerox Creativity Award, Palmetto Regional 1st seeded and finalist
2004 UCF Regional Rookie All-star Award
Unread 22-05-2009, 19:08
Billfred's Avatar
Billfred Billfred is offline
1618 used ours on our dumper and intake rollers, 64:1s (I think) straight to an AndyMark key hub screwed to a PVC end cap screwed to our roller. We used the 545 motor, and had no problems with the gearboxes through the course of Palmetto.
Unread 23-05-2009, 10:13
Adam Freeman's Avatar
Adam Freeman Adam Freeman is offline
Forever HOT!
FRC #0148 (Robowranglers)
Adam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond repute
67 used a P60 (64:1) with RS-545 on the conveyor that feed from the hopper to the shooter. We used this combination to replace a face mounted modified globe motor, to increase available torque.
We experienced no issues with the P60 gearboxes we used through 5 complete competitions. In my opinion the these gearboxes were great in the application we put them in....compact, light weight, easy to assemble, and easy to mount.
We had to replace (4) RS-545 motors during the season, and with a spare P60/RS-545 combo ready to go we could swap them out in about 2 minutes.
Unread 24-05-2009, 00:57
Donut Donut is offline
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
Our team used these at a 64:1 ratio with the RS-545 motors, with one on each side of our robot as drive motors. We opted to move our CIMs to our intake and shooting mechanism and remove some of them for weight, and these guys easily handled driving the robot. There were no failures and we did not replace them once even though we used them from week 4 of build season through the end of the Arizona Regional. Two small muffin fans were used on each motor to help make sure they ran cooler but this was mainly a precaution since these small motors (which we had never used before) were being driven for 2 minutes straight more or less.
The only complaint we had was that our robot ended up driving a little on the slow side, but this was due to problems in obtaining correct sprocket sizes, nothing to do with the P60s or RS-545s. Mounting was pretty straightforward and with the longer shaft sizes now available these gearboxes are even more convenient than before. Overall these were a solid choice and I'd recommend using them again.
1557's gearboxes gorrilla Technical Discussion 11 04-05-2008 17:31
Finding Gearboxes Armando Gonzalez General Forum 5 12-01-2008 22:28
Gearboxes Evert Technical Discussion 19 10-01-2008 18:47
Gearboxes Calvin_1631 Motors 2 20-02-2007 19:40
AndyMark planetaries in all their glory! Travis Covington Technical Discussion 2 15-02-2006 22:40
