Go to Post The students who benefit from FIRST are the real "trophies". - David Brinza [more]
Unread 23-05-2009, 20:06
kajeevan kajeevan is offline
FRC #0188 (blizzard)
kajeevan has much to be proud ofkajeevan has much to be proud ofkajeevan has much to be proud ofkajeevan has much to be proud ofkajeevan has much to be proud ofkajeevan has much to be proud ofkajeevan has much to be proud ofkajeevan has much to be proud ofkajeevan has much to be proud of
Any ideas?
I'm working on a project were i need to mount a DeWALT 2-speed drill. The application of this drill is for a drive train direct driving a wheel so secure mounting is needed. I took off the case to take a look inside and the case seems to be needed to hold the gearbox together but i will cut the handle off. I have a couple of solutions but I am wondering if anyone else has a better one before I start cause funding is very much limited so I wanted the best and simplest method possible. So anyone with any idea of mounting this it would be much appreciated.
This is the link to the Drill:
http://www.canadiantire.ca/AST/brows...4V%2BDrill.jsp
Unread 23-05-2009, 20:36
kramarczyk's Avatar
kramarczyk kramarczyk is offline
is getting his kicks.
AKA: Mark Kramarczyk
FRC #3096 (Highlanders)
kramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond repute
Re: Any ideas?
If you have not read the Nothing But Dewalts white paper, I highly recommend that you do so. While the model you are looking at is slightly different, it should give you a good leg up to start with (including holding the gearbox).
Mark
Brick walls are for other people. - Randy Pausch
Unread 26-05-2009, 15:11
Dick Linn's Avatar
no team (Synergy)
Re: Any ideas?
Team 975's first year robot used the Bosch drill motor/tranny with the case. I think that was the last time the drill case was included. We sawed off the handle, then carefully aligned the case and used heavy-duty expanding polyurethane construction adhesive to bed it to a base plate. The plate had waxed paper on it so it wouldn't stick. That provided us with a flat on one half the case. It was then held down with two large hose clamps.
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Unread 27-05-2009, 08:08
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
Re: Any ideas?
Read the nothing but Dewalts paper to understand what parts you need/should leave intact. At the end of the paper it shows a welded aluminum clamp to hold the nose. For OCCRA, a lot of teams use an U-bolt exhaust clamp. You can then block in or strap down the handle to act as a torque reaction/anti-rotation feature. This is quick and easy, but not terribly attractive.
http://www.mufflermall.com/index.php...roducts_id=734
These style of clamps can be purchased at any auto shop for a few dollars.
Unread 29-05-2009, 17:31
Dick Linn's Avatar
no team (Synergy)
Re: Any ideas?
"Gluing" down the casings wasn't exactly elegant, but it did not distort them or damage them, as could happen with an ill-fitted muffler clamp with too much torque. I prefer to think of it as a high-tech polymer bedding process.
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
[FTC]: Any ideas? ttldomination FIRST Tech Challenge 4 29-10-2008 11:41
Any Ideas? Cody Carey Technical Discussion 7 25-02-2005 19:24
Any Ideas? Jonathanb Motors 3 16-04-2003 20:00
any ideas?!?!?!?!?!? Tyler Olds 3D Animation and Competition 0 26-11-2002 09:19
got any ideas? Brandon Martus Chit-Chat 4 02-09-2001 11:32
