Go to Post FIRST rocks, thats for sure. - Dan Richardson [more]
Go Back   Chief Delphi > Other > VEX
Unread 24-05-2009, 00:34
Chris is me's Avatar
AKA: Pinecone
Re: New VEX Game Announced!
If I was building a big giant unfolding wall of Vex plating, I'd just have the center stretch more than 2 feet. But a big, giant wall is unfeasible because your alliance partner can't break it either. A sliding wall on some kind of omnidirectional chassis, be it crab or omniwheel, would probably be better.
Man, why aren't there more Vex crab drives?
Unread 24-05-2009, 21:30
AlexD744 AlexD744 is offline
FRC #0744 (744 Shark Attack)
AlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond repute
Well as long as you knock most of the footballs to the other side in autonomous it doesn't matter what your partner does, because you've nasically won, but the difficulty of build a mega wall is the major problem.
www.sharkattack744.com
Unread 24-05-2009, 22:53
ttldomination's Avatar
Sunny
If you do manage to construct this "wall." What is the probability that you'll be able to maneuver as well as the robot which scrambles to score?
If you're up against a decent offensive bot, then the robot should be able to hold a LARGE amount of balls and then should be able to proceed and score them.
As easy as it may seem to build a bot with a large wall, I agree with gblake on that it won't be that effective during the match.
1648: 2013-2014
5283: 2015
Unread 25-05-2009, 00:04
AKA: Pinecone
I can see a lot more slightly geared up drive trains. You could unfold a wall with 2 motors, then power the drivetrain with 8 and gear it up slightly. No pushing matches, remember?
Then again, heavy walls would make this a bit of an issue. Can you speed-hole in Vex?
Unread 25-05-2009, 11:23
gblake's Avatar
gblake gblake is offline
6th Gear Developer; Mentor
AKA: Blake Ross
no team (6th Gear)
If you don't like the existing holes, you may certainly drill more.
Unread 25-05-2009, 17:26
phr34kR's Avatar
phr34kR phr34kR is offline
AKA: electrical/mechanical/Pneumatics
no team (symbiOHSis)
phr34kR is an unknown quantity at this point
Send a message via MSN to phr34kR
What about rollers for the wall?
Im thinking if you could lift your wall up past the goals then lower it in the middle of both of them and if you had wheels on the bottom of your wall so you could roll along it (omni drive would be a necessity) Then there would be no chance of being pushed away from the divider also would make for a very stable robot as the heavy wall will be supported by the field.
YAY won 6 out of 8 New Zealand VEX competitions!(and only killed Three servos in the process)
at least we made the semis
Its not a hole its a controlled leak...
Winners of the New Zealand excellence award (yay going to Dallas)
Unread 25-05-2009, 19:56
Sunny
Well, robots aren't allowed to the cross the wall and go over the other side and you're talking about putting a wall down on the other side...I think you might get disabled.
1648: 2013-2014
5283: 2015
Unread 25-05-2009, 20:33
gblake's Avatar
AKA: Blake Ross
no team (6th Gear)
Well, robots aren't allowed to the cross the wall and go over the other side ....
Not quite correct
Robots are not allowed to touch the opposite side's tiles. Robots are allowed reach over/under the wall
Unread 25-05-2009, 21:06
Sunny
Originally Posted by gblake View Post
Not quite correct
Yes you're correct, but the post before me said...
Originally Posted by phr34kR View Post
..and if you had wheels on the bottom of your wall so you could roll along it (omni drive would be a necessity) ..
I'm assuming the "it" is the floor.
1648: 2013-2014
5283: 2015
Unread 28-05-2009, 18:21
bobwrit's Avatar
bobwrit bobwrit is offline
//No Comment
AKA: ...
FRC #1977 (Loveland High Robotics)
bobwrit is just really nicebobwrit is just really nicebobwrit is just really nicebobwrit is just really nicebobwrit is just really nice
Well, I guess 1977 is in VRC for this year also.
FRC Team 1977 Alumni
Has Attended:2008 Colorado regional
2009 Colorado Kickoff
2009 Colorado Regional
2010 Colorado Kickoff
2010 Colorado Regional
The most exciting phrase to hear in science, the one that heralds new discoveries, is not "Eureka!"(I found it!), but rather, "Hmm.... That's funny" ---Isaac Asimov
Chance favors the prepared mind ---Louis Pasteur
And you can tell me, that I can't make a diffrence because I'm just one, but one is all it takes to start it. And you can tell me, that I can't change the world because I'm too young, but I wont stand here and be your target. ---FM Static
Unread 29-05-2009, 09:33
astallasalion astallasalion is offline
FRC #1261 (Robolions)
astallasalion is an unknown quantity at this point
Well, we're only allowed 10 motors/servos per robot, and crab has to have each wheel independently driven. On top of that, we need two motors/servos to turn the wheels for coax. There are a few teams that use 6 motors on their drivetrain but not a lot, as most of them use their motors to build manipulators.
For this game I'm even contemplating using 2 drive motors geared for torque, just because I need all of my motors for the manipulator(s).
New Vex Microcontroller announced Brandon Martus General Forum 19 07-05-2009 16:00
VEX Robotics Competition Announces New Game Brandon Martus Announcements 11 01-09-2008 23:28
Asian Robotics League Vex Game Announced Brandon Martus Announcements 13 18-09-2007 20:06
2006 VEX Game Announced Jeremy Roberts FIRST Tech Challenge 11 19-10-2005 20:11
2006 Vex Season and new accessories announced Mike M. FIRST Tech Challenge 10 06-09-2005 15:49
