Go to Post FIRST has stated time and again that the program is not about teaching (they always refer to the I and R in FIRST) - Dave Flowerday [more]
Go Back   Chief Delphi > Other > VEX
  #106   Spotlight this post!
Unread 24-05-2009, 14:03
gblake's Avatar
gblake gblake is offline
6th Gear Developer; Mentor
AKA: Blake Ross
no team (6th Gear)
Re: New VEX Game Announced!
Originally Posted by Smoores View Post
I've already managed to build a wall/arm that has a 3 foot span. I could add another 2 feet if that was my sole strategy.
Suppose you erect a wall with a 5 foot wing span and a non-trivial height over the wall that is part of the field.
If I stroll up with my little dumping bot; will I
a) Be able to simply race you to a spot in the 7 feet of the field's width that your wall doesn't cover and be able to beat you there?
b) Be able to easily push either end of your wall out of the way because I have the advantage of leverage when I push on a part of the wall that far from the main body of your robot and because a wall that large made of Vex metal has to be pretty flexible.
I would like to see a picture of what you have built, no matter what. Building it does seem to be a interesting experiment and learning experience, but I just can't imagine it being effective in a Clean Sweep match.
On the other hand, you might be getting good training for deploying solar cell arrays or other structures in outer space, or for bridging small rivers here on earth.
Blake
  #107   Spotlight this post!
Unread 24-05-2009, 21:30
AlexD744 AlexD744 is offline
FRC #0744 (744 Shark Attack)
AlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond repute
Originally Posted by Chris is me View Post
If I was building a big giant unfolding wall of Vex plating, I'd just have the center stretch more than 2 feet. But a big, giant wall is unfeasible because your alliance partner can't break it either. A sliding wall on some kind of omnidirectional chassis, be it crab or omniwheel, would probably be better.
Man, why aren't there more Vex crab drives?
Well as long as you knock most of the footballs to the other side in autonomous it doesn't matter what your partner does, because you've nasically won, but the difficulty of build a mega wall is the major problem.
www.sharkattack744.com
  #108   Spotlight this post!
Unread 24-05-2009, 22:53
ttldomination's Avatar
Sunny
If you do manage to construct this "wall." What is the probability that you'll be able to maneuver as well as the robot which scrambles to score?
If you're up against a decent offensive bot, then the robot should be able to hold a LARGE amount of balls and then should be able to proceed and score them.
As easy as it may seem to build a bot with a large wall, I agree with gblake on that it won't be that effective during the match.
1648: 2013-2014
5283: 2015
  #109   Spotlight this post!
Unread 25-05-2009, 00:04
Chris is me's Avatar
AKA: Pinecone
I can see a lot more slightly geared up drive trains. You could unfold a wall with 2 motors, then power the drivetrain with 8 and gear it up slightly. No pushing matches, remember?
Then again, heavy walls would make this a bit of an issue. Can you speed-hole in Vex?
  #110   Spotlight this post!
Unread 25-05-2009, 11:23
gblake's Avatar
AKA: Blake Ross
no team (6th Gear)
If you don't like the existing holes, you may certainly drill more.
  #111   Spotlight this post!
Unread 25-05-2009, 17:26
phr34kR's Avatar
phr34kR phr34kR is offline
AKA: electrical/mechanical/Pneumatics
no team (symbiOHSis)
phr34kR is an unknown quantity at this point
Send a message via MSN to phr34kR
What about rollers for the wall?
Im thinking if you could lift your wall up past the goals then lower it in the middle of both of them and if you had wheels on the bottom of your wall so you could roll along it (omni drive would be a necessity) Then there would be no chance of being pushed away from the divider also would make for a very stable robot as the heavy wall will be supported by the field.
YAY won 6 out of 8 New Zealand VEX competitions!(and only killed Three servos in the process)
at least we made the semis
Its not a hole its a controlled leak...
Winners of the New Zealand excellence award (yay going to Dallas)
  #112   Spotlight this post!
Unread 25-05-2009, 19:56
Sunny
Well, robots aren't allowed to the cross the wall and go over the other side and you're talking about putting a wall down on the other side...I think you might get disabled.
1648: 2013-2014
5283: 2015
  #113   Spotlight this post!
Unread 25-05-2009, 20:33
gblake's Avatar
AKA: Blake Ross
no team (6th Gear)
Well, robots aren't allowed to the cross the wall and go over the other side ....
Not quite correct
Robots are not allowed to touch the opposite side's tiles. Robots are allowed reach over/under the wall
  #114   Spotlight this post!
Unread 25-05-2009, 21:06
Sunny
Originally Posted by gblake View Post
Not quite correct
Yes you're correct, but the post before me said...
Originally Posted by phr34kR View Post
..and if you had wheels on the bottom of your wall so you could roll along it (omni drive would be a necessity) ..
I'm assuming the "it" is the floor.
1648: 2013-2014
5283: 2015
  #115   Spotlight this post!
Unread 28-05-2009, 18:21
bobwrit's Avatar
bobwrit bobwrit is offline
//No Comment
AKA: ...
FRC #1977 (Loveland High Robotics)
bobwrit is just really nicebobwrit is just really nicebobwrit is just really nicebobwrit is just really nicebobwrit is just really nice
Well, I guess 1977 is in VRC for this year also.
FRC Team 1977 Alumni
Has Attended:2008 Colorado regional
2009 Colorado Kickoff
2009 Colorado Regional
2010 Colorado Kickoff
2010 Colorado Regional
The most exciting phrase to hear in science, the one that heralds new discoveries, is not "Eureka!"(I found it!), but rather, "Hmm.... That's funny" ---Isaac Asimov
Chance favors the prepared mind ---Louis Pasteur
And you can tell me, that I can't make a diffrence because I'm just one, but one is all it takes to start it. And you can tell me, that I can't change the world because I'm too young, but I wont stand here and be your target. ---FM Static
  #116   Spotlight this post!
Unread 29-05-2009, 09:33
astallasalion astallasalion is offline
FRC #1261 (Robolions)
astallasalion is an unknown quantity at this point
Well, we're only allowed 10 motors/servos per robot, and crab has to have each wheel independently driven. On top of that, we need two motors/servos to turn the wheels for coax. There are a few teams that use 6 motors on their drivetrain but not a lot, as most of them use their motors to build manipulators.
For this game I'm even contemplating using 2 drive motors geared for torque, just because I need all of my motors for the manipulator(s).
  #117   Spotlight this post!
Unread 29-05-2009, 12:21
Ben Mitchell Ben Mitchell is offline
Ben Mitchell has a reputation beyond reputeBen Mitchell has a reputation beyond reputeBen Mitchell has a reputation beyond reputeBen Mitchell has a reputation beyond reputeBen Mitchell has a reputation beyond reputeBen Mitchell has a reputation beyond reputeBen Mitchell has a reputation beyond reputeBen Mitchell has a reputation beyond reputeBen Mitchell has a reputation beyond reputeBen Mitchell has a reputation beyond reputeBen Mitchell has a reputation beyond repute
I registered three teams while still in Texas and my kids got to spend the plane ride home with a box of sample game scoring objects and a notebook for writing ideas.
It was cleanly done and I really liked having the new game out now - my students can work on it over the summer if they so desire.
Benjamin Mitchell
Vex Robotics Competition team advisor (4 high school teams)
  #118   Spotlight this post!
Unread 29-05-2009, 17:26
595294001 595294001 is offline
FTC World Champion
FTC #2820 (Longhorn Robotics)
595294001 is an unknown quantity at this point
My only complaint is about the time frame. For those of us 10-20 hours a week, (while I'm sure that will be toned down for summer), the only realistic use for more time, would be a more advanced autonomous. Plus it gives makes recruiting hard with no time between seasons to get the people coming into grade 10 interested. And finally it means that you lose some of the real-life-esque pressure the old time frame provided, I mean look at FRC...
2820: Longhorn Robotics
2009 World Championships - Winning Alliance
2009 Edison Division - Winning Alliance
2009 BC Regional - Inspire
2009 BC Regional - Winning Alliance
2009 Rookie Team
  #119   Spotlight this post!
Unread 29-05-2009, 17:39
Andrew Bates's Avatar
Andrew Bates Andrew Bates is offline
AKA: Bates
FRC #0125 (NUTRONS)
Andrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond repute
So you would prefer to be under a ton of pressure to get something done in time instead of being able to relax think ideas through experiment and then decided to build? I personally prefer this time frame plenty of time to work around other events.
ME Student at Northeastern University, Captain of the NUTRONs #125 FRC
Former member of VEXELLENT and Cranbrook Robotics
  #120   Spotlight this post!
Unread 29-05-2009, 21:08
gblake's Avatar
AKA: Blake Ross
no team (6th Gear)
Wink Re: New VEX Game Announced!
Good plan - I look forward to seeing it in action
Then you should get them interested during grade 8 and have them compete in at least one scrimmage that year. That way, by the time they reach grade 10 they are already both interested and experienced.
New Vex Microcontroller announced Brandon Martus General Forum 19 07-05-2009 16:00
VEX Robotics Competition Announces New Game Brandon Martus Announcements 11 01-09-2008 23:28
Asian Robotics League Vex Game Announced Brandon Martus Announcements 13 18-09-2007 20:06
2006 VEX Game Announced Jeremy Roberts FIRST Tech Challenge 11 19-10-2005 20:11
2006 Vex Season and new accessories announced Mike M. FIRST Tech Challenge 10 06-09-2005 15:49
