Go to Post Needless to say, lots of smoke came out, and I debated using its terrible smell as a deterrent. - Snapshot [more]
Unread 23-10-2001, 14:44
kmcclary's Avatar
kmcclary kmcclary is offline
Founder 830/1015;Mentor 66/470/1502
FRC #0470 (Alpha Omega Robotics)
Rookie Year: 1994
kmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond reputekmcclary has a reputation beyond repute
Allowed wood types
1) When you specify "plywood up to 3/4 inch", MUST it be plywood, or may we please use other wood such as a pine or hardwood board?
For small pieces, any solid wood is definitely preferable over plywood. We need to make a small part out of wood, and small pieces of plywood tend to shatter and split easily, especially if you try to drill it on an edge.
2) Would you consider allowing DOWELS of wood (or Plexiglas)?
IMHO, a reasonable thing would be to allow that up to the same size as the flat stock of the same type (3/4" wood, 1/4" for lexan). That would be cheap, consistent with other materials & glues, and cover a good range for "round things" between the allowed 1/4" rod and pipe. (We need a small round piece of something like wood or plastic for a widget, and the size ranges of the other things aren't optimum.)
I guess we're REALLY just trying to avoid spending time sanding square slices of wood or lexan round (or worse, cutting out a pile of tiny disks out of flat stock and gluing them all together ;-) if we don't have to, just to make things like a 30 cent dowel stick! <GRIN>
Thanks!
- Keith McClary, Huron High Team 830
Keith McClary - Organizer/Mentor/Sponsor - Ann Arbor MI area FIRST teams
ACTI - Automation Computer Technologies, Inc. (Sponsoring FIRST teams since 2001!)
MI Robot Club (Trainer) / GO-Tech Maker's Club / RepRap-Michigan) / SEMI CNC Club
"Certifiably Insane": Started FIVE FRC teams & many robot clubs (so far)!
2002: 830 "Rat Pack" | 2003-5;14: 1015;1076 "Pi Hi Samurai" | 2005-6: 1549 "Washtenuts"/"Fire Traxx"
2005-(on): 1502 "Technical Difficulties" | 2006-(on): FIRST Volunteer!
2009-(on): 470 "Alpha Omega" | WAFL | Sponsor & "Floating Engineer" for MI Dist 13 (Washtenaw Cnty)
2011: 3638 "Tigertrons" | 2013-(on): 4395 "ViBots" | 2014-(on) 66 "Grizzlies"
"Home" Teams: 66, 470, 1076, 1502, 4395
Local FIRST alumni at or coming to Ann Arbor (UM/EMU/WCC/Cleary)?
...We Want YOU as a Mentor! Please email me for info!
Support CDF Reputation - If a posting helped, thank 'em with rep points!
"It must be FRC build season when your spouse and children become 'Action Items 8 & 9'..."
Unread 24-10-2001, 21:23
meaubry meaubry is offline
volunteer helper
FRC #6099 (Knights)
meaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond repute
Keith,
Question #1) Can you use solid wood instead of plywood? I need to talk to Martus and find out what we have ruled in past years on this (I know its come up in previous CDI's) I'll get back to you.
Question #2) - Are dowels allowed? You have me confused on what you are calling dowels. ROD (cylindrical)? or Biscuits (flat oval shaped)? Sounds like you are talking about biscuits but then at the end you say "dowel stick"
You also state, "We need a small round piece of something like wood or plastic for a widget". Are you asking about a widget made of solid wood (not plywood)? Is this related to the 1st or 2nd question?
Unread 25-10-2001, 00:29
kmcclary's Avatar
Rookie Year: 1994
dowels and biscuts
By dowel I mean a chunk of cylindrical rod, not a flat biscuit.
Yes, and it is round, but it will be within the same 3/4" max thickness specification, per piece.
That's why we're especially interested in dowels.
Both. If premade dowels are not allowed, it is very tough to make a reliable one out of plywood.
Thanks!
Unread 25-10-2001, 22:59
volunteer helper
FRC #6099 (Knights)
After checking out our response from previous years and discussing it among ourselves, we have decided that the rules related to using plywood stand "as is". No solid hardwood this year, its too late into the build cycle to change these rules and still make it fair to everyone. We have noted it and will re-evaluate this item for next years competition.
Unread 26-10-2001, 01:04
kmcclary's Avatar
Rookie Year: 1994
Thanks!
OK. I'm sure we'll figure out something else then. <grin>
Thanks!
What's the best combination for bot types this year? authgeek1218 Rules/Strategy 5 09-01-2003 00:14
How many allowed to finals? LeadRiccardoT Championship Event 4 08-01-2003 21:27
Button types Scottie2Hottie General Forum 7 27-03-2002 00:13
No antimatter allowed on robot Jan Olligs Chit-Chat 9 19-02-2002 21:13
Is a Limiter Switch allowed? Randy_Ai Technical Discussion 4 12-02-2002 00:57
