Go to Post To change culture, you're going to have to get people to listen. - Yipyapper [more]
Unread 28-05-2009, 21:36
johnr johnr is offline
FRC #0910
johnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond repute
Bill's latest blog
Bill's latest blog mentions a problem at the start of matches. How wide spread was this problem and how much could it effect code. I am not a programmer but our bot did act up once or twice late in the season. Thanks for any further explanation you can give.
Unread 28-05-2009, 23:27
bobwrit's Avatar
bobwrit bobwrit is offline
//No Comment
AKA: ...
FRC #1977 (Loveland High Robotics)
bobwrit is just really nicebobwrit is just really nicebobwrit is just really nicebobwrit is just really nicebobwrit is just really nice
Re: Bill's latest blog
I didn't notice it often, but I noteced teams getting dropped from the FMS more often. It *may* affect a teams code slightly by forcing them to think of teleop and auton as two seperate programs instead of having one, then the other.
FRC Team 1977 Alumni
Has Attended:2008 Colorado regional
2009 Colorado Kickoff
2009 Colorado Regional
2010 Colorado Kickoff
2010 Colorado Regional
The most exciting phrase to hear in science, the one that heralds new discoveries, is not "Eureka!"(I found it!), but rather, "Hmm.... That's funny" ---Isaac Asimov
Chance favors the prepared mind ---Louis Pasteur
And you can tell me, that I can't make a diffrence because I'm just one, but one is all it takes to start it. And you can tell me, that I can't change the world because I'm too young, but I wont stand here and be your target. ---FM Static
Unread 29-05-2009, 00:33
Ice Berg's Avatar
Ice Berg Ice Berg is offline
Seth Berg
AKA: Seth Berg
FRC #0694 (Stuy Pulse)
Ice Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to behold
Send a message via AIM to Ice Berg
This problem plagued us throughout the season, and caused us to sit still during autonomous during eliminations at Hartford. Our autonomous routine implemented a timer in order to break out of a PID loop. We had intermittent problems throughout NY and CT, but the FTA people couldn't figure it out. We suggested that the field may have been sending auton enabled signals before auton actually began causing the timer to start and count down, then when auton actually started the timer had already run out, but the field people said that this was impossible (disclaimer: not being a programmer I only have a general sense of how the program worked, so I'm sorry for not being more specific). We actually spent the last few weeks going through our code trying to fix the "problem" but could not find anything. This explains a lot.
Mens et Manus
Unread 29-05-2009, 05:54
jtdowney jtdowney is offline
Boiler Up
AKA: John Downey
FRC #4302 (Robophins)
jtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant future
This is an issue that I noticed quite a bit on Galileo. Speaking as a professional software developer I can say that independent programs to talk to each other in a disconnected manor is a difficult problem to solve. There is a lot to be said for the positives of FMS but every piece of software has its defects. At least no one got hurt because of this bug.
John Downey
Lead Robot Inspector - Purdue IndianaFIRST District
Whitney Young Magnet High School/Robophins (FRC 4302) - Mentor (2013-current)
Midwest Regional Planning Committee - Member (2012-current)
Boilermaker Regional Planning Committee - Member (2011-2014)
Robot Inspector (2008-current)
Purdue FIRST Programs - Staff Advisor (2008-2011)
Lafayette-Jefferson High School/Precision Guessworks (FRC 1646) - Mentor (2006-2011)
Unread 29-05-2009, 06:15
Essentially, if the DS and robot began communicating with each other before the FMS exerted control (takes a second or two), then it would start operating enabled just like at home. Either auto/enabled or teleop/enabled depending on how your DS switch was set.
This bug was discovered during the early events and was the reason for the team startup procedure of:
1) making sure your DS switch was set to Teleop,
2) waiting for the Field Preset,
3) connecting the Driver Station and waiting for FMS to recognize the DS,
4) powering up the robot.
For next year, to solve this, FIRST is looking at a firmware change that forces both the DS and cRIO to connect to FMS before being allowed to connect to each other.
The window was small, but the robots could twitch dangerously (threatening the team & field crew), and of course if you used an auto state machine or a timer then your auto would likely be messed up.
For programmers this means always resetting any required startup states during auto/disable or teleop/disable. In the early days of autonomous in 2003/2004 we had similar learning experiences where the modes could be mixed and not the progression you'd expect: 1)auto/disabled, 2)auto/enabled, 3)teleop/disabled. 4)teleop/enabled, 5)teleop/disabled.
You might see a similar issue during the usual back-to-back practice matches run on Thursday.
Don't design your code to depend on these exact steps. Design it to work at home if the Teleop/Auto switch is toggled randomly.
We found at SBPLI we could safely stagger the startup procedure, but we made sure the FMS was in control of the DS before the robot cRIO's finished booting.
Unread 29-05-2009, 07:37
Jared Russell's Avatar
Taking a year (mostly) off
I have a scar on my left hand from when our "disabled" robot suddenly enabled itself in San Diego. I am glad to see that we are at least cognizant of the issue.
Unread 29-05-2009, 09:10
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
We had trouble with out robot (rolling PID loop(s)) on Galileo during the semi finals when they started rushing people to turn on the robot "right away". It caused our auto malfunction and we were not allowed to reboot the robot from the DS.
Unread 30-05-2009, 23:18
RoboMaster's Avatar
RoboMaster RoboMaster is offline
Alum, former programmer&co-captain
FRC #2472 (The Centurions)
RoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant future
I don't think that this was the cause to our problem, but one time our robot was unable to drive around during the whole match. The wheels would move and other motors on our robot would move just fine and such, but apparently our back two wheels (we had 4WD for our traction control) were not moving. Our front wheels were not able to provide enough pulling force to move our robot and we could only inch forward.
This doesn't sound like a symptom of this problem, but just wanted to throw that out there. Our robot is mysteriously fine now and we have theorized till our brains cramped.
My engineering blog: noeticbrainwaves.blogspot.com
I'm not slacking, my code's compiling
...and I'm using LabVIEW
Unread 31-05-2009, 00:58
AlexD744 AlexD744 is offline
FRC #0744 (744 Shark Attack)
AlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond repute
Yeah something like that happened to us our very first match on Galileo. Thanks again for making sue we were okay. After that we conspired to get the control board on in like 2 secs and our driver and coach slowed down a little while placing the robot.
www.sharkattack744.com
Unread 01-06-2009, 12:17
That sounds like it could be the problem I reported on the FIRST Forums.
Update from Bill's Blog (Rules 1/6/09) Karthik1 General Forum 3 06-01-2009 17:37
Message from Dean on Bill's Blog IndySam General Forum 9 14-11-2008 17:23
**FIRST EMAIL**/FRC Blog - Bill's Place Richard McClellan FIRST E-Mail Blast Archive 21 15-09-2008 20:07
Bill's Place Moved => Now Bills Blog BornaE General Forum 1 10-09-2008 18:18
