Go to Post make sure to make it look really cool, it makes it easier for teams to remember you, which comes in handy for alliance selections ;) - Holtzman [more]
Unread 29-05-2009, 15:30
kramarczyk's Avatar
kramarczyk kramarczyk is offline
is getting his kicks.
AKA: Mark Kramarczyk
FRC #3096 (Highlanders)
kramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond repute
Re: Team Trailer Ideas?
Originally Posted by DeepWater View Post
The plan was to install it exactly as shown in the video. In the video the walls are already covered in plywood and the E-Track is installed on top of the plywood which would leave the E-Track raised. Are you suggesting two layers of plywood? The first as in the video and then piece in sections between the horizontal E-Track strips to flush up the wall flat with the outermost surface of the E-Track? While I can see the advantage to this I am wondering about how much extra weight that might add to the trailer that could take away from the carrying capacity.
In the video he was retrofitting the trailer, so the plywood was already there. The mechanics would be the same without the plywood, in fact, he never actually attaches to the plywood, just the trailer 'stud'. I would not put on two layers of plywood. I also would probably not go to the effort of stripping off existing plywood just to make it flush. I'm sure that you can install the e-track over the plywood and be satisfied with the result; it's not like you will be loading/unloading every day. I only suggested the flush mount since you already planned to put up new plywood. e.g. install e-track, then install plywood of a thickness to make it flush. Perhaps I am, once again, making the simple complicated.
Mark
Brick walls are for other people. - Randy Pausch
Unread 29-05-2009, 15:41
ChuckDickerson's Avatar
ChuckDickerson ChuckDickerson is offline
FRC #0456 (Siege Robotics)
No, you are being extreamly helpful! I like the idea of the plywood being flush or even a bit raised above the top of the E-Track so that the wood makes first contact rather than the item being carried rubbing on the metal track. Since the inside of the trailer has been stripped we could go either way but I am now leaning toward a layer of plywood first then the E-Track installed as in the video and then adding some strategically placed 1x4 or 2x4 "rub rails" horizontally between the strips of E-Track. I'm not sure the exact thickness of E-Track but I would think some pine 1x4s might be about right and if/when they get damaged they would be easier to replace as needed than whole sheets of plywood. This page seems to have all the E-Track dimensions except what I need (the thickness).
Unread 29-05-2009, 20:54
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Originally Posted by IndySam View Post
Set yourself a weight budget and keep track of the weight (just like building a robot.)
We have a weight budget
___________________
- Tennyson, Ulysses
Unread 29-05-2009, 21:32
Onward through the fog.
It's a good idea (though I think you are teasing) . The years that I pulled the team trailer, we were careful with the weight, also keeping in mind the weight that the vehicle I was driving would have to carry.
I just love threads about trailers, they are so cool.
~ Helen Keller
(1880-1968)
Unread 30-05-2009, 19:59
Joining the 900 Meme Team
FRC #0079
This is good, we accidentally overloaded a trailer a couple years back, getting a phone call from the parent driving it back saying it broke on a Sunday morning is not an experience I think anyone wants .
Unread 02-06-2009, 01:56
kapolavery's Avatar
kapolavery kapolavery is offline
All Your Base Are Belong to FIRST
AKA: Avery-John Domingo
FRC #2445 (RoboKAP)
kapolavery is a splendid one to beholdkapolavery is a splendid one to beholdkapolavery is a splendid one to beholdkapolavery is a splendid one to beholdkapolavery is a splendid one to beholdkapolavery is a splendid one to beholdkapolavery is a splendid one to beholdkapolavery is a splendid one to behold
Model it after Optimus Prime!
Seriously!
"There's always next year..."
Unread 02-06-2009, 17:06
cpeister's Avatar
cpeister cpeister is offline
Mech Eng Student at Waterloo
AKA: Cale Peister
FRC #0781 (Kinetic Knights)
cpeister has much to be proud ofcpeister has much to be proud ofcpeister has much to be proud ofcpeister has much to be proud ofcpeister has much to be proud ofcpeister has much to be proud ofcpeister has much to be proud ofcpeister has much to be proud of
Send a message via MSN to cpeister
Be careful when loading the trailer of where the weight is located. Although you may be within the weight limitations of the truck/trailer, packing the heavy items too close to the front will cause increased tongue weight, pushing down the back of the tow vehicle. Likewise, placing heavy items too far to the rear will cause the tongue to be light, lifting the rear of the vehicle, and making the trailer more likely to slip off of the ball. Also, if it is uncoupled while loaded, the tongue will have a tendency to lift up. Plan to load the heaviest items over or just ahead of the axle, in order to prevent this problem.
Cale Peister - Team 781 Alumni
Mechanical Engineering Student at Waterloo
Attended: WAT'07, WAT'08, GTR'08, WAT'09, GTR'09, WAT'10, GTR'10, WAT'11, GTRE/W'11, BUCKEYE'11, CMP'11, GTRE'12, WAT'12, GTRW'12, WAT'13, WAT'14, WAT '15
Unread 02-06-2009, 21:36
Bertman's Avatar
Bertman Bertman is offline
FRC #0418 (Purple Haze)
Bertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond repute
Keep the design flexible with lots of tie downs, both high and low. Interior lights are a great help. Carry a good spare with jack & lug wrench. Remember, if you are loading or working in the trailer and it is not attached to a vehicle, it will pivot around the axle and gravity will take over (don't ask how I know this)
Team 121 2009 Trailer Kyle Fenton Robot Showcase 13 23-02-2009 20:43
Low-Cost trailer drawings? (was: Trailer) DM7000 General Forum 2 07-01-2009 16:54
pic: Team 1676 Trailer 2 Graham Donaldson Extra Discussion 17 29-11-2007 11:06
pic: Team 1676 Trailer 1 Graham Donaldson Extra Discussion 1 27-11-2007 20:15
Team 871 Trailer WernerNYK Robot Showcase 6 19-02-2002 03:42
