Go to Post You can lay out all the disclaimers that you want, but the bottom line is you are representing your team. - Karthik [more]
  #61   Spotlight this post!
Unread 29-05-2009, 21:23
Terminator Terminator is offline
None #0025
Terminator has a reputation beyond reputeTerminator has a reputation beyond reputeTerminator has a reputation beyond reputeTerminator has a reputation beyond reputeTerminator has a reputation beyond reputeTerminator has a reputation beyond reputeTerminator has a reputation beyond reputeTerminator has a reputation beyond reputeTerminator has a reputation beyond reputeTerminator has a reputation beyond reputeTerminator has a reputation beyond repute
Re: T-Shirt cannon pnuematic set ups
Originally Posted by Tanis View Post
Hey everyone,
Our team is hoping to build a t-shirt cannon this summer, but need some help.
First, to those that have built one before, or have an idea as to how to do it, could you list the pneumatic (or sprinkler) parts used, including valve/solenoid, tubing/hose, connectors, and pump? We've seen tutorials with how to do it with things like a bike pumb and manual release knob/switch, but not an electric one. If you could also link where you got it, that would be great.
Second, is there a (cheap) way to attach a digital PSI sensor to the pneumatics? We would like to adjust the PSI output from the OI, but we aren't sure if we can.
All help is appreciated.
Thanks!
Looks great. Any way that I can get the plans and list of parts from you? Any other team that has built them, please let me know.
Have any of you built a handheld launcher? Please e-mail me any information to cpbio@aol.com
  #62   Spotlight this post!
Unread 20-07-2009, 09:19
McGyver McGyver is offline
FRC #0571
McGyver is an unknown quantity at this point
the Physics class at my school made a t-shirt cannon and they used a sprinkler valve to fire it, but they also used a SCUBA tank and regulator before it. as for the pressure gauge, there are digital gauges available for under $5 that just use a sensor with a variable resistance. I believe that there is a LEGO 'hack' website that has instructions on how to pirate the gauge and use it as a sensor.
  #63   Spotlight this post!
Unread 21-07-2009, 23:16
gallo26's Avatar
gallo26 gallo26 is offline
Team 79 Alumni
AKA: Bryan Gallo
FRC #0079 (Team KRUNCH)
gallo26 is a name known to allgallo26 is a name known to allgallo26 is a name known to allgallo26 is a name known to allgallo26 is a name known to allgallo26 is a name known to all
Send a message via AIM to gallo26
Wow awesome! Glad to see other teams making T Shirt cannons!
We're building our 3rd generation cannons right now into our robot. Sprinkler valves are the best to release the pressure because they can be controlled by a spike relay. Fairly cheap too.
As for the pressure, we've figured out that all you need is a normal pressure switch. So that's usually 115psi-120psi. Between the pumps and the air tank reservoir add a pressure regulator. You can regulate the pressure and know what the pressure will be at, and the OI will receive the shut off from the pressure switch as you normally would.
I don't know if that's been posted before or not, I didn't have time to read all 60+ posts on this thread, i was just too excited to post. So if someone else DID post this, I do apologize.
Bryan Gallo
Team 79 Alumni '11- Present
Team 79 Driver '09, '10
Team 79 Senior CAD Designer '09, '10
Team 79 President '09
Team 79 Electrical Sub Team Leader '08, '09
pic: Fully Automatic Tee Shirt Cannon - Pic 2 artdutra04 Extra Discussion 23 26-07-2015 13:20
pic: T-Shirt Cannon at Purdue's Homecoming jtdowney Extra Discussion 10 08-11-2007 19:48
IRI T-shirt cannon Kyle Love Off-Season Events 6 17-07-2007 12:09
pic: 549's t-shirt cannon and ballon inflator w/ horn griff549 Extra Discussion 2 06-05-2007 00:36
pic: UPS with UPS Kevin Kolodziej Extra Discussion 10 04-05-2005 12:57
