Go to Post I'm sure FIRST did the math. They always do the math. Just not math humans use. It was probably given to them from NASA from the aliens so we'd quit predicting the divisions before they release it. - Koko Ed [more]
Unread 29-05-2009, 23:15
kramarczyk's Avatar
kramarczyk kramarczyk is offline
is getting his kicks.
AKA: Mark Kramarczyk
FRC #3096 (Highlanders)
kramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond repute
Re: Gears for CIM
The Toughbox has an optional output ratio of 5.95:1 with the 40 tooth output gear and the 24 tooth cluster gear. And what do you know, the output is a .5" shaft. AndyMark must have already thought of this application.
Mark
Brick walls are for other people. - Randy Pausch
your thoughts on the FP CIM/2.5 CIM motor drive setup versus 2 2.5 CIM motors waialua359 Motors 11 14-12-2007 04:29
Gears for CIMs Brawler006 Motors 5 18-01-2004 09:46
Replacement for Bevel Gears? Greg Technical Discussion 3 30-03-2003 19:56
Spur Gears for Bosch and FP archiver 2001 11 24-06-2002 03:17
Gears for Chipuahs!!! dense Motors 2 16-01-2002 20:41
