Go to Post 50% of the time that 330 used mcmaster 2717T51, we went to Einstein. Your mileage may vary. - Joe Ross [more]
Unread 29-05-2009, 21:58
Creator Mat Creator Mat is offline
FRC #2338 (Gear it Forward)
Creator Mat is a jewel in the roughCreator Mat is a jewel in the roughCreator Mat is a jewel in the roughCreator Mat is a jewel in the rough
Gears for CIM
I am in charge of designing a swerve drive for my team. I am having touble finding a spur gear that has the bore size to direct connect to the CIM's.
What i need it for is a CIM with a spur gear direct connect that goes to a .5" axle with another gear on it. I would like about a 6:1 gear ratio but if larger can be found that would be aswome. Note: the larger gear has to be smaller in diameter than a standard FIRST wheel.
So if anybody has a place to buy gears for a cim that would rock.
2010 Midwest Spirit award
2010 Midwest Quarterfinalists
2010 Wisconsin Quarterfinalists
2009 Midwest Finalists
2009 Wisconsin Quarterfinalists
2008 Midwest Rookie AllStars
Unread 29-05-2009, 22:09
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Gears for CIM
here is a gear that will fit a CIM shaft, you should be able to find some gears that will mate with it at the same web site.
http://store.andymark.biz/am-0034.html
not sure if you'll find a 6:1 ratio though...that usually takes two stages of reduction to achieve
Unread 29-05-2009, 23:15
kramarczyk's Avatar
kramarczyk kramarczyk is offline
is getting his kicks.
AKA: Mark Kramarczyk
FRC #3096 (Highlanders)
kramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond repute
Re: Gears for CIM
The Toughbox has an optional output ratio of 5.95:1 with the 40 tooth output gear and the 24 tooth cluster gear. And what do you know, the output is a .5" shaft. AndyMark must have already thought of this application.
Mark
Brick walls are for other people. - Randy Pausch
Unread 29-05-2009, 23:43
Re: Gears for CIM
Thanks for the quick answers
Unread 30-05-2009, 00:04
Joe_Widen's Avatar
Joe_Widen Joe_Widen is offline
FRC #1675 (The Ultimate Protection Squad)
Joe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud of
Re: Gears for CIM
I know this doesn't directly apply to your question, but when your designing the crab drive leave like .003" inbetween gears. If you plan for them to mesh perfectly, youll find they grind a bit and dont spin that well.
Finally in college =]
2009 Midwest Regional Champions - Thanks 111 and 1625
Unread 30-05-2009, 10:03
techtiger1's Avatar
techtiger1 techtiger1 is offline
Coach Drew?!?!
AKA: Drew Disbury
FRC #1251 (TechTigers)
techtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond repute
Send a message via AIM to techtiger1
Re: Gears for CIM
Matt the bore for the cim gear is 8mm with a 2mm key way.
Team 1251 The TechTigers
"Inspiring future innovators, one stripe at a time"
2004 Rookie All Star Orlando Regional
2006 Palmetto Regional Winner
2007 Orlando Regional Winner
2008 Orlando Regional Winner
2010 Orlando Regional Winner
2013 South Florida Regional Winner
Unread 30-05-2009, 10:33
Tom Line's Avatar
Tom Line Tom Line is online now
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Re: Gears for CIM
Right-o. But that's not just for swerve drive.
That distance, or looseness between gear teeth is called backlash.
http://www.engineersedge.com/gears/gear_backlash.htm
ALL gears require some backlash to allow optimal function. Too much causes other problems. Normally, if you buy a set of small feeler gages you can set your backlash consistently. You always want some.
Unread 30-05-2009, 11:20
Michael Corsetto's Avatar
Michael Corsetto Michael Corsetto is offline
Breathe in... Breathe out...
FRC #1678 (Citrus Circuits)
Michael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond repute
Re: Gears for CIM
This occurs over two stages though, so it might not be what Mat is looking for. Keep in mind Mat that 14 teeth is probably the smallest CIM spur gear you'll find, which means you'll need an 84 tooth gear to mesh with it in order to get the ratio you want in one stage. A spur gear that size will have a radius of somewhere around 4.5 inches, which might be a problem for you depending on what wheel diameter you plan on using. If you are set on having a single reduction, Martin Sprocket's pdf catalog list 20dp 14.5pa spur gears with sizes all the way up to 132 teeth. They even happen to carry an 84 tooth gear, what are the chances? (By the way, the 84 tooth gear they carry has a 1/2 inch stock bore, so all you'll need to do is broach a keyway into it. It also weighs 2 pounds, so be careful )
Mike C.
Team 1678: Citrus Circuits - Lead Technical Mentor, Drive Coach **Like Us On Facebook!**
Unread 30-05-2009, 11:36
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Re: Gears for CIM
It's not a terribly significant difference, but AndyMark also sells 12 tooth CIM gears: http://andymark.biz/am-0018.html
--Madison--
...down at the Ozdust!
Unread 30-05-2009, 13:37
NickE's Avatar
NickE NickE is offline
_
Re: Gears for CIM
Mike C.
You probably won't be able to accomplish this in one reduction with the CIM placed directly above the wheel. This would require having a final gear slightlly smaller than your wheel and a pinion slightly larger than the CIM Motor (>52 teeth), which will not accomplish the desired reduction. A pinion gear smaller than the CIM motor will cause the motor to intersect the wheel.
Unread 31-05-2009, 09:37
Andy Brockway Andy Brockway is offline
Engineer
FRC #0716 (Who'sCTEKS)
Andy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond repute
Re: Gears for CIM
If you want to modify a gear yourself or have a shop do it for you, then any stock gear with a 5/16" bore will work.
5/16" bore will work with an 8mm reamer. Ream the gear with an 8mm reamer and broach with a 2mm keyway broach. Add a set screw over the keyway if you want or use the retaining ring as used by AndyMark.
Andy Brockway
Team 716, The Who'sCTEKS
Unread 31-05-2009, 13:57
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Gears for CIM
Just to add to this, a Letter O size drill or reamer measures 0.316", and that will work just fine too.
your thoughts on the FP CIM/2.5 CIM motor drive setup versus 2 2.5 CIM motors waialua359 Motors 11 14-12-2007 04:29
Gears for CIMs Brawler006 Motors 5 18-01-2004 09:46
Replacement for Bevel Gears? Greg Technical Discussion 3 30-03-2003 19:56
Spur Gears for Bosch and FP archiver 2001 11 24-06-2002 03:17
Gears for Chipuahs!!! dense Motors 2 16-01-2002 20:41
