Go to Post Start building your robot as soon as possible, but not sooner. - Richard Wallace [more]
Go Back   Chief Delphi > Technical > CAD > SolidWorks
Unread 01-06-2009, 00:53
Stuart's Avatar
Stuart Stuart is offline
#include coffee.h
FRC #1745 (P51- Mustangs)
Stuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond repute
Send a message via AIM to Stuart
Mastercam Gear/SolidWorks Gear Question
ok so at the end of each years season we ask the students what went good and what we could do better on. this year one of the things that they want to do better on is to use CAD software to help in the design and testing of the robot, not just as a way of getting a general layout of shapes, or CAMing out the few parts we do have machined.
for the past few years we have used the included mastercam Gear dll to make easy gears for the mill( it comes up with a wizard we fill in teeth and pitch and presto a gear). what I was wondering is how to make those gears in solid works, exactly as they appear in masterCAM.
if yall could steer me in the direction of a tutorial or a walk through that would help out alot.
I say solidworks because the team has a boat load of full licenses
Proud mentor of Team #1745 the P-51 Mustangs
If at first it doesn't work, use a hammer.
If that doesn't work, use a bigger hammer.
Unread 01-06-2009, 01:36
NickE's Avatar
NickE NickE is offline
_
Re: Mastercam Gear/SolidWorks Gear Question
I'm not very familiar with mastercam, but here's some ways to make gears in solidworks:
If your version of solidworks includes the solidworks toolbox, you can do it directly in there. Make sure you have the toolbox enabled (Tools>Add-Ins). Then, click on the tab in the right column that looks like a bar graph. Navigate to Gears (Toolbox>Ansi Inch>Power Transmission>Gears) and select the type you want. Drag it into your model and a configuration table will appear in the left column where you can configure the pitch, # of teeth, etc)
If you do not have the toolbox, you could use Design Table Parts. Attached are two that I put together a while ago. (Here's the hex one on 3dContent Central if you need a version for Solidworks 2007 or earlier) One has a hex broach and the other a keyway broach. You just open it up in solidworks and go to the "configurations" tab in the left column. Right click "Design Table" and open it. You can change the various properties (pitch diameter, # of teeth, bore size, etc) from there.
Keep in mind that for the purpose of general designing, it is often better just to extrude/revolve a disk of the pitch diameter in place of the gear. It is easier on your system resources and allows you to look at the model and make sure all your gears are tangent.
Unread 01-06-2009, 16:19
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
If you have Machinery's Handbook, you can sketch the profile of a single tooth on a sketch. Then you can use equations (for # of teeth, pitch, and pressure degree angle), and dynamically link those equations to key features in the tooth profile that would get modified by a change in teeth, pitch, or pressure degree angle. By simply changing the data in the equations and hitting Rebuild, you can have any spur gear in the world.
Art Dutra IV
世上无难事,只怕有心人.
Unread 06-06-2009, 07:46
mplanchard mplanchard is offline
Marie Planchard, SolidWorks
mplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond repute
In April 2009, "Mastercam® for SolidWorks" established an even stronger relationship between the CAD model and the machined part. Now you can program parts directly in SolidWorks, using toolpaths and machining strategies preferred the most by shops around the world. The Core of Your Machining Needs Mastercam for SolidWorks includes a suite of the most sought-after cutting strategies, including High Speed Machining (HSM) toolpaths. In addition, Mastercam for SolidWorks delivers a powerful set of automated toolpaths that get parts off the machine faster, with little or no handwork. You should contact your Mastercam rep for more details. Marie
Unread 06-06-2009, 21:28
R.C.'s Avatar
R.C. R.C. is online now
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Marie, I had a quick question. Does Mastercam For Solidworks work inside Solidworks 2009?
-rc
R.C.
MadTown Robotics Team 1323
Unread 07-06-2009, 01:06
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
-rc
Yes, but it's not simply MasterCAM inside Solidworks. It is a stripped down version of MasterCAM created explicitly for Solidworks. It does not have all the toolpaths and other features that a standalone license of MasterCAM contains.
From talking to the MasterCAM people at Westec about it the last two years, it's designed for people with minimal CAM experience who want to go straight from Solidworks to machined part with minimal input. Essentially it emphasizes convenience at the expense of customization.
2001-2004: Team 100
2006-Present: Team 254
Unread 07-06-2009, 01:29
Stuart's Avatar
#include coffee.h
that sounds GREAT . .
Unread 07-06-2009, 01:44
R.C.'s Avatar
Thanks Cory, I saw the launch of it and was wondering if it was worth it. I'll stick to my regular copy of MasterCAM then.
R.C.
AM Planetary Gearbox (removing the fisher price gear/buying one without a gear) Ice Berg General Forum 10 04-02-2009 15:43
MasterCam, Solidworks & CNC Help R.C. CAD 9 09-11-2008 23:03
gear question kevin.li.rit Technical Discussion 2 13-01-2007 19:40
Gear reduction question dmellich Motors 6 25-01-2003 08:54
motor high gear/low gear switch... archiver 2001 6 23-06-2002 23:50
