Go to Post Oh, the magic smoke will just make make it seem a bit more like Christmas. - CJO [more]
Unread 02-06-2009, 21:08
Happyisgood Happyisgood is offline
FRC #3161 (Tronic Titans)
Happyisgood is an unknown quantity at this point
Re: Wireless Router to Connect with Driver Station
Thanks for all the input. I'm actually afraid as anything to even hook up the cRIO for fear of breaking it or blowing it out in some way. I'm going to use a different router, but I'll be using the recommended bridge. Thanks for all your input.
Unread 03-06-2009, 07:46
If you are being serious, then I'd like to point that it will be difficult to build a robot without being able to connect things to the cRIO. The more you learn about how it works, the more comfortable you will be with it.
The good news is that the cRIO is pretty protected, and you can treat it like almost any other household electrical device -- no liquids, no metal shavings, don't stick things into outlets, etc.
Greg McKaskle
Unread 04-06-2009, 13:06
We're getting the cRIO to start working with tonight, we also put the purchace in for the driverstation and some breakers for the PDBoard. We're buying the wireless bridge from TigerDirect. Any clue why nobody's selling the bridge anymore? Thanks for the advice about the cRIO, we know how to use it, but it's going to be a fun learning curve for me in the way of programming. Anybody have any suggestions of some idiot-proof tutorials on LabVIEW for FRC?
By the way, for reference, I'm going to use last years AirPORT Extreme Base Station as my router, the Linksys Bridge as my wireless and a Toshiba Satelite as the main computer.
Unread 04-06-2009, 13:15
Russ Beavis Russ Beavis is offline
Russ Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond repute
For LabVIEW training, check out http://www.ni.com/first. Also, I've heard nothing but great comments about http://www.lvmastery.com.
Russ
Power Driver Station with Serial pyr0b0y Technical Discussion 6 30-04-2009 19:53
Problems with driver station gyaniv FRC Control System 2 13-02-2009 01:21
Use of Wireless Router Andrew Lindsay Rules/Strategy 3 12-01-2009 14:17
Timing with the Driver Station Zorkinian Programming 6 10-01-2009 09:42
Wireless Router Issues zim2411 Scouting 17 09-04-2008 22:24
