Go to Post Seriously, when I grow up (or if I grow up) I want to be just like Al. - Paul Copioli [more]
Unread 04-06-2009, 08:46
Andrew Schuetze's Avatar
Andrew Schuetze Andrew Schuetze is offline
499 Founder / Alamo FTC & FLL AP
Andrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond repute
Re: Vex Controller with FRC Robot
We haven't finished the voltage regulator work yet that was suggested by another poster and need to tidy up the wiring but our 2005 FRC robot which was later redesigned to shoot tee shirts underwent a two day conversion to a VEX controller after World Champions this year. You can see it throwing out the first pitch in CD-Media. Victor speed controllers wire up directly to the VEX controller but one needs to make a custom PWM cable for the spikes as these have two signal wires and a ground and draw power from the device power supply. (meaning the +12 from the power distribution)
So if you have spikes you will need to need to wire custom versions going from one connection to two. Does this make sense
APS
Founder FRC 499
Parent alumni FRC 2745 & 4219
Co-Coach FTC 4549 & 6407
Alamo FTC Affiliate Partner
Alamo FLL Affiliate Partner
help with Operator Interface and FRC robot Controller RoarRoar Control System 16 22-04-2008 09:51
Vex Motor Help with FRC Robot professorX Motors 2 13-03-2008 15:19
FRC Robot Controller Broke animemanga197 Kit & Additional Hardware 6 02-02-2008 18:12
FRC Robot Controller/Speed Controller RoarRoar Control System 3 17-01-2008 10:41
Using a spike with a VEX controller? AdamHeard VEX 2 20-11-2007 10:26
