Go to Post Besides, if you look back on anything you've already made and can't find any flaws that can be improved, you're doing it wrong. - artdutra04 [more]
Go Back   Chief Delphi > Technical > IT / Communications > Website Design/Showcase
Unread 04-06-2009, 02:30
stevenngo stevenngo is offline
FRC #2761
stevenngo is an unknown quantity at this point
Site Design
Hi everyone, I was wondering what program you all use for your websites? And if someone can help me explain the concept behind drupal. Thanks, mucho appreciated
Unread 04-06-2009, 04:32
JohnBoucher JohnBoucher is offline
Blue Shirt
FRC #0237
JohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond repute
Re: Site Design
Drupal is a very powerful CMS (Content Management System). It is a framework that takes care of all the background mechanics of a website and allows you to concentrate on content building.
Drupal is open source, so there is a very large community of users that share designs and modules. There are many online tutorials and demos.
Zappos.com is powered by Drupal.
The downside to any CMS is that the tend to be targeted by link spammers and hackers. Both the good guys and the bad guys have access to the source code. You must keep the code up to date. Don't rely on your host to do it, you need to stay on top of it.
Drupal has a steep learning curve. It can be frustrating to use, until you get used to it. There are many CMS's available. Wordpress, Moveable type, etc
This discussion from WebmasterWorld may help you decide on using Drupal.
Unread 04-06-2009, 10:45
Burmeister #279's Avatar
Burmeister #279 Burmeister #279 is offline
What Time Is It?
AKA: Nick Burmeister
FRC #0279 (TechFusion)
Burmeister #279 is a glorious beacon of lightBurmeister #279 is a glorious beacon of lightBurmeister #279 is a glorious beacon of lightBurmeister #279 is a glorious beacon of lightBurmeister #279 is a glorious beacon of lightBurmeister #279 is a glorious beacon of light
Send a message via AIM to Burmeister #279
Re: Site Design
My team uses Notepad and MSPaint with Filezilla for the server stuff =)
However bad our site looks now, the web team is learning html, css, php, and javascript instead of downloading a template or running a program to do it. I personally like Notepad++ because its open-source and has multiple languages and syntax highlighting.
WHAT TIME IS IT? TWO SEVEN NINE!!! [Team B =) ] Awards: 4 Safety, 2 Ind. Design, 2 Xerox, 1 Nat. Champs
2009 Buckeye Semi-Finalists (1014 & 695) || 2008 GLR Safety Award || 2006 GLR Safety Award
2005 Buckeye Regional Champs (67 & 274) & GM Industrial Design Award & Safety Award GLR Quarter Finalist & Xerox Creativity Award & Safety Award National Xerox Creativity Award & Curie Quarter Finalist (1126 & 180)
2004 Buckeye Delphi Driving Tomorrows Technology Award & Quarter Finalist GLR Champs Nationals Curie Division Finalist
2003 GLR GM Industrial Design Award || 2001 National Newton Division Winner & National Champions
2000 MI DaimlerChrysler Team Spirit Award
Unread 04-06-2009, 11:04
Joining the 900 Meme Team
FRC #0079
Re: Site Design
As with everything it depends on what you want it to do and how hard you want to work.
Some people insist on using Notepad, other people install a CMS, yet others use hosted services such as tumblr. Obviously if you want ABSOLUTE control over every aspect you should code the whole site from scratch using notepad or notepad ++ (or any plain text editor) If you just want to have a site up and running and be able to update it without worrying about how I would use either a hosted service or one of the aforementioned CMS.
As for me, I use Visual Studio at work, we do a lot of vbscript (Im actually sad to admit that) At home I use Textmate (very nice Mac text editor) and am trying to learn how to do asp.net and c# using Visual Studio.
Don't be intimidated by people saying that REAL programmers use notepad (or butterflies) A REAL programmer uses the tool which allows them to most efficiently achieve their goals. The first step is defining your goals, do you want a site up quickly and easily? Do you want to learn how the tools work?
Unread 04-06-2009, 17:12
What Time Is It?
Re: Site Design
I agree with Andrew here. Do what fits you best: try out as many options as possible and pick what works. there's been several threads on web tools, feel free to use the search function on the forums.
Unread 04-06-2009, 18:02
Vpr99's Avatar
Vpr99 Vpr99 is offline
Not quite a person... yet
AKA: Eric Skram
FRC #0159 (Alpine Robotics)
Team Role: Webmaster
Vpr99 is an unknown quantity at this point
Send a message via MSN to Vpr99
Re: Site Design
What you should use to design and implement your website really depends on
a. The type of site you want
If you want to create your site 100% from scratch (which is a ton of work) I would recommend using the Adobe design suite (if you have money to burn) or otherwise, use Burnmeister's setup of M$ Paint and Notepad.
However, if you want to expend a significantly less amount of effort & time, I would recommend a CMS. Some of the big ones are Drupal, like you mentioned, and Wordpress, which I would recommend. These CMS sites are relatively customizable, but not near the extent that a fully custom site is.
b. (and this is a big one) How much time you are willing to spend
As a general rule, CMS sites take much less time and effort to maintain and create than a site that you made yourself. CMS's tend to facilitate the updating and creating process for you.
Also, I would not recommend tackling any kind of website project without a team of people to help you. This year, I did about 95% of a completely new site by myself, and it just about killed me. I spent probably 300-400 hours on our site, and that was just to get it up and running, not counting updates.
Hope this was helpful
-Eric, 159
Unread 05-06-2009, 08:39
NalaTI NalaTI is offline
AKA: Alan
FTC #2848 (Techno Guards)
NalaTI is just really niceNalaTI is just really niceNalaTI is just really niceNalaTI is just really nice
Re: Site Design
The best thing about a decent CMS (like Drupal or Joomla) is that it is substantially easy to give multiple people access to various different parts and pieces. And enabling or disabling a feature on the site is usually a matter of a click or two.
For instance perhaps you only want Developers to format the site, but you want Mentors and Team Members to have be able to create content, and you want Moderators to be able to edit everyone's posts, while simultaneously havng both private and public blogs and portions... Writing that is a pain from scratch, but in Drupal takes me about a day and a half to set up a new site from scratch.
We use Drupal on multiple sites. The FTC site (http://www.technoguards.org) is the least advanced of them, but we only have three members. We are able to use the blog feature of Drupal, and taxonomy (categories) to completely set up our engineering notebook. It is all done online. The only time we use paper is when we print it out for competition.
The most advanced is actually the FLL team's (http://www.legoguards.net) because we have different privileges for team members, mentors, parents, webmaster, etc. Plus we have multiple blogs that are only available to team members and above.
Unread 05-06-2009, 09:54
Foster Foster is offline
Engineering Program Management
VRC #8081 (STEMRobotics)
Foster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond repute
Re: Site Design
Our prior site was PHP based and has a pretty decent blog attachment to it.
We are moving to a wiki based (using mediawiki) site for a number of reasons:
  1. Websites are 10% look and 90% content. There was a huge effort to get the look right in the past that took away from getting content in.
  2. Anyone on our team can add and edit content. They don't need to have any PHP experience. The wiki markup is much easier.
  3. Page linking is easy. It's very easy for us to decide to add a cross link to another page and in seconds to have it done
  4. For free we get links at the top of pages to sections that follower farther down in the page.
  5. Free searching. Want to know about drive trains, just put drive train in the search box
  6. We get forward / back link checking, we can see what pages link to others, and what pages have been ophaned.
  7. Anyone can enter content. Yes this is here twice but we are planning that all of the sub-component groups (drive,game,electrical,programming, etc) to update every few days in the build season. The wiki makes it easy for multiple preople to edit the same page.
  8. If we decide to change the look and feel then the wiki "skin" takes care of that, I don't need to worry about custom PHP code or CSS code someone may have put on one of their pages.
Granted all of the above points can be managed in a CMS based site, but there is more administrative work that needs to be done.
Foster
Foster - VEX Delaware - 17 teams -- Chief Roboteer STEMRobotics.org
2010 - Mentor of the Year - VEX Clean Sweep World Championship
2006-2016, a decade of doing VEX, time really flies while having fun
Downingtown Area Robotics Web site and VEXMen Team Site come see what we can do for you.
Unread 05-06-2009, 20:15
likzuz's Avatar
likzuz likzuz is offline
AKA: Nat
FRC #1710 (Ravonics Revolution)
likzuz will become famous soon enough
Re: Site Design
Our school is an Engineering/Design school and as such we have access to Adobe CS3. So when we built our website it was a combination of Dreamweaver CS3, Illustrator and Photoshop.
If you don't have access to Adobe products a great alternative is Notepad (like everyone else has said) but instead of MS paint you can use Gimp http://www.gimp.org/
Gimp is attempts to be a freeware version of photoshop. Granted it's not the best but it's great for what you pay for (nothing!).
Team 1710 Ravonics Revolution
Unread 05-06-2009, 21:16
FIRSTgirl675's Avatar
FIRSTgirl675 FIRSTgirl675 is offline
AKA: Stephanie
FRC #0675 (Tech High Robotics)
FIRSTgirl675 will become famous soon enoughFIRSTgirl675 will become famous soon enough
Re: Site Design
I believe that my team uses DreamWeaver.
Unread 06-06-2009, 05:25
AKA: Alan
Re: Site Design
There's a free plugin for Gimp called "Gimpshop" (you can google it) and it skins gimp so it has the same interface as Photoshop (not CS3, but a previous version).
Also, an inexpensive (but not free) program that is really good for web-type graphics development is Paint Shop Pro - IMHO it's the best for the money option.
Unread 07-06-2009, 13:46
What Time Is It?
Re: Site Design
The Aviary at a.viary.com is also a low cost photoshop alternative and includes a swatch maker, vector editor among other in-dev. products. its really cool, although its more towards daily users not one-time or short-time image editors.
of course all of the free(or cheap)ware tools can be just as good as any other and it depends on the user.
Unread 07-06-2009, 16:17
Chris is me's Avatar
AKA: Pinecone
Re: Site Design
Several team sites are done in Wordpress. While technically a blog engine rather than a CMS, the Static Pages feature is adequate for most people's needs, and it's a very powerful blogging tool. It's extendable with plugins and themes, allowing for lots of customization and features, completely free, and you can edit any page from any web browser if you have an account for it. I'm making a prototype site in Wordpress to replace my team's current Frontpage format.
Unread 07-06-2009, 19:58
elemental elemental is offline
DAAP Slapped
AKA: Erin
elemental is a glorious beacon of lightelemental is a glorious beacon of lightelemental is a glorious beacon of lightelemental is a glorious beacon of lightelemental is a glorious beacon of lightelemental is a glorious beacon of light
Re: Site Design
Another photoshop alternative is a souped-up version of MSPaint called Paint.NET It's pretty nice and hasn't given me any trouble.get
Unread 15-06-2009, 12:15
Ranana_Prussy's Avatar
Ranana_Prussy Ranana_Prussy is offline
Ranana_Prussy is an unknown quantity at this point
Site Design
Hi there,
I think the background of your site is good the color and design is also nice. If you give red color on top it will look more better.
[Official 2008 Game Design] OK, so YOU design the 2009 game... dlavery FRC Game Design 69 23-08-2009 19:54
Question regarding Web-site Design Deadline rsegrest Website Design/Showcase 3 10-02-2009 14:38
[Official 2008 Game Design] OK, so YOU design the 2008 game... dlavery FRC Game Design 25 20-02-2008 23:31
FIRST Team 1444 Site Design for 2008 Compnerd Website Design/Showcase 13 25-03-2007 23:55
[Official 2006 Game Design] OK, so YOU design the 2006 game... dlavery FRC Game Design 29 08-01-2006 00:21
