Go to Post Holy cow! Five years in FIRST and it only gets better! Skyway has supplied wheels to FIRST for ten years. Ten years ago Dean called Ken for wheels. Ken said yes. Man, we love helping you guys and gals get good wheels. ;) Bart at Skywaywheels.com - SkywayWheels [more]
Unread 06-06-2009, 13:28
Doug Leppard's Avatar
Doug Leppard Doug Leppard is offline
FRC #1902 (Exploding Bacon)
Doug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond repute
Send a message via AIM to Doug Leppard
EasyC Pro updating libraries
Importing libraries in easyc pro is easy. BUT if you change a library how to you update that library in all the projects you use it in?
When you try to import that library again it says it has duplicates. Is there a way to import a library you are using with new updates in it?
You can delete existing functions that library uses, but that is a mess because of the dependencies etc.
Thanks
Doug Leppard
Unread 07-06-2009, 09:00
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
Re: EasyC Pro updating libraries
Doug, the best bet currently is to create a new project. Then import the functions from your previous existing program using "Add Existing Function". A easyC library will import multiple functions and variables that would be difficult to keep track of and update. These imported features are not protected so the variable or function could have been modified.
Unread 07-06-2009, 09:12
Basically that is what I decided, good to have someone confirm it.
I am generating a "base" library with all my various functions and import from that.
I do wish they had real libray that could be linked, oh well still a good product especially for a part time programmer.
Doug Leppard
Math in EasyC pro TonyP Programming 1 04-02-2008 09:57
EasyC Pro Programming? Gizmo2417 General Forum 6 04-02-2008 01:08
MS Vista/EasyC & EasyC Pro rswsmay Programming 1 25-04-2007 10:47
easyC PRO contest Brandon Martus Announcements 0 01-02-2007 11:57
