Go to Post FIRST is all about helping eachother and team work, isn't it? - vadyr [more]
Unread 08-06-2009, 00:45
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
pic: EWCP Wheel 5"x1"
Unread 08-06-2009, 00:48
steelerborn's Avatar
steelerborn steelerborn is offline
Engineer at JBT FoodTech
AKA: Jonathan Stokes
FRC #5817 (Uni-Rex)
steelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant future
Re: pic: EWCP Wheel 5"x1"
Yeah that looks pretty slick right there.
What are your guys plans in the off season.
We're thinking of doing a bit of prototyping of some new ideas.
If you guys ever need anything just contact us.
We should get together as teams over the summer and discuss ideas at some point too.
Unread 08-06-2009, 01:57
Andy L's Avatar
Andy L Andy L is offline
FRC #1458
Andy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud of
Send a message via AIM to Andy L
I'd question if the outer spokes could handle a side hit if on carpet
Unread 08-06-2009, 02:40
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
At a glance, I'd think so. There's 9 of them, and roughly speaking there seems to be enough mass in the wheel for its size. Also, the spokes aren't super long, since the hub diameter is rather large. What's the thickness on the spokes?
If you really wanted to answer that question with some certainty, it'd be easy enough to run a quick ANSYS or COSMOS simulation on it.
I'm assuming the material is 6061 Aluminum?
Unread 08-06-2009, 02:53
R.C.'s Avatar
I haven't ran COSMOS on it yet, but I will soon. As for the spokes, they are 1/4 inch thick.
R.C.
MadTown Robotics Team 1323
Unread 08-06-2009, 02:56
NickE's Avatar
NickE NickE is offline
_
You could probably go thinner if you want to save more weight. Those wheels look pretty nice. I like the simplicity.
The stepped pockets on the spokes are an interesting touch. I would probably remove them from the inner pockets (although those could be structural, I suppose). They're a nice touch on the outer pockets. I'd be interested in seeing the outer pockets without any steps for comparison.
Unread 08-06-2009, 14:49
I still like my red rendering better
http://s656.photobucket.com/albums/u...inchwheel1.jpg
Unread 08-06-2009, 15:11
CraigHickman
Posts: n/a
Suggestion for CNC speed improvement: The inner pockets between the bolt holes could be moved out and included into the profile (making the center hub shaped sort of like a Dog from a shifter) of the Hub, which would cut down on cutting time. It takes more time to pull out of a cut, move over to somewhere, and plunge a new hole then it does to simply keep cutting across with a slightly longer cut line.
Just food for thought.
Unread 08-06-2009, 16:58
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
See if you can make them look like these wheels
They might be worth money one day
Unread 10-06-2009, 01:21
Mr. Forbes I absolutely love funny cars.
That actually would be a cool thing to do with enough time and proper machines. Maybe a small diameter 4" wide wheel is in order.
pic: EWCP Founders Akash Rastogi Extra Discussion 5 26-04-2009 19:08
pic: Pic 2: "caster wheel" crab drive combo adengler Extra Discussion 7 27-01-2009 21:14
pic: Pic 1: "caster wheel" crab drive combo adengler Extra Discussion 1 25-01-2009 17:44
Lowered Center Wheel for 6 wheel drive 987HighRoller Technical Discussion 37 17-01-2007 01:21
pic: Chantilly Academy's 4 Wheel Drive 4 Wheel Steering!!!! jskene Robot Showcase 25 18-02-2005 20:24
