Re: Team 2338 swerve drive peer review
Hey, team 2158 is doing the same summer project! To cut down on weight and price, we're making our modules out of 3/8" Lexan, if it helps at all. Aluminum should be comparable to both price and weight, though, so stick with what you're team is comfortable doing. You're right, the main expense is coming from the 90* gearbox. We haven't really been able to find a way around that other than building a custom one, but since we don't have any machining tools, that would end up being much less stable. If you feel confident enough, you could find some set-screw-on bevel gears and align them yourself, which should save you quite a bit of money. Good luck!
| pic: Team 1535 Peer Awards | JakeC | Extra Discussion | 9 | 06-03-2009 22:50 |
| team 2338 robot | Creator Mat | Robot Showcase | 1 | 18-02-2009 18:09 |
| pic: Team 108 - LEGO swerve drive | zander_108 | Extra Discussion | 8 | 10-04-2007 22:36 |
| Setting up a peer-to-peer network | Michael Hill | IT / Communications | 7 | 26-07-2006 20:29 |
| Team 312: HeatWave multispeed swerve drive | Stephen Kowski | Robot Showcase | 10 | 08-03-2006 23:48 |
