Go to Post Do what you do well and I'm sure there will be much hope in your future! - Collmandoman [more]
Unread 14-06-2009, 13:04
rajv23 rajv23 is offline
FRC #1515
rajv23 is an unknown quantity at this point
Re: What programming language do you use?
Originally Posted by Andrew Schreiber View Post
It depends on the application, plus asking here what languages we use is sure to get a range of responses ranging from Assembly to Visual Basic (couldn't come up with a language that ended in Z)
Personally I use whatever language is best suited for the application. I wouldn't use C to do lots of string manipulation, I would use Python (Ive heard great things about Perl too but never used it) If I were writing web pages I wouldnt use Haskell (though someone DID) I would use HTML, PHP or ASP.Net. My question is, what sort of application are you working on, how would we use it?
Oh and my personal favorite language, C. I enjoy working in it despite it not being the simplest of languages to learn.
It's for a website. I am in a dilemma between using PHP or Ruby on Rails. While Ruby on Rails will be easier to teach to my team, I am a better coder at PHP and it is generally just a more popular language. If there is a significant number on chief delphi that uses ruby, then I might consider using it for the web applacation.
What programming environment do you use? SL8 Programming 28 23-03-2008 20:46
What language do you use? 1strobotixrox Programming 54 29-01-2007 02:18
What programming environment did you use? StevenB Programming 10 18-03-2006 09:32
What kind of computer do you use for programming? Rohan_DHS Programming 21 05-01-2006 11:52
