Go to Post You don't always get what you pay for, but you hardly ever get what you don't pay for. - MrForbes [more]
Thread Tools Rating: Thread Rating: 2 votes, 4.50 average. Display Modes
Unread 17-06-2009, 17:30
byteit101's Avatar
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
Re: Recording with the Camera
We were able to save video from the camera to the crio's 2GBish drive, and then copy it to a computer and assemble it into a avi on a laptop. in the code we used imaqSaveImage or imaqWriteImage (look in nivision.h) to save to a folder, and just ftp'ed to ftp://10.xx.yy.2/ and copied it off after matches. we used a simple C# program that i wrote to play it back, and vidshot capture to save it to avi. here are some of ours:
http://thecatattack.org/VOB/Practice...ilermaker2009/
http://thecatattack.org/VOB/Match4Boilermaker2009/
Watchdog.Kill();
Unread 05-07-2009, 00:18
biojae's Avatar
biojae biojae is offline
Likes Omni drives :)
AKA: Justin Stocking
FTC #5011 (BOT SQUAD) && FTC#72(Garage bots)&& FRC#0399 (Eagle Robotics)
biojae is a jewel in the roughbiojae is a jewel in the roughbiojae is a jewel in the rough
Lightbulb Re: Recording with the Camera
you can make the videos directly on the cRio
(it probably takes more space to store though)
AVISession imaqCreateAVI(const char* fileName, const char* compressionFilter, int quality, unsigned int framesPerSecond, unsigned int maxDataSize);
int imaqWriteAVIFrame(Image* image, AVISession session, const void* data, unsigned int dataLength);
int imaqCloseAVI(AVISession session);
FTC Team 72 - No site
FRC Team 399 - http://www.team399.org
2010 Rockwell Collins Innovation in Control Award - (Use of the CAN bus, among other reasons) Phoenix, Arizona!
Unread 05-07-2009, 01:08
I think you will find that the AVI functions are documented for IMAQ in general, and they are in the header file as well, but they will not work on a nonWindows OS. I'm not sure if you will get a runtime error or a compiler error.
Greg McKaskle
Unread 06-07-2009, 01:04
biojae's Avatar
Cool Re: Recording with the Camera
Greg McKaskle
well, i will try it out on saturday then, (my team doesn't really do offseason robot work and thats the only time that i will have with the robot until IRI), i would imagine that it would at least compile if its in the header file.
just throwing around ideas, as i have enough time to sift through the huge NIvision.h
(Really 200 defines, 150 typedefs and 50 functions in 1 file )
i think NI should refactor that thing
i did have ours take pictures when a button was pushed on the joystick though
(image taken at LA regional during camera calibration time)
Unread 06-07-2009, 14:14
byteit101's Avatar
we tried that, and it does not work.
http://decibel.ni.com/content/thread/2473?tstart=30
This may be due to these functions not be expected to be used by FIRST teams (all of the standard FIRST Vision functions use JPEGs), and therefore are not found in the headerfile. This being said I will double check with R&D to see if this is the case.
Cheers,
Mark
NI FIRST Support
Also, I'm not sure how it works, but it maybe choppy, even if it did work, say you get 3 images in 10ms, then it slows down and the next 3 images are taken over 30ms. we compensated this by saving the images as picnumb auto/telop enable/disable timestamp cameraCapt.jpg (ex. 05 ae 128963 cameraCapt.jpg) and used the timestamp's to set the delay for the next photo. before we did this, we had it play at the average speed, fixed at 16ms, and you can see it slow down, and then speed back up.
Watchdog.Kill();
Unread 06-07-2009, 18:18
The AVI stuff will work on a desktop development computer running Windows. It will not work on the PPC cRIO running vxWorks.
The second part about choppy is valid, but the times listed aren't. The camera will not return images faster than one every 33ms, and even that is dependent upon the lighting, size, etc.
I'm not that knowledgeable of codecs for video encoding. Ideally, you'd select one that allows for arbitrary timings on the frames. I'm not sure which support that.
Greg McKaskle
Help with the camera frcchile NI LabVIEW 5 11-02-2009 20:20
PROBLEMS WITH THE CAMERA RDD Programming 2 18-02-2007 15:12
problems mounting the camera to the 'bot with the default servo/mount set up Redneck Programming 0 16-02-2005 20:53
I need help with the camera WesleyBalmer Programming 7 15-01-2005 17:25
Problem with recording, help Animentor 3D Animation and Competition 2 22-01-2003 18:21
