Go to Post Look at 71's 'walking' bot from last year. One dosn't need wheels/track to move. All you need is an idea. - Jack [more]
Thread Tools Rating: Thread Rating: 10 votes, 5.00 average. Display Modes
Unread 18-06-2009, 08:24
Andrew Schuetze's Avatar
Andrew Schuetze Andrew Schuetze is offline
499 Founder / Alamo FTC & FLL AP
Andrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond repute
pic: cRIO CAN Jag
Unread 18-06-2009, 08:25
Jared Russell's Avatar
Taking a year (mostly) off
Re: pic: cRIO CAN Jag
Very cool. I'm crossing my fingers that this is a "go" for 2010...
Unread 18-06-2009, 08:47
Uberbots's Avatar
Uberbots Uberbots is offline
Mad Programmer
AKA: Billy Sisson
FRC #1124 (ÜberBots)
Uberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond repute
I like how they just left the head of the cable in the last jag (:
Thats really cool. daisy chained jag's look intimidating without those silly 3-color wires coming out of them.
A few of my favorite numbers:
175 176 177 195 230 558 716 1024 1071 1592 1784 1816
RPI 2012
BREAKAWAY
Unread 18-06-2009, 08:52
Does the idea of having (potentially) all of your speed controllers in series scare anybody else?
One would assume that the CAN pass through circuitry is sufficiently removed from the motor driver so that even a "blown" Jag wouldn't bring down the entire network. Even if that is the case it seems like this configuration could lead to a really tough time debugging your electrical system.
Unread 18-06-2009, 09:15
Look at it closely. I'm pretty sure that's a termination resistor, something typically used to suppress signal reflections at the end of a high-speed bus like CAN.
Unread 18-06-2009, 09:42
Eh, not really. CAN is reasonably fault tolerant. I'd be more afraid of a cable coming out or a device on the bus going "babbling idiot mode" than one Jaguar electrically disabling others.
Quoted for Truth. Standard CAN usually has 120 Ohm termination resistors on either end of the bus.
Unread 18-06-2009, 10:13
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
THe only thing that worries me is all those RJ45 connectors in series.....you saw what happened to similar connectors on the DS this year when used in a competitive environment.
Unread 18-06-2009, 10:22
Nick Lawrence's Avatar
Nick Lawrence Nick Lawrence is offline
Commander Canada
FRC #3940 (CyberTooth, AndyMark)
Nick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond repute
Well, ideally your electronics would be in a low impact area on your robot, right?
-Nick
Alumnus of 1503 Spartonics
Founding Mentor of 5406 Celt-X
Mechanical Design Mentor of 3940 CyberTooth
Emceeing events since 2013 - come say hi!
Success doesn't always equate to match wins. It's about the wins off the field.
Unread 18-06-2009, 10:27
MrForbes's Avatar
AKA: Jim
Yeah, right
Unread 18-06-2009, 10:28
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
-Nick
Finding a low impact area is difficult to do in the situation where a 150lb robot going 12fps slams into your bot.
If anything we can do the clear nail polish thing again. It worked wonders on the IFI PWMs and it still works great on my R/C car.
GitHub
Unread 18-06-2009, 10:31
MrForbes's Avatar
AKA: Jim
Unfortunately the RJ series connectors are inherently flaky....
Unread 18-06-2009, 10:49
Please don't assume that because KwikByte chose to use an unacceptably inferior component that TI/Luminary did as well. RJ connectors come in many forms and many quality levels. If you squeeze cost out hard enough, any component can become a failure point.
Unread 18-06-2009, 12:14
R.C.'s Avatar
R.C. R.C. is online now
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
In my opinion, I hope they release the module before season so we have a few week to play with it. Even though none of our pwm's ever came out, I personally would feel better if we used CAN.
-RC
R.C.
MadTown Robotics Team 1323
Unread 18-06-2009, 12:43
What I like about CAN is removal of several PWM wires all traveling the same path and having to check which pin number it was in and verifying correct orientation on both ends several times during the build when things would get disassembled and reassembled. With CAN, 1 RJ45 cable from the cRIO from just the CAN bumper to the first device and then daisy chain from there. No need to verify orientation and keep the log of which pin to which device ... all that is in the code and addressing log.
How many times did your robot temporarily lose functionality after a re-build because a PWM was not inserted into the correct pin ...
APS
Founder FRC 499
Parent alumni FRC 2745 & 4219
Co-Coach FTC 4549 & 6407
Alamo FTC Affiliate Partner
Alamo FLL Affiliate Partner
Unread 18-06-2009, 12:50
MrForbes's Avatar
AKA: Jim
Unfortunately, cost seems to be the primary design consideration for the RJ series since it's inception decades ago.
Hopefully Luminary has figured out how to make the system reliable....but my long experience with the connector series isn't good.
Failed attempt to explain JAG linearity vamfun Technical Discussion 66 05-06-2009 13:13
2009 Camera and Jag inventor models problem Creator Mat CAD 5 08-03-2009 14:05
1 Jag and 1 Victor not responding correctly. elbuo NI LabVIEW 4 17-02-2009 22:57
How can you add more rom space to the cRIO? Comatose FRC Control System 8 05-02-2009 21:16
