Go to Post A stack is a stack is a stack. (How Profound!) - Paul Copioli [more]
Thread Tools Rating: Thread Rating: 10 votes, 5.00 average. Display Modes
Unread 19-06-2009, 18:20
skimoose's Avatar
skimoose skimoose is offline
Parent/Mentor/Engineer
AKA: Arthur Dutra
FRC #0228 (GUS)
Team Role: Electrical
skimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond repute
Re: pic: cRIO CAN Jag
Considering that in most cases you'll be plugging in your CAN bus only once when you wire your robot, I don't see a concern with the RJ series connectors. Your land line telephones are also connected with RJ series connectors and they also take a fair amount of abuse, their connections have a fairly low failure rate in that environment as well as in network systems.
As a model railroader, we use a similar connection for our data bus standards for digital command control with very few problems. It should work well.
All I can say to FIRST is... "When CAN we play?"
2009 CT Regional Motorola Quality Award
2010 VRC Connecticut Championship Winners & Amaze Award
2010 VRC Championship Divisional Energy Award
2010 WPI Regional Winner
2010 WPI Regional Engineering Inspiration Award
2011 WPI Regional Chairman's Award
2012 WPI Regional Finalists
Failed attempt to explain JAG linearity vamfun Technical Discussion 66 05-06-2009 13:13
2009 Camera and Jag inventor models problem Creator Mat CAD 5 08-03-2009 14:05
1 Jag and 1 Victor not responding correctly. elbuo NI LabVIEW 4 17-02-2009 22:57
How can you add more rom space to the cRIO? Comatose FRC Control System 8 05-02-2009 21:16
