Go to Post Yes, a big part of FIRST is learning from others. But a just as important part of FIRST is learning from discovery. - [more]
Unread 18-06-2009, 02:04
kajeevan kajeevan is offline
FRC #0188 (blizzard)
kajeevan has much to be proud ofkajeevan has much to be proud ofkajeevan has much to be proud ofkajeevan has much to be proud ofkajeevan has much to be proud ofkajeevan has much to be proud ofkajeevan has much to be proud ofkajeevan has much to be proud ofkajeevan has much to be proud of
pic: Prototype 6WD
Unread 18-06-2009, 02:05
Jon Jack's Avatar
Jon Jack Jon Jack is offline
VEX Robotics
no team (No Team)
Jon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond repute
Send a message via AIM to Jon Jack
Re: pic: Prototype 6WD
I can't see clearly, but why are your gearboxes offset from the center wheel? How are you running your chain?
Team 1538 / The Holy Cows, 2005-2016
Unread 18-06-2009, 02:18
NickE's Avatar
NickE NickE is offline
_
It looks like a direct driven center wheel to me. The final gear reduction is hard to see (Looks like a supershifter using standoffs instead of the stock extruded body).
Unread 18-06-2009, 10:37
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
I love the use of U-channel, however usually U-Channel is weaker at the bends than C-channel. This would worry me on the outside rails on a high-impact carpet game. To keep the frame stiff, I would use C-channel on the inside (usually for those dimensions you can only find 3" base with 1.5" legs or a 4" base with 2" legs and both have a ~3/16" radius on the inside corners of the bend) and 2x1" or 3x1" box extrusion on the outside. It's roughly the same weight, stiffer, and much stronger on the outside. Possibly a little more expensive depending on the supplier. For a prototype this looks good!
GitHub
Unread 18-06-2009, 10:43
AM SS steel hex driven direct drive
42lbs w/no lighting
should take one day to build
can use 25/35 chain
tensioners are floaters
wheels are CNC baltic birch used in every 188 drive train
AM bearing hubs/hex hubs/sprockets/spacers
Unread 18-06-2009, 20:16
Jon Jack's Avatar
VEX Robotics
no team (No Team)
Okay, I see now. I couldn't tell if that was a SS or not.
Unread 19-06-2009, 11:41
Andrew Remmers's Avatar
Andrew Remmers Andrew Remmers is offline
AKA: Andrew Remmers
Andrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond repute
Send a message via AIM to Andrew Remmers
still looks really cool tho great jon
Unread 19-06-2009, 11:43
AKA: Andrew Remmers
job*
Unread 21-06-2009, 12:38
Cyberphil's Avatar
Cyberphil Cyberphil is offline
That Guy
AKA: Phil
FRC #0103 (Cybersonics)
Cyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud of
Send a message via AIM to Cyberphil
Let me just say this. I will warn you about chains right now. There are a lot more problems that chains will have rather than gears. I will suggest you use gears before you go too headlong into chains. Ask team 79. They could have won in Florida if their chains didn't break.
Unread 21-06-2009, 13:25
Joining the 900 Meme Team
FRC #0079
Properly aligned and tensioned chain should NOT break under FRC loads. I know many teams have been using #25 chain for years without problems. If you feel uncomfortable using #25 chain feel free to use the heavier #35 because it will allow you to be lazy when you are tensioning and aligning.
Unread 21-06-2009, 13:30
ATannahill ATannahill is offline
AKA: Alex Tannahill
The chain did not break, it came off the gear. We added some metal to our lexan to preven vibration, this was on our manipulator, not the drivetrain.
- Arizona North
Unread 21-06-2009, 14:08
Actually most teams who switch to just gears: you guys, 25, 1403, some more, tried chain first just like the rest of us.
Yes chain has its problems and gears sometimes have their benefits in a DT, but when the design is based on good tensioning and weight is considered their priority you can't go wrong with chain.
We were happy not to have any chain in our drive train this year too though But I wouldn't necessarily bypass chain, especially when its a veteran team like Blizzard.
Unread 21-06-2009, 15:20
188 has a very reliable gear drive like 25 which has never broken once during competition the 2yrs we have used it but some of us think if we had more weight like 10-15lbs we could have built a much better function. I m hoping that the mentors will allow me to build and then break it thru tests to find the breaking point of the 25 chain vs the 35 in FIRST scenarios and see if anything else breaks over an extended period. Also to figure out if floaters are good enough to tension the chain and such.
Unread 21-06-2009, 15:44
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
There is absolutely no reason that a team should be worried about using either #25 or #35 chain on a FIRST drivetrain as long as simple precautions are taken such as proper alignment and tensioning. If the chain is taut and completely aligned there will not be any problems with it breaking. Additionally, it is much more difficult to machine a drivetrain to use gears versus chain and the gears will be much heavier.
Mentor 2415
Unread 21-06-2009, 19:24
Aren_Hill's Avatar
Build Nifty Things
08 swerve, 8 runs of #25 chain, how many issues we had with them? 0
if you simply pay attention and take care when aligning and tensioning it, it will not go anywhere on you. (1 of those runs was holding back several hundred lbs of surgical tubing)
btw this is biohazard a former world champion battlebot i believe
and it uses #25 chain for the drive
http://www.botshop.150m.com/Biohazard.jpg
A guy who likes robots.
pic: FRC1293 Prototype 6wd Chassis Thermal Extra Discussion 16 06-01-2009 23:12
pic: 6wd prototype chassis Collin Buchan Extra Discussion 7 03-01-2009 10:00
pic: 6wd prototype chassis Collin Buchan Extra Discussion 3 02-01-2009 14:14
pic: GUS Team 228's 6WD Sheet Metal Prototype Chassis artdutra04 Extra Discussion 14 02-01-2009 02:11
pic: re-modified 6wd spc295 Extra Discussion 15 19-11-2008 15:14
