Go to Post FIRST has changed my life and I can never say thank you enough. - Jason Kixmiller [more]
Unread 27-06-2009, 00:34
NorviewsVeteran's Avatar
NorviewsVeteran NorviewsVeteran is offline
Precision Driver Extraordinaire
AKA: Richard Raitt
FRC #1793 (Pilots)
NorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond repute
Trebuchet (Joining Lumber)
Hello fellow off-season CDer's,
I'm building a trebuchet in my basement, and I want to make the swing arm out of 4x4 and 2x4, but I'm not sure how to join the two together end-to-end.
Some ideas have been tossed around, all including large bolts, some including large steel C-channel, but none of us (my brother, dad, or myself) have any real clue how to do it.
Any help would be greatly appreciated, images could validate hugs. No promises.
The attached image is what I came up with in SketchUp, feedback would be nice. The lines flanking the 2x4 are shims to keep it centered.
Name:	trebuchet arm coupler.png
______
I was in Scouts but I wanted out by the third meeting. I was in TSA, but I quit after a couple of weeks. I don't go camping with the SCA anymore. I was in taekwondo but I had to leave because I got sick.
I joined FIRST and stuck with it. It was nice enough to return the favor.
Unread 27-06-2009, 01:05
MrForbes's Avatar
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Trebuchet (Joining Lumber)
It would be helpful to know what the loading is, and how it is applied. Perhaps you have a drawing or sketch of the whole machine?
Unread 27-06-2009, 02:59
It would be better to describe the piece you want and then ask how to make it. Attaching a 4x4 end-to-end with a 2x4 is almost certainly the wrong answer to the question. If -- for example -- you really wanted a 12-foot-long arm with a 4-foot 4x4 section and an 8-foot 2x4 section, I would suggest that you make the arm up from a 12-foot 2x4 with a 4-foot section of 1x4 laminated onto each side of the butt of the arm using yellow glue and a some #8 2-1/2" screws to hold things together while the glue cures. Then, you won't be compromising on the strongest part of a wood laminate structure, which is its long fibers running longitudinally. Given the nature of a treb, I would strongly consider getting the nicest possible board for your arm. A clear piece of southern yellow pine or CVG Douglas fir would be good. Avoid anything with big growth rings or lots of knots.
Have you considered using an arm that is thinner and deeper? You could make a really nice, stiff arm out of some 3/4" plywood strips 8-inches wide and laminated with carpenter's glue. Stiffness increases hugely (the 4th power?) with thickness, and the deeper (higher) your arm, the stiffer it is.
Can you post a sketch?
Unread 27-06-2009, 11:05
AKA: Richard Raitt
FRC #1793 (Pilots)
Almost immediately after I posted this question, my brother and I had the same idea for running a 2x4 the entire length and thickening the weighted end and axle.
The entire thing is southern yellow pine, primarily because its what they have at Home Depot and our budget is "it had better be on sale."
I went back into the SketchUp model and redid the arm, so here is a screen shot with a couple of dimensions for scale.
Name:	trebuchet arm redux.png
______
Unread 27-06-2009, 11:12
Jon236's Avatar
Jon236 Jon236 is offline
AKA: Jon Mittelman
FRC #2648 (Infinite Loop)
Jon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond repute
At a Mentor Gathering following the closing ceremonies in Atlanta, we ran into a fascinating couple who participate in Pumpkin Chucking . They have teams of all ages who construct various machines and hold competitions. They have a great website http://www.punkinchunkin.com/ with forums on how to construct these machines.
Have fun and be safe!
Jon Mittelman
Senior Judge Advisor New England & Israel 2014-2015
Infinite Loop Mentor 2011-2015
TechnoTicks Mentor 2000-2011
Championship Chairman's Award 2009 Team236 TechnoTicks
Judge 2010-2015 Championships
Senior Judge Advisor New England District Championship 2014-2015
Judge Advisor Tel Aviv Regional 2007-2015
Judge Advisor Pine Tree Regional 2013
Maine Regional Planning Committee
New England District Planning Committee
Lead Inspector Microsoft Tel Aviv Regional 2006-2008
Judge & Lead Inspector GM/Technion Tel Aviv Regional 2006
Judge UTC Hartford Regional 2006
Unread 27-06-2009, 11:48
MrForbes's Avatar
AKA: Jim
I don't see the need for doubling the arm, or using 4x4s for posts to support the pivot....since the arm is only 7' long. If you do reinforce it, I'd suggest putting the reinforcements on the top and bottom instead of the sides. In fact you could make the whole arm from a 1x6, taper the long end so it's about 3" wide at the tip.
The pivot shaft looks a bit long and skinny though.
Unread 27-06-2009, 12:37
hillale's Avatar
hillale hillale is offline
Formerly a Winnovator
AKA: Alec Hill
FRC #3617 (Cold Logic)
hillale is a splendid one to beholdhillale is a splendid one to beholdhillale is a splendid one to beholdhillale is a splendid one to beholdhillale is a splendid one to beholdhillale is a splendid one to beholdhillale is a splendid one to behold
Send a message via AIM to hillale
Is this thing going to stay in your basement? Or are you designing it so that you can piece it down and move it? I am reminded of my dad's friend that built a car in his basement and wound up installing an improvised car elevator (forklift hydraulics) to remove it.
Unread 27-06-2009, 13:12
AKA: Richard Raitt
FRC #1793 (Pilots)
The plan from the very beginning was to have it able to break down in to 5-6 major components, most of which lay flat. (minus the counterweight box of course)
We were talking about moving the sides in a little to shorten the shaft. That's 5/8" steel from Home Depot, and bushings and shaft collars from McMaster, for the record.
The problem I see with using a 1x6 for the entire arm is warping from humidity and damage in transportation, I'd feel a lot better tossing a 2-by in the back of the van and putting stuff on top of it.
______
Unread 27-06-2009, 13:16
MrForbes's Avatar
AKA: Jim
Then use a 2x6? my main point is to make the piece larger in the dimensions that need it, and smaller in the dimensions that don't need strength.
Maybe larger diameter thinwall tubing instead of solid rod? although figuring out a bushing would take some effort.
Unread 27-06-2009, 13:53
AKA: Richard Raitt
FRC #1793 (Pilots)
I went back to the model and adjusted the arm again.
There is a 2x6 running the entire length, with a 1x4 on each side where the pivots are, however those could be easily taken out of the plan. At this point they are only there because the bearings I have are too long to have one on each side of a 2-by.
Thanks for all the input, everyone.
Name:	trebuchet arm redux deux.png
______
Unread 27-06-2009, 13:58
The other problem with a 1x6 would be that most Home Depot-quality 1x6s are suitable for trim boards, but are structurally about as strong as Kleenex. The 2x6 makes sense to me. How heavy is your counterweight?
Unread 27-06-2009, 14:06
MrForbes's Avatar
AKA: Jim
good point!
Might also look into buying a sheet of plywood instead of a lot of that lumber....a base plate, two triangles, and not much 2x4 could make the base structure, and it might be possible to make it easy to disassemble and lay flat.
Unread 27-06-2009, 15:06
AKA: Richard Raitt
FRC #1793 (Pilots)
I've already built the two side structures and counterweight box, and the plywood probably wouldn't look as good.
I planned the base with double layered 2x4's so the components can be bolted together using T-nuts.
The counterweight is as heavy as whatever we put in the box, right now we have a spare bag of gravel in the driveway (20-25 lbs? Its labeled as .5 cubic feet) but we could get another bag to experiment once its all together. We are planning on throwing SCA rocks (4 tennis balls duct taped in a tetra) so the projectile won't be really heavy.
______
Unread 27-06-2009, 15:39
Justin Stiltner's Avatar
Justin Stiltner Justin Stiltner is offline
The big guy
Justin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud of
Send a message via ICQ to Justin Stiltner Send a message via AIM to Justin Stiltner Send a message via MSN to Justin Stiltner Send a message via Yahoo to Justin Stiltner
I can lend my personal experience here,
I built a treb very similar to what you have there, I used only one 2x4 for the arm, no extra bracing at the center and had no problems using 300lb of counterweight. For my pivot rod I used a 2" piece of steel pipe that I had laying around, my thoughts about yours is that it will flex quite a bit, especially if you start putting a lot of weight in your box. Also, as others have said, you've got bracing on things that do not really need it, such as the braces from the base to the top of the pivot support, those are good, but the others triangulating them aren't needed. Mine actually looked like yours, but take out the 4x4 post going up for the pivot. Looks good though! Just watch that arm when you (so apparently the bad word filter decided that another word for load that started with a c is bad, so PULL THE ARM BACK) , that pin is dangerous! Oh and mine was 15 feet tall with the arm pointing up. All of my dimensions were true also, as in my 2x4 was actually 2" by 4" I bought them at a local small saw mill, about the same cost as normal lowes or Home depot lumber, but the guys picked out some really good ones for me when they heard what I was doing with them.
Justin Stiltner
Lead Robot Inspector, VCU Regional
Unmanned Systems Lab, Virginia Tech
KI4URQ
Unread 27-06-2009, 16:41
AKA: Richard Raitt
FRC #1793 (Pilots)
Yeah the more I look at the 5/8" we got, the less I trust it for this.
I just looked through our garage and spotted about 10 feet of ~1 1/2" metal pipe, but I don't know how thick it is or if its steel or aluminum. Also, its on a rack above the garage door, so I can't get it down by myself.
There should be an update when my dad gets home.
EDIT: We have a piece of 1 3/8" galvanized steel pipe that seems like it'll work. (we thinks its been in the garage since my parents moved in)
______
It's Trebuchet time..... JohnBoucher Math and Science 2 21-03-2007 09:27
The Trebuchet Challenge JohnBoucher Math and Science 7 29-08-2006 00:47
Trebuchet Challenge Bill_Hancoc Chit-Chat 1 18-06-2006 00:51
Hi - bor pressure treated lumber archiver 2001 0 23-06-2002 22:46
Hi - bor pressure treated lumber archiver 2001 1 23-06-2002 22:46
