Go to Post My mom's cousin heard from her friend who heard from her brother who heard from his barber who heard from his son that his teacher told him that his father's brother's sister's former roommate heard from Frank himself. - notmattlythgoe [more]
Thread Tools Rating: Thread Rating: 10 votes, 5.00 average. Display Modes
Unread 29-06-2009, 02:22
s1900ahon s1900ahon is offline
AKA: Scott McMahon
FRC #2468 (Appreciate)
s1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant future
Re: pic: cRIO CAN Jag
Originally Posted by biojae View Post
You somehow initialize the re-addressing part of jags program (it will have to be part of your program on Crio) then you press the user button on the jags, first one will be addr 1, and so on
Since they come from the factory as '1' it would be recommended to start with 2 and avoid 1. You are correct that the assignment sequence originates as part of some cRIO programming. Since the address is stored in non-volatile memory on the Jaguar, this needs to happen just once, but it can be changed if needed.
yes it will work on other teams, but you will have to re address all of them (as far as i know)
You only need to change the id if a Jaguar is moved to serve a different purpose for which the id is different.
Failed attempt to explain JAG linearity vamfun Technical Discussion 66 05-06-2009 13:13
2009 Camera and Jag inventor models problem Creator Mat CAD 5 08-03-2009 14:05
1 Jag and 1 Victor not responding correctly. elbuo NI LabVIEW 4 17-02-2009 22:57
How can you add more rom space to the cRIO? Comatose FRC Control System 8 05-02-2009 21:16
