Go to Post So many possibilities so many different meanings and soo many different opinions. LOL but i guess this is what FIRST is all about. - Bcahn836 [more]
Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
Unread 29-06-2009, 14:45
Chief Pride's Avatar
Chief Pride Chief Pride is offline
<3
AKA: James Kiefer
Chief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond repute
Losing Communication
My team, as well as others have run into this problem. Something on your robot loses power, and you lose communication. No one can really tell you what happened, because they don't know.
This is especially frustrating. I have done testing at our shop by unplugging the radio and plugging it back in, unplugging the drivers station and plugging it back in, even removing the power leads from the CRIO for a brief moment, then plugging it back in. In all situations the robot regained communication with the KOP router within 30-40 seconds.
How can that be? As anyone who has had this happen to them can tell you, the robot doesn't regain communication...
How can a team debug this issue, and expect to actually find the problem when it is impossible to recreate the problem without an actual field. There must be something that the FRC field is doing that our KOP routers are not, that disallows them to reconnect to the network. I want to know what that is, so that we can either recreate it, or possibly talk someone into disabling it.
Just curious if anyone knows the answer/wants to chime in.
Unread 29-06-2009, 16:47
Re: Losing Communication
I assisted a team at the DC Regional whose robot had consistent communications dropouts on the field, but which had never had problems at home. Moving the WGA out from underneath a Jaguar made everything work properly.
If your robot's radio is in a bad location, but your testing environment is giving a strong enough signal between the robot and the router, you might never see anything break.
Unread 29-06-2009, 16:53
<3
AKA: James Kiefer
At the Michigan State Championships we were seeing our robot drop out light a lightbulb from just driving around. It was caused by an 1/8th inch aluminum L bracket holding the radio. When we drove around apparently it caused enough vibration to disrupt the signal.
As soon as this information was found we immediately stopped using the bracket, and all seemed to be fixed.
With our new robot at MARC we died twice, both times after bumping into a wall, both times were very, very minor crashes. 1/10th of that seen through the rest of the competition with collisions of robots.
I don't think this is a configuration of the components. I am sure we have a connection problem somewhere, we have already found two. I am still curious why the FRC field software will not let your robot reconnect to the network after losing comms.
Unread 29-06-2009, 17:09
IndySam's Avatar
IndySam IndySam is online now
FRC #0829 (Digital Goats)
I did see a couple robots this year that had the radio mounted in such a way that the reset button would be pushed if the robot had collisions in certain conditions.
Unread 29-06-2009, 17:32
<3
AKA: James Kiefer
You can see our mount in this picture... Even if it had been pushed, what is stopping it from regaining connection to the field?
Unread 29-06-2009, 19:32
Burmeister #279's Avatar
Burmeister #279 Burmeister #279 is offline
What Time Is It?
AKA: Nick Burmeister
FRC #0279 (TechFusion)
Burmeister #279 is a glorious beacon of lightBurmeister #279 is a glorious beacon of lightBurmeister #279 is a glorious beacon of lightBurmeister #279 is a glorious beacon of lightBurmeister #279 is a glorious beacon of lightBurmeister #279 is a glorious beacon of light
Send a message via AIM to Burmeister #279
I just had a thought: maybe the robot goes into watchdog mode when it loses communication while under fms's control and cannot get out of it but can get back out of watchdog while its on an open wireless connection.
or maybe when it loses communication the fms program reacts by shutting the robot comm down and putting it in watchdog as a 'safety precaution.'
both are possible i guess.
WHAT TIME IS IT? TWO SEVEN NINE!!! [Team B =) ] Awards: 4 Safety, 2 Ind. Design, 2 Xerox, 1 Nat. Champs
2009 Buckeye Semi-Finalists (1014 & 695) || 2008 GLR Safety Award || 2006 GLR Safety Award
2005 Buckeye Regional Champs (67 & 274) & GM Industrial Design Award & Safety Award GLR Quarter Finalist & Xerox Creativity Award & Safety Award National Xerox Creativity Award & Curie Quarter Finalist (1126 & 180)
2004 Buckeye Delphi Driving Tomorrows Technology Award & Quarter Finalist GLR Champs Nationals Curie Division Finalist
2003 GLR GM Industrial Design Award || 2001 National Newton Division Winner & National Champions
2000 MI DaimlerChrysler Team Spirit Award
Unread 29-06-2009, 19:33
<3
AKA: James Kiefer
The drivers station never says "Watchdog" when we lose communication though.
Unread 29-06-2009, 19:38
What Time Is It?
hmmm... could be a special form of hey-i'm-gonna-really-screw-you-guys-up watchdog that won't let it communicate. We've never had this problem (thankfully) so i'm not much help i guess
Unread 29-06-2009, 19:44
<3
AKA: James Kiefer
I just think that FIRST should do testing on this and find out exactly what causes this behavior, since the teams cannot.
Unread 29-06-2009, 19:45
What Time Is It?
i most definitely agree, however it'd probably take a LOT of time to go through all the possibilities. then again maybe they already fixed it for 2010.
Unread 30-06-2009, 16:40
So far as I know, the FRC field software does let your robot reconnect to the network after losing communication.
Unread 27-07-2009, 03:14
biojae's Avatar
biojae biojae is offline
Likes Omni drives :)
AKA: Justin Stocking
FTC #5011 (BOT SQUAD) && FTC#72(Garage bots)&& FRC#0399 (Eagle Robotics)
biojae is a jewel in the roughbiojae is a jewel in the roughbiojae is a jewel in the rough
it may be in the way the bridges are set up in the competition
the bridge on the robot is a router, and the fms connects to it, (thats why there are 6 antennas on the wifi box on the field)
but in the shop the bridge is solely a wireless to ethernet bridge and you have a router
the fms bridges may only try to connect once, so if you lose communications it won't try to reconnect (fms)
FTC Team 72 - No site
FRC Team 399 - http://www.team399.org
2010 Rockwell Collins Innovation in Control Award - (Use of the CAN bus, among other reasons) Phoenix, Arizona!
Unread 27-07-2009, 04:41
Chris is me's Avatar
AKA: Pinecone
I believe you have to reset your Driver Station to do this. Takes around 20 - 30 seconds. Obviously a big deal in an official match but it can be done.
I have never directly had this issue but it seems certain teams had the issue repeatedly at regionals. I certainly hope this doesn't plague 47 at IRI D:
Unread 27-07-2009, 10:36
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
It's very confusing to other people on the message boards when you make things up that are incorrect and assert them as fact. Please don't do this.
The wireless bridge on the robot is a bridge regardless of if you're at home or at a competition. The device at the side of the field at competition is indeed an access point that the bridges on the robot connect to. The reason there are 6 antennas is because that access point has both 2.4GHz and 5GHz. Each band uses 3 antennas because it employs MIMO technology.
Unread 28-07-2009, 18:37
BLAQmx's Avatar
BLAQmx BLAQmx is offline
Software Engineer
no team (National Instruments)
BLAQmx is a glorious beacon of lightBLAQmx is a glorious beacon of lightBLAQmx is a glorious beacon of lightBLAQmx is a glorious beacon of lightBLAQmx is a glorious beacon of lightBLAQmx is a glorious beacon of light
...and it won't. The only time you will see watchdog written to the DS screen is when the user watchdog is killed, and if you are seeing this you are connected to the robot.
NI FIRST Community: Where to go for LabVIEW, Wind River, cRIO-FRC, and NXT support.
Wireless problem - losing communication jalburty FRC Control System 9 09-01-2009 07:35
Intentionally Losing Matches fredliu168 Rules/Strategy 108 10-04-2008 18:43
losing air pressure razor95kds Pneumatics 3 13-02-2007 07:17
Highest Losing Score Ben Piecuch General Forum 9 03-04-2005 23:17
