Re: How many Robots at the nationals had an operational Camera Track Autonomous?
461 had a successfully tracking robot and as mentioned above scored 6 moonrocks in autonomous during one of the matches. our programmers keep expanding their skills and are getting really great at getting the robot to do everything that we want it to accomplish... they even help other teams out!
Go 461! |
I think that it must have something to do with the visual nature of LabVIEW pushing people to use the visual side of the brain, which can get pretty cluttered when trying to conceptualize a camera control system. Not to mention how C++'s OOP paradigm lets you reimplement the camera controller into your own custom class the way that you conceptualize it best. It's like the difference between C and C++, except that in C the programs actually have a greater chance of not having bugs than C++.
P.S. LabVIEW doesn't qualify as a programming language! |
If you have learned LabVIEW well enough to criticize it, give it a shot. Explain why it isn't a programming language. While you are at it, explain what a programming language is. On the vision tracking topic, has anyone started comparing the approaches and determining the key elements that led to success? I did a number of presentations in Atlanta, and I have my list of things. Greg McKaskle |
I believe he was being facetious with that comment about LabView's status as a programming language, he probably doesn't prefer it though.
I doubt camera tracking autonomouses failed based on anything other than varied lighting conditions and lack of incentive to do so; 70 / 494 were the only teams I saw do it, though if I recall correctly 2056 tracked. If points were worth double in auto or something then I bet you'd see more teams do it instead of loading in autonomous, but loading paid off way more. |
We worked all year on our vision system, and it worked pretty well. We did not use it during auto. We had a piezo buzzer attached to our operator's gamepad, which would sound whenever we were relatively close to a trailer we could score on, during Teleop. We also had a button on our pad that, if held, would automatically dump balls, if I had driven into a correct trailer and was locked on to it.
At nationals, it worked about 80% of the time, when it was sunny out. -Nick |
Something pretty cool we tried along with 1771 was adding on an IR blocking lens onto the camera. The camera values came out much clearer and tracking did work a little better. With calibration, 1771 had some better luck, we did not, but still chose to load in auto. The lenses were from some special military grade goggles (I totally forget what they actually were) donated by 1771's sponsor.
#7
192 had an operational camera tracking autonomous at the Silicon Valley Regional, but they weren't at the Championship.
#8
One thing my team wanted to try was putting a polarized lens over the camera. A 1732 mentor suggested it to us in Wisconsin, but shortly thereafter we gave up on the camera (before we could get one and try it).
#9
I know that a couple teams put a fish-eye lens over the camera, due to the rather limited field of view. It seemed to work pretty well for them.
-Nick |
#10
They start in the top right corner steer toward the center, make a major course correction and score (just off camera). http://www.thebluealliance.net/tbatv/match/2009hi_qf1m1 |
#11
Team 79 used the camera (like posted in the beginning) but it never really worked properly. Then we had a match at the North Star Regional in Minnesota.... and once it tracked a trailer... it drove itself the whole match. I couldn't even drive it... quite funny to watch our robot skynet us, even tho it didnt make a score.
#12
I never tried an additional IR filter. The lens from the mfgr has one built in. Do you have any before and after images, or values?
As for the polarizer, they are useful when the light is polarized, otherwise they are equivalent to a neutral density filter (a gray piece of glass). The atmosphere polarizes the sunlight to some degree, so polarizing outdoors is pretty effective for blocking glare more than other light. Indoor lighting is not polarized. The wide angle lens helps with seeing more of the field without panning the camera. I saw some put lenses in front of the camera, others replaced the lens. If you replace it, beware to get an IR filter. Anything else? Greg McKaskle |
#13
The filter we used was actually a lens from a pair of laser safety goggles. We use IR lasers at work, and have safety goggles to prevent eye injury. What we found is that the incandescent lighting that First uses at events is very heavily weighted towards the IR end of the spectrum, so filtering out a bunch of the IR helped leave bandwidth for the colors we wanted to detect.
In addition, we used a fisheye lens to give us a wider field of view. |
#14
Do you have any before and after images? I'm curious how much saturation boost this gave you?
Greg McKaskle |
| how many people have had failing jaguars | bluebird | Motors | 127 | 04-03-2010 23:28 |
| How many teams had router problems? | darkember | Technical Discussion | 8 | 31-01-2009 21:22 |
| How many teams are using the Camera? | Matt Goulart | Electrical | 3 | 30-01-2005 09:29 |
| how many of u actually used the stacker if u had one? | HolyMasamune | General Forum | 21 | 14-04-2003 13:12 |
| How many robots on the bar in one match? | archiver | 2000 | 14 | 23-06-2002 22:39 |
