Go to Post The real world does not go together like an Erector set. FIRST robots should not either. - dlavery [more]
Unread 07-07-2009, 15:09
Pat Fairbank's Avatar
Pat Fairbank Pat Fairbank is offline
Circuit Breaker
Pat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond repute
Send a message via MSN to Pat Fairbank
Re: pic: 1503 front roller
Tyler and Jeff are correct; it's elastic waistband material. It wasn't the easiest stuff to work with, and we had to reinforce it with fishing line to keep the bands tight, but at least it was inexpensive.
Originally Posted by Lowfategg View Post
Why don't you guys run a guard over it to stop it from getting hit?
We added a steel tube over top and slightly in front of the roller, sometime during the season (I think it was at GTR). It definitely helped, although there was one match on Archimedes where we took such a hard hit in autonomous that both tubes bent, and the roller being out of round caused it to get jammed against the guard as it spun, putting the entire system out of commission.
Originally Posted by Akash Rastogi View Post
Just gotta say, 1503, along with 148 and 1114, had one of the cleanest machines out on the field this year. Really well aesthetically and mechanically designed.
Thanks. Aesthetics was one of the things we were aiming for from the beginning, and we're very proud of how it turned out.
Patrick Fairbank
Team 254 | Mentor (2012-)
Team 1503 | Mentor (2007-2011)
Team 296 | Alumnus (2001-2004) | Mentor (2005-2006)
patfairbank.com
pic: Finished roller assembly Cody Carey Extra Discussion 2 08-10-2006 23:22
pic: Team 306's (maybe) roller system. Cody Carey Extra Discussion 9 24-09-2006 10:47
Thanks to 987 and 1503 Craig Roys Thanks and/or Congrats 4 21-05-2006 13:43
pic: 1902's intake roller Dan Richardson Robot Showcase 7 14-02-2006 20:59
pic: Teams 1114, 1503 & 1680; NiagaraFIRST.org Karthik Robot Showcase 15 25-02-2005 13:27
