Go to Post As you get more into your years in FRC, you start becoming friends with more people. You should try it out. Robotics people are pretty nice. - [more]
Thread Tools Rating: Thread Rating: 36 votes, 4.89 average. Display Modes
Unread 09-07-2009, 18:09
JoeyTNT280's Avatar
JoeyTNT280 JoeyTNT280 is offline
Scouting
AKA: Joey
FRC #0280 (TnT)
JoeyTNT280 is an unknown quantity at this point
Send a message via AIM to JoeyTNT280
Re: Cardboard Boating?
As far as I know any paint is allowed and any non rubber based glue is allowed but no caulk.
Programming
Scouting
Pnuematics
TnT 280 Robotics
Unread 09-07-2009, 21:23
henryBsick's Avatar
henryBsick henryBsick is offline
Why wait for the last 20?
AKA: Henry B. Sick
FRC #0125 (NUTRONS)
henryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond repute
Send a message via AIM to henryBsick
Cardboard regatta, excellent; here is what I have done in the past for a similar competition. It only allowed cardboard and tape. The tape could only extend beyond a seam 1".
My method of choice was to obtain 3 large soda-syrup boxes and tape those together for a base. These boxes are very strong as they carry very heavy bags of syrup. Traditionally they are at least two layers thick in all stress points with a heavy application of glue to hold them together. With these three boxes taped together in line, I cut cross sections of the profile I wanted to achieve and taped them all down the length of the big, three box, center structure. This effectively produced the shape of the hull. From there some crafty taping and placement of 2 outer layers of cardboard around this ribbed structure gave the craft its final shape.
PROTIP: By scoring the entire outer layer of hull, I was allowed to tape the entire surface and still abide by the rules. The boat was perfectly waterproof. HOWEVER my first year I let the cardboard hull in the water 'naked' and it did fine for the duration of its journey: approximately 1 minute.
That's it in a nutshell. Hope it helps.
Mechanical Engineer
Digital Lumens
NU ME: 2011
Unread 09-07-2009, 22:03
Stormnnormn's Avatar
Stormnnormn Stormnnormn is offline
iPirate Poster
AKA: Norman
FRC #1528 (iPirates)
Stormnnormn is a jewel in the roughStormnnormn is a jewel in the roughStormnnormn is a jewel in the roughStormnnormn is a jewel in the rough
Wow... no duct tape?
There goes plans A thru Y...
BTW, most sites I have looked at recommend a flat or really gently sloped bottom, otherwise it risks getting tipped over.
Are there any tapes you are allowed to use? Paper tape, Package tape, scotch tape, and masking tape have not been mentioned...
I like some of the other peoples idea, so look at them too. However, it looks like a few contain duck/duct tape.
Also, if you can use paint, you probably should...
(Sorry about the segmented post, I did not want to post more than once)
-Stormin Norman
Unread 10-07-2009, 11:18
Bruceb's Avatar
Bruceb Bruceb is offline
FRC #0706 (Cyberhawks)
Bruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to behold
One word EPOXY I suppose you could call that 2 words since it is a 2 part adhesive. Look to some of the boatbuilding plan sites for ideas. Cardboard is not thatmuch different than the plywood that most wooden boats are buldt from. search on "clarkcraft" or "Glen-L" and just "boat plans".
Bruce
Unread 10-07-2009, 12:57
Daniel_LaFleur's Avatar
Daniel_LaFleur Daniel_LaFleur is online now
Mad Scientist
AKA: Me
FRC #2040 (DERT)
I'm pretty sure Chop Shop (team 166) has a cardboard regatta every year. You may want to talk to them.
___________________
- Tennyson, Ulysses
Unread 17-07-2009, 13:12
Mentor007's Avatar
Mentor007 Mentor007 is offline
AKA: Paul Fleming
FRC #2228 (Cougar Tech)
Mentor007 is an unknown quantity at this point
You may want to research the Waters & Sons Paper Boat Company in Troy NY. They manufactured boats made entirely of paper. The key trick was to use a single sheet of paper for the outer hull skin so that no seams existed. I believe they used varnish for waterproofing. Also the paper was molded to allow for a keel rib and gunwale ribs.
Waters came up with the concept in 1867. In 1874 on of his canoes made the trip from Troy, NY down the Eastern coast to Florida.
Interestingly, he also used to technique to build domes for observatories. RPI, West Point, Beloit, Columbia, and Brooklyn Polytechnic all had such domes. Syracuse University was about to get one when Waters accidently set fire to it while working with a torch, burning down his factory and ending his paper boat building business.
Unread 19-07-2009, 23:16
Josh Fox Josh Fox is offline
AKA: Foxy
FRC #0027 (Team RUSH)
Josh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud of
Team RUSH is holding our second annual cardboard boat regatta this year, and it's actually one of our team's largest fundraisers. If you're interested in details about anything feel free to pm me or just ask in this thread and I'll respond when i can.
Team RUSH Alumnus and Mentor, Mechanical Engineer
Unread 21-07-2009, 14:16
Robert Cawthon's Avatar
Robert Cawthon Robert Cawthon is offline
Robert Cawthon is a splendid one to beholdRobert Cawthon is a splendid one to beholdRobert Cawthon is a splendid one to beholdRobert Cawthon is a splendid one to beholdRobert Cawthon is a splendid one to beholdRobert Cawthon is a splendid one to beholdRobert Cawthon is a splendid one to behold
I have never built a boat out of cardboard, but I would make the following recommendations:
1. Use several layers of cardboard glued together with a waterproof glue to make stiff pieces of "wood". If you need curved pieces of "wood", you can make a jig and glue the pieces together in the jig so that when the glue dries, the "wood" will have the proper shape.
2. After the boat is built and glued together, paint the inside and outside with a thin layer of the glue. This should waterproof the cardboard. Paint the boat afterward to further protect the glue and waterproofing.
Good luck. Sounds like fun. And don't forget to be safe!
Formerly a mentor with Team Stealth, 1802. Thanks, kids. It was fun!
2008 Greater Kansas City Regional Winner (Thanks 476 and 1806)
2010 Greater Kansas City Regional Gracious Professionalism Award
2012 Greater Kansas City Regional Imagery Award
"It doesn't hurt to be smart as long as you don't out-think yourself." -- Steve Fujita Former KC Chiefs player.
pic: we decided to leave our electronics box as the cardboard box FIRST gave us, it was prelabeled. bubbablahmon Extra Discussion 15 22-01-2008 09:40
pic: 648 Cardboard Crab Steer Boat 1 SgtMillhouse648 Extra Discussion 17 05-07-2007 23:14
The Great Cardboard Boat Regatta SgtMillhouse648 General Forum 11 06-06-2007 14:54
CardBoard Rollercoaster Chaos204 Math and Science 6 29-12-2006 20:10
Forget cardboard sleds, we have polycarb AdamT Chit-Chat 2 18-02-2003 10:33
