Go to Post So now my family thinks I'm insane. - Amanda Morrison [more]
Unread 17-06-2009, 09:18
BlackBird11891's Avatar
BlackBird11891 BlackBird11891 is offline
We Rise Above Our Challenges
AKA: Chad Krivanec
FRC #1927 (Team Tempest)
BlackBird11891 is on a distinguished road
pic: Team 1927's swerve module
Unread 17-06-2009, 09:19
FriedLiver FriedLiver is offline
FRC #2496
FriedLiver is an unknown quantity at this point
Re: pic: Team 1927's swerve module
Ahhh fun stuff. I've been wanting my team to experiment with a system similar to this for a while. Expesically with the different modes of drive. Looks awesome
Unread 17-06-2009, 15:30
sgreco's Avatar
sgreco sgreco is offline
AKA: Steven Greco
FRC #2079
sgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond repute
It looks pretty good...A few questions though...
1. What is the wall thickness on the module? (the module itself doen't quite look strong enough)
2. Is there anything else attaching those drive pullies on the shafts besides the set screws? Because if there isn't you'll need to find another way to secure it, the set screws will loosen.
3. Are you going to have any more suppot on the vertical drive shaft?Because it looks like that drive shaft is going to be torqued in which ever dirction the chain is coming from.
4. How heavy is it?
5. How thick is are the drive shafts?
It looks nice, It makes me really happy to see all of the great offseason CAD work that teams are doing.
Unread 17-06-2009, 23:57
AKA: Chad Krivanec
wow lot of questions the walls are 3/16" thick and the shafts are 1/2"
bearing and all it ways about 6 lbs. a piece i think
we used set screws this year and that was our biggest problem was them coming loose as well as throwing chains so next year were going to go with roll pins for SURE!! ha
we are also going completely away from chains and using all belts there much simpler!!
Unread 20-06-2009, 22:17
AKA: Chad Krivanec
Also to be noted the on the side of the yoke the cut out is still there
Unread 20-07-2009, 00:49
AKA: Chad Krivanec
we just built a chassis with regular wheels and ran it for 3 hours on carpet... they performed excellently
Unread 20-07-2009, 00:59
Sweet! Love to see some pics or vids!
Great work. =) I love how simple these modules are!
Unread 20-07-2009, 09:19
gallo26's Avatar
gallo26 gallo26 is offline
Team 79 Alumni
AKA: Bryan Gallo
FRC #0079 (Team KRUNCH)
gallo26 is a name known to allgallo26 is a name known to allgallo26 is a name known to allgallo26 is a name known to allgallo26 is a name known to allgallo26 is a name known to all
Send a message via AIM to gallo26
Wow! Those modules look amazing! Our team did crab for about 3 years, but stopped because of the hard work that went into them. The platter bearings we had to make were SOO expensive, the software was over complicated, and if there was a malfunction or error in the code the modules would keep spinning and rip the motor wires right out of it. (we had the motors mounted to the actual module like most) For 2008 we thought crab would be the best, but after the debates we couldn't design a new module like you guys have which would eliminate the issues we've had. Very awesome design!!
Team 79 Alumni '11- Present
Team 79 Driver '09, '10
Team 79 Senior CAD Designer '09, '10
Team 79 President '09
Team 79 Electrical Sub Team Leader '08, '09
pic: Team 221 LLC. - Wild Swerve Module ajlapp Extra Discussion 77 06-11-2009 17:33
Team 1927's swerve module BlackBird11891 Technical Discussion 2 16-06-2009 16:35
pic: Team 148 Robowranglers: Swerve Module and Motors Brandon Martus Robot Showcase 27 24-02-2008 22:29
pic: Swerve! (Module) =Martin=Taylor= Extra Discussion 13 09-07-2006 19:57
