Go to Post Teams that are consistently designing and end up with weight problems need to look at their design process and make corrections in "Weight Management". - Mike Martus [more]
Unread 23-07-2009, 03:03
Re: pic: 1323 Thinks Pink
Which wood did you go with in the end, RC?
Turned out really nice, better than I thought it would. I honestly can't believe how nice your renders turn out, its really beautiful.
Unread 23-07-2009, 08:04
sgreco's Avatar
sgreco sgreco is offline
AKA: Steven Greco
FRC #2079
sgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond repute
Wow, that's a sick skid steer. I'm liking it.
Can't wait for specs.
Custom wheels?
Is there a way to get inside the extrusion to access the wheels for things like chain?
Unread 23-07-2009, 11:47
R.C.'s Avatar
R.C. R.C. is online now
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Custom wheels?
Specs are up and the there is a slot under the Chassis Rails to slide wheels into. Max Wheel size is 6 inch. There are also notches cut out to put in chain.
The Wheels are custom, they are these: EWCP Wheel
Akash, the wood board was a tough one. Thanks to Sean I went to Baltic Birch, but I have another type of wood in mind for season
R.C.
MadTown Robotics Team 1323
Unread 23-07-2009, 12:37
sgreco's Avatar
AKA: Steven Greco
FRC #2079
The weight is impressive, especially given 4 motors and a 2 stage tranny. I'm liking the wood too. I'm guesssing the 2 stage transmissions are custom too, Have you potsed them on CD? If not please do, they look nice.
I hope your not stealing my teams plan for a bamboo robot...
Unread 23-07-2009, 12:44
Lowfategg's Avatar
Lowfategg Lowfategg is offline
Building cars now....
AKA: Tyler Moser
FRC #2016 (Mighty Monkey Wrenches)
Lowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond repute
Send a message via AIM to Lowfategg
Its already been done, I cant remember the team number but there was one last year (2008).
Mechanical Engineering Student at WPI.
Mightly Monkey Wrenches FRC #2016 - 2010-12 (Mentor)
Past: FTC #74, FVC #3179, FVC #73, FRC #303, FRC #2753
Unread 23-07-2009, 12:47
Jeff K.'s Avatar
Jeff K. Jeff K. is offline
Hmm..now what?
FRC #1138 (Eagle Engineering)
Jeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond repute
Send a message via AIM to Jeff K. Send a message via MSN to Jeff K.
It's good to explore more natural means for robots. Wood is an excellent tool if implemented nicely and holds advantages over other materials like polycarb or aluminum. The battery looks awfully cozy in the back though. How is the weight distribution front-rear?
Unread 23-07-2009, 13:24
We might not be posting them up until after build. But if you'd like to see them please PM.
Unread 23-07-2009, 15:02
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
Looks sick man. I definitely love your renders. Glad I could have a bit of an influence on you, and I love your implementation of the EWCP transmission.
Mentor 2415
Unread 23-07-2009, 15:52
AndyB's Avatar
AndyB AndyB is offline
Ambitiously Disappointing
AKA: Andy Burchardt
FRC #0171 (Cheese Curd Herd)
AndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond repute
Very nice render. Background could use some work, everything else looks great though.
I'm assuming the crossbars in the front and back are just welded on.
I'm also assuming the support rails would run across the middle? What did you have in mind for those, just a couple 2x1 extrusions welded in place?
What prompted you to put both the trannies and the battery in the very back?
Team 171 :: Cheese Curd Herd :: College Mentor, 2008-Present
Team 269 :: CooneyTech Robotics :: Student, 2005-2007
Unread 23-07-2009, 16:23
R.C.'s Avatar
Nice to hear from you Andy. The crossbars are welded on and pretty much our frame will be welded as it has been for the past 4 years. You nailed the extrusion part right:
-one in the back and front
-one in the middle maybe two
The reason for the trannies in the back along with the battery is because if you look closely enough at the center wheel. There is an arc bolt pattern that I've CNC'd into the rail. (The add on plate is not shown, I forgot to add it on). We used that pattern this year and it works great (even with the slippery surface for a 1/16 drop). You can adjust the drop between a no drop or a 1/4 inch, 1/16th increments. So I put the trannies in the back with a direct drive. The battery is in the back because I don't have anything to put on top.
It depends, If the game or design I was making was a forklift, the battery would be fine. But If it was something that extruded beyone the frame like an arm. I may move it a bit forward. It all depends.
Here's a pic of A wood DriveTrain made my Team 418, just to show the use of wood:
http://www.chiefdelphi.com/media/photos/31598
-RC
R.C.
Unread 23-07-2009, 17:36
AdamHeard's Avatar
Lead Mentor
If the wood is rigidly attached to the frame along it's length, you could probably get away with no internal cross members.
Also, You appear to be using 6" wheels, which is fne; but I think you could save a substantial amount of weight by going smaller (and keep the same ground clearance by shifting the wheels down).
For season, I'd ditch the adjustable center drop and go with a value you know works, saves some parts and weight.
Unread 23-07-2009, 18:32
Scott Morgan Scott Morgan is offline
None #1138
Scott Morgan has a spectacular aura aboutScott Morgan has a spectacular aura aboutScott Morgan has a spectacular aura about
I was thinking the same thing. I don't think Pink uses any cross internal members on their robots.
Unread 24-07-2009, 18:33
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
They use their belly pan as their cross bracing.
2001-2004: Team 100
2006-Present: Team 254
Unread 24-07-2009, 19:32
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Looks good, just replace all that blue stuff with brown stuff and you'll be done!
(with a lot of redesign)
pic: THINK PINK 233 Roccobot 2k9's Pink Gabe Salas Jr. Extra Discussion 4 11-03-2009 19:31
pic: 1323 R.C. Extra Discussion 3 07-02-2009 23:24
pic: 1323 Robot comwiz7 Robot Showcase 21 17-03-2008 15:30
pic: 1323 electrical Robo_Coyote Extra Discussion 1 20-01-2007 19:32
pic: John thinks he's important... CD47-Bot Extra Discussion 1 13-01-2004 23:24
