pic: 1323 Thinks Pink
Re: pic: 1323 Thinks Pink
Which wood did you go with in the end, RC?
Turned out really nice, better than I thought it would. I honestly can't believe how nice your renders turn out, its really beautiful. |
Wow, that's a sick skid steer. I'm liking it.
Can't wait for specs. Custom wheels? Is there a way to get inside the extrusion to access the wheels for things like chain? |
The Wheels are custom, they are these: EWCP Wheel Akash, the wood board was a tough one. Thanks to Sean I went to Baltic Birch, but I have another type of wood in mind for season ![]() |
The weight is impressive, especially given 4 motors and a 2 stage tranny. I'm liking the wood too. I'm guesssing the 2 stage transmissions are custom too, Have you potsed them on CD? If not please do, they look nice.
Its already been done, I cant remember the team number but there was one last year (2008).
#7
It's good to explore more natural means for robots. Wood is an excellent tool if implemented nicely and holds advantages over other materials like polycarb or aluminum. The battery looks awfully cozy in the back though. How is the weight distribution front-rear?
#8
We might not be posting them up until after build. But if you'd like to see them please PM. |
#9
Looks sick man. I definitely love your renders. Glad I could have a bit of an influence on you, and I love your implementation of the EWCP transmission.
#10
Very nice render. Background could use some work, everything else looks great though.
I'm assuming the crossbars in the front and back are just welded on. I'm also assuming the support rails would run across the middle? What did you have in mind for those, just a couple 2x1 extrusions welded in place? What prompted you to put both the trannies and the battery in the very back? |
#11
-one in the back and front -one in the middle maybe two The reason for the trannies in the back along with the battery is because if you look closely enough at the center wheel. There is an arc bolt pattern that I've CNC'd into the rail. (The add on plate is not shown, I forgot to add it on). We used that pattern this year and it works great (even with the slippery surface for a 1/16 drop). You can adjust the drop between a no drop or a 1/4 inch, 1/16th increments. So I put the trannies in the back with a direct drive. The battery is in the back because I don't have anything to put on top. It depends, If the game or design I was making was a forklift, the battery would be fine. But If it was something that extruded beyone the frame like an arm. I may move it a bit forward. It all depends. Here's a pic of A wood DriveTrain made my Team 418, just to show the use of wood: http://www.chiefdelphi.com/media/photos/31598 -RC Last edited by R.C. : 23-07-2009 at 16:27. |
#12
If the wood is rigidly attached to the frame along it's length, you could probably get away with no internal cross members.
Also, You appear to be using 6" wheels, which is fne; but I think you could save a substantial amount of weight by going smaller (and keep the same ground clearance by shifting the wheels down). For season, I'd ditch the adjustable center drop and go with a value you know works, saves some parts and weight. |
#13
I was thinking the same thing. I don't think Pink uses any cross internal members on their robots.
#14
They use their belly pan as their cross bracing.
#15
Looks good, just replace all that blue stuff with brown stuff and you'll be done!
(with a lot of redesign) |
| pic: THINK PINK 233 Roccobot 2k9's Pink | Gabe Salas Jr. | Extra Discussion | 4 | 11-03-2009 19:31 |
| pic: 1323 | R.C. | Extra Discussion | 3 | 07-02-2009 23:24 |
| pic: 1323 Robot | comwiz7 | Robot Showcase | 21 | 17-03-2008 15:30 |
| pic: 1323 electrical | Robo_Coyote | Extra Discussion | 1 | 20-01-2007 19:32 |
| pic: John thinks he's important... | CD47-Bot | Extra Discussion | 1 | 13-01-2004 23:24 |
