Go to Post *speaks into wristwatch* We've got a non-gracious professional here, get Woodie on the phone! - Ringo5tarr [more]
Thread Tools Rating: Thread Rating: 10 votes, 5.00 average. Display Modes
  #61   Spotlight this post!
Unread 05-07-2009, 02:04
s1900ahon s1900ahon is offline
AKA: Scott McMahon
FRC #2468 (Appreciate)
s1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant future
Re: pic: cRIO CAN Jag
Originally Posted by biojae View Post
i just noticed in the picture that there is a split cord at the base of the cRio, one side goes to the jags and the other goes to an enclosure, is that another termination resistor?
Yes, but that shouldn't be surprising. The CAN bus uses 2 termination resistors, ideally located at each end. Both termination resistors are 120 ohm. Neither the Jaguar nor NI-9853 (*) provide internal termination since they make no assumptions regarding the bus topology nor where they are placed.
(*) This module was used by NI on NItro.. but I would not make any assumptions about this. NItro is a technology demonstration vehicle.
  #62   Spotlight this post!
Unread 05-07-2009, 02:18
AKA: Scott McMahon
It looks like it could be made easily, how much does NI sell it for? (We will probably get one in the kit though)
Also what module # is in the cRIO?
I know that the jags can do 1mb per second comms, and there is a 1mb module but there is the possibility of us having the slower comms, (Though i don't believe that we will ever need to have that much data throughput)
The cable pictured is not available from NI. It was a small custom build for NItro. It is a small piece of 9 conductor ribbon cable with 4 flat ribbon DB-9 connectors crimped on it. One DB-9 is used for connecting to the Jaguars, one for connecting a termination resistor, one to connect to the NI CAN module, and the final for connecting a CAN bus analyzer. The parts are cheap and no soldering required.
A comment on the bus bandwidth.. the number of packets per second you can get on CAN depends on a number of factors. If you consider a 29-bit message identifier (as used by Jaguar) and average bit stuffing, on a 1 Mb/s network, you can get >12,800 1-byte packets per second and >9,300 4-byte packets per second. I bet that some crazy team will be complaining in a year or so about the need for more CAN bandwidth . The nice thing about CAN is that there are no collisions, so you know when it is busy the data still gets through.
Last edited by s1900ahon : 05-07-2009 at 16:11. Reason: Can't add. Forgot the DB-9 facing the module.
  #63   Spotlight this post!
Unread 06-07-2009, 01:47
biojae's Avatar
biojae biojae is offline
Likes Omni drives :)
AKA: Justin Stocking
FTC #5011 (BOT SQUAD) && FTC#72(Garage bots)&& FRC#0399 (Eagle Robotics)
biojae is a jewel in the roughbiojae is a jewel in the roughbiojae is a jewel in the rough
I just wish that first would tell us that we can use the CAN bus in 2010
FTC Team 72 - No site
FRC Team 399 - http://www.team399.org
2010 Rockwell Collins Innovation in Control Award - (Use of the CAN bus, among other reasons) Phoenix, Arizona!
  #64   Spotlight this post!
Unread 25-07-2009, 01:48
biojae's Avatar
Though at atlanta, the luminary micro and java people said that the Fpga image was gettting too large and they (WPI) would have to take some functionality out to get CAN in
Failed attempt to explain JAG linearity vamfun Technical Discussion 66 05-06-2009 13:13
2009 Camera and Jag inventor models problem Creator Mat CAD 5 08-03-2009 14:05
1 Jag and 1 Victor not responding correctly. elbuo NI LabVIEW 4 17-02-2009 22:57
How can you add more rom space to the cRIO? Comatose FRC Control System 8 05-02-2009 21:16
