Go to Post My favorite quote from my 4 year old daughter is, "if it works, who cares?" - drwisley [more]
Unread 25-07-2009, 14:40
,4lex S.'s Avatar
,4lex S. ,4lex S. is offline
University Mentor
AKA: Alex Strong
FRC #2702 (REBotics)
,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of
pic: 3/4" Plywood Frame
Unread 25-07-2009, 14:42
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: pic: 3/4" Plywood Frame
We built a plywood chassis last year, it was a different design, as the wood was used to support the axles directly, and it was based on the "box" concept. Not much twisting going on with a box!
http://www.chiefdelphi.com/forums/sh...ad.php?t=71902
The strange overal design was due to having to harvest balls from the floor, and the trailer let us use a wide 4wd design instead of the narrow 6wd that most games seem to require.
Unread 25-07-2009, 16:11
Jared Russell's Avatar
Taking a year (mostly) off
Without some "3D" supports, I'd worry about warping in a chassis like this. It's looking good, though - you are almost there.
Unread 25-07-2009, 19:06
AndyB's Avatar
AndyB AndyB is offline
Ambitiously Disappointing
AKA: Andy Burchardt
FRC #0171 (Cheese Curd Herd)
AndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond repute
I might look into a design like this within Inventor and do some stress testing on it. Very interesting idea. I'd be most concerned with bending or warping between the gearboxes, but that could be pretty easily remedied with a couple bars of 1x1 aluminum. I like the idea though.
Team 171 :: Cheese Curd Herd :: College Mentor, 2008-Present
Team 269 :: CooneyTech Robotics :: Student, 2005-2007
Unread 25-07-2009, 19:38
gburlison gburlison is offline
gburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to all
A little warping in the right direction might help keep all 6 wheels on the ground if the floor is not completely flat. I would reinforce the long side first, to help keep chains between the wheels on the sprockets.
Gordon Burlison - Mentor
662/Rocky Mountain Robotics
"Every silver lining's got a Touch of grey - Robert Hunter"
"No sense in being pessimistic, it wouldn't work anyway"
Unread 25-07-2009, 21:59
DonRotolo's Avatar
Back to humble
FRC #0832
There are many grades of plywood; you want aircraft plywood if possible. It uses many layers of light wood.
regular plywood, like used for house construction, uses only a few layers, and is not as strong (or light) as aircraft plywood. Marine plywood uses a few more layers, but isn't as light. You might consider making your own plywood, two 1/4" aircraft ply outer layers with foam and 1/4" spacers in-between - lighter and just as strong.
For stiffness, use pieces mounted 90 degrees to the plane - glue and screw.
It would be heavier than aluminum, but plenty strong. Use some aluminum U channel along the outer edge to give very good impact strength.
But nice concept!
Unread 25-07-2009, 22:20
Bertman's Avatar
Bertman Bertman is offline
FRC #0418 (Purple Haze)
Bertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond reputeBertman has a reputation beyond repute
We have made several plywood frames over the years. If you use 3/8" plywood (I would use Baltic Birch which has at least 5 layers and no voids) as a top with a 1/4" Baltic Birch Ply bottom - sandwiching 1/2" -3/4" X 3/4" spacers around the perimeter, all glued and clamped, with solid blocks at mounting points for pillow blocks and super-structures you will create a hollow chassis which is light and incredibly strong and stiff. For inspiration look to light wieght, wooden boat construction. Go for it and good luck.
Unread 26-07-2009, 00:24
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Does Inventor now have an FEA plugin that can do laminated composites? (Plywood is non-isotropic and non-homogenous, so a regular solid model simulation won't perform well except for very small stresses—where it probably wouldn't matter.)
Unread 26-07-2009, 00:58
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Just an idea, you may want to try making a chassis like 1771 or 1726.
-RC
R.C.
MadTown Robotics Team 1323
Unread 26-07-2009, 12:46
kramarczyk's Avatar
kramarczyk kramarczyk is offline
is getting his kicks.
AKA: Mark Kramarczyk
FRC #3096 (Highlanders)
kramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond repute
2009 does not. 2010 is supposed to have a substancially upgraded package, but I do not believe composites are included. It does open the door for analysis of assemblies.
Mark
Brick walls are for other people. - Randy Pausch
Unread 02-12-2009, 14:17
Cyberphil's Avatar
Cyberphil Cyberphil is offline
That Guy
AKA: Phil
FRC #0103 (Cybersonics)
Cyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud of
Send a message via AIM to Cyberphil
I dono if im missing something, but there is almost no clearance on that at all. I have always found that you should have some more clearance than that.
Unread 02-12-2009, 22:32
Gdeaver Gdeaver is offline
FRC #1640
Plywood is mother nature's composite. If you add in some epoxy and glass, Kevlar or carbon fiber cloth, you can make a very light and durable wood structure. Our team this year is contemplating making our bottom electronics board out of 5mm birch plywood laminated on both sides. The panel in our design is also a structural part of the frame. To keep the weight down requires vacuum bagging. We could buy other material for this part or buy pre made panels. I'm going to work with the students laminating the panel to give them some exposure to composite construction. There are many good tutorials on the web showing how to do this. However it does take some practice. It wood be a good off season project. You don't want to decide to do this during build season with out some practice. Allot of FRC teams are addicted to metal. They should get some fiber in their robot diet.
Bumper Plywood Backing Skifanatic Technical Discussion 3 10-02-2009 18:20
pic: plywood+mill = wooden omniwheels?!? Stuart Extra Discussion 4 06-02-2007 14:35
grip on dusty plywood greencactus3 Technical Discussion 5 12-01-2005 18:41
Wheels - Plywood Denman Technical Discussion 10 04-02-2004 08:38
Question about Plywood thickness KennethToronto Technical Discussion 4 06-02-2002 15:20
