Go to Post Pursue your passion whatever that may be and do not fault another for pursuing theirs. - Mr. Van [more]
Unread 26-07-2009, 02:12
bobwrit's Avatar
bobwrit bobwrit is offline
//No Comment
AKA: ...
FRC #1977 (Loveland High Robotics)
bobwrit is just really nicebobwrit is just really nicebobwrit is just really nicebobwrit is just really nicebobwrit is just really nice
pic: Neural Network Concept
Unread 26-07-2009, 02:14
GarrettF2395's Avatar
GarrettF2395 GarrettF2395 is offline
AKA: Sierra 117
FRC #2395
Team Role: RoboCoach
GarrettF2395 is a glorious beacon of lightGarrettF2395 is a glorious beacon of lightGarrettF2395 is a glorious beacon of lightGarrettF2395 is a glorious beacon of lightGarrettF2395 is a glorious beacon of light
Send a message via Yahoo to GarrettF2395
Re: pic: Neural Network Concept
Please excuse me if I am being ignorant, for I am not a programmer.
But what exactly do the small circles represent, and how do they affect the motor inputs?
https://twitter.com/TeamNinjaMunkee
FRC 2395: Team captain 2008-2009, Design mentor 2010-2011, Lead design and strategy mentor 2012-Present
Unread 26-07-2009, 13:53
Jared Russell's Avatar
Taking a year (mostly) off
The small circles are neurons - in artificial neural networks, neurons have N inputs and a single output. Each of the N inputs has an associated weight - the output of the neuron is the weighted sum of the each input multiplied by its weight. There are many variations on this scheme, but this is a general starting point for a neural network.
However, what is pictured needs some more explanation to be meaningful. This is a picture of a generic one-layer artificial neural network. Neural networks essentially try to solve nonlinear optimization problems - what is the problem (cost function to be minimized) in this case?
Unread 28-07-2009, 04:18
kiettyyyy's Avatar
kiettyyyy kiettyyyy is offline
FRC #1538 (The Holy Cows)
kiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond repute
Send a message via AIM to kiettyyyy
So, what's the benefits of implementing a neural network in this case?
-Kiet Chau
2004-2008 - Software Developer/Driver on Team #968
2008-2011 - Software Developer/Coach/Mentor/"Engineer" on Team #968
2011-Present - Mentor & Engineer on Team #1538
www.team1538.com
Unread 28-07-2009, 10:10
In this configuration, none that I am aware of. A neural network is only really useful when you are trying to solve a problem where the solution is "hard" to find but "easy" to know. To borrow an adult example of this from our legal system, "_________ is hard to define, but I know it when I see it".
As I see it, this doesn't fit that requirement. It is easy to define, but hard to know. Training the Neural Net will require a lot of hand-holding - how will you define how good it is? Also, the direct coding alternatives are plentiful and effective - just look around this forum.
Constructive Criticism:
This configuration only knows two things: the most recent joystick values. Therefore, it only can do things that only require the most recent joystick values. This prevents it from doing things like filtering or ramping. Adding recursion (nodes that look at their previous output as a current input) would allow this. Adding inputs from encoders/accelerometers/gyro/etc would allow it to do more interesting things.
Unread 04-08-2009, 10:55
Back after 4 years off
FRC #5279
Is this the same NN discussed here http://www.chiefdelphi.com/forums/sh...02&postcount=7 ?
If so I believe that we are falling into a trap, just because something can be done one way doesn't make it the best way (or even a good way). Could you please post more information (ie details about what each of the nodes is actually doing) so we (or at least I) can get a better idea of what the benefits of using a Neural Network here might be?
I'm Back
5279 (2015-Present)
3594 (2011)
3280 (2010)
1665 (2009)
1350 (2008-2009)
1493 (2007-2008)
1568 (2005-2007)
Will we see Artificial Neural Networks in FRC in 2010? manderson5192 Java 11 22-07-2009 15:30
pic: Concept Frame armoredvehicle Extra Discussion 6 16-12-2007 20:55
Neural Control of Robot Arm Leo M Math and Science 2 29-03-2004 13:46
pic: Claw^2 Concept CD47-Bot Extra Discussion 8 06-02-2004 14:08
pic: Crab Concept 6 CD47-Bot Extra Discussion 13 14-11-2003 22:03
