Go to Post Looks like we will be building a wood robot :) - IndySam [more]
Unread 26-07-2009, 12:46
kramarczyk's Avatar
kramarczyk kramarczyk is offline
is getting his kicks.
AKA: Mark Kramarczyk
FRC #3096 (Highlanders)
kramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond repute
Re: pic: 3/4" Plywood Frame
Originally Posted by Tristan Lall View Post
Does Inventor now have an FEA plugin that can do laminated composites? (Plywood is non-isotropic and non-homogenous, so a regular solid model simulation won't perform well except for very small stresses—where it probably wouldn't matter.)
2009 does not. 2010 is supposed to have a substancially upgraded package, but I do not believe composites are included. It does open the door for analysis of assemblies.
Mark
Brick walls are for other people. - Randy Pausch
Unread 02-12-2009, 14:17
Cyberphil's Avatar
Cyberphil Cyberphil is offline
That Guy
AKA: Phil
FRC #0103 (Cybersonics)
Cyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud of
Send a message via AIM to Cyberphil
I dono if im missing something, but there is almost no clearance on that at all. I have always found that you should have some more clearance than that.
Unread 02-12-2009, 22:32
Gdeaver Gdeaver is offline
FRC #1640
Plywood is mother nature's composite. If you add in some epoxy and glass, Kevlar or carbon fiber cloth, you can make a very light and durable wood structure. Our team this year is contemplating making our bottom electronics board out of 5mm birch plywood laminated on both sides. The panel in our design is also a structural part of the frame. To keep the weight down requires vacuum bagging. We could buy other material for this part or buy pre made panels. I'm going to work with the students laminating the panel to give them some exposure to composite construction. There are many good tutorials on the web showing how to do this. However it does take some practice. It wood be a good off season project. You don't want to decide to do this during build season with out some practice. Allot of FRC teams are addicted to metal. They should get some fiber in their robot diet.
Bumper Plywood Backing Skifanatic Technical Discussion 3 10-02-2009 18:20
pic: plywood+mill = wooden omniwheels?!? Stuart Extra Discussion 4 06-02-2007 14:35
grip on dusty plywood greencactus3 Technical Discussion 5 12-01-2005 18:41
Wheels - Plywood Denman Technical Discussion 10 04-02-2004 08:38
Question about Plywood thickness KennethToronto Technical Discussion 4 06-02-2002 15:20
