Go to Post Sometime it makes me think what would I do without FIRST... - Arefin Bari [more]
Unread 01-07-2002, 08:45
Ian W. Ian W. is offline
College? What?
no team (Gompei and the Herd)
i missed that episode . is there anywhere that i can download it online, or is it supposed to air again anytime soon?
as for propellers, i've heard if you look in the right hobby shops, you can find propellers made for model airplanes. not the tiny electrical ones, but the huge gas powered ones. i've seen one site with a 24" prop from a hobby shop (i think). it's www.xinventions.com. not a bad site, some pretty cool stuff .
for skirt material, me and orie were thinking tarp type material. there is an army surplus store nearby, but i'm not sure what they have.
AIM --> Woloi
Email --> ian@woloschin.com
Unread 01-07-2002, 09:05
MrB's Avatar
MrB MrB is offline
871 Team Leader
AKA: Brian Buonomo
FRC #0871 (WI RoboTechs)
MrB is a jewel in the roughMrB is a jewel in the roughMrB is a jewel in the roughMrB is a jewel in the rough
In HS my tech class built a couple of Hover Crafts. All were electric powered. We used the old ELECTROLUX vacuum cleaner motors. We mounted two motors piggy back on a plywood board that was glued (calked maybe) to an inner tube, from a HUGE tire.
It could hold 2-3 people and with a couple of extension cords you could glide down the entire hallway.
From what I’ve read in the past few years and scene while teaching I would model a hovercraft after the commercial models.
One motor in the back with a bug prop. From what I read it seems like the more blades on the prop the more air that is pushed, and the less air that can leak back through the prop, actually they are more like fan blades to a turbine engine.
As for a skirt, I agree with those that suggest using a heavy duty tarp. The ideas is to create a cushion of air beneath the vehicle, and that when the air leaks out under the skirt it does so in an even and balanced fashion. Balancing the hovercraft is critical, and building a skirt that only allows minimal air "leakage" is the main goal.
I saw a Web site a few years ago about a kid, probably 15, who built a hover craft with 2 engines. One was a leaf blower that provided lift, the other was a 5 HP Briggs and Stratton Engine attached to a 2 blade prop. HE said he could lift about 120 lbs and move at about 20 MPH.
It looked just like a junkyard war project :-)
Please make sure some Adults are around. You guys aren't building a toy, remember it is a vehicle, whether it is legal or not, it is still dangerous.
Good Luck and have fun. Just be careful, remember SAFTEY FIRST.
Unread 01-07-2002, 10:32
College? What?
yeah, that kid who built the hovercraft is the one who has www.xinventions.com, and there's a bunch of pics on the site. i think we want to build something like that, only a little bigger and more powerful. we're not exactly sure though.
also, is it possible to power a shop vac with say, a car battery and a volt converter? i have a really cool idea, but it wouldn't work with extension cords.
AIM --> Woloi
Unread 01-07-2002, 11:12
oreocookeee oreocookeee is offline
Critic Extraordinaire
AKA: orie
#0810 (Mechanical Bulls)
oreocookeee is on a distinguished road
Send a message via AIM to oreocookeee
ive been to xinventions.com and its one of my favorite sites but they fail to explain the technical aspects of building a hovercraft. although i dont mind experimenting with different ideas, i would feel a lot more confortable knowing that my plans actually have a chance of working. and as for the junkyard wars episode, i cant remember who won, but it was pretty close untill one of the driver leaned to far to the side while turning and crashed the side of the hovercraft into the ground. since the hovercraft was fairly light, it stopped on impact bu the driver was a little less fortunate, being thrown into the mud. but one of the team's hovercraft was basicall a jet engine mounted on a foam platform. they used only on propeller that was mounted inside a stripped down turbine engine and diverted half the air to lift the craft. the idea may be similar but i am hoping that our craft will be a little more than a floating platform.
Unread 01-07-2002, 12:00
team222badbrad's Avatar
3D Printing Specialist
AKA: Bradley Rigdon
FRC #0222 (The Tigertrons)
Simple.....
Just simply visit www.hovercraft.com for plans
Tigertrons are on Facebook!
http://www.printo3d.com
16th FIRST season for me.
Unread 01-07-2002, 12:09
DaBruteForceGuy's Avatar
DaBruteForceGuy DaBruteForceGuy is offline
aKa - Steve Bennett
FRC #0125 (NUtrons)
DaBruteForceGuy is an unknown quantity at this point
Send a message via AIM to DaBruteForceGuy
LOL
ORIE:
i am worried about making them mmyself because if they are not perfectly symmetrical, they could cause the whole craft to vibrate and consequently fall apart.
Orie, i m afraid that anything that you build yourself will consequently FALL APART!! !!
Team
810 > 2001-2005 - Student Founder
125 > Present - College Student
---The pessimist complains about the wind, the optimist hopes that the wind will change... the realist adjusts the sail.
***<Therapist> Tell me, is the glass half full or half empty?
***<Engineer> Neither, the glass is too big.---
....Uh, GO NUTRONS!
Unread 01-07-2002, 12:47
AKA: orie
hey steve, being pessimistic is my job! I think i do a good enough job of criticizing my own work, so i dont need any help from you!
Unread 01-07-2002, 16:33
Adam Y.'s Avatar
Adam Y. Adam Y. is offline
Adam Y.
no team (?????)
come on stop worrying about a piece of plywood falling apart if the guys on tv managed to make a hovercraft that worked with a pieces of styrofoam and an gas engine and it worked
too much lift and your hovercraft will be unstable and fall too little it isnt going anywhere btw a hovercraft is nothing more than a floating platform
Unread 01-07-2002, 18:13
College? What?
well, more than a floating platform as in, a floating platform with a cool shape and a nice big engine on the back to move it around
AIM --> Woloi
Unread 01-07-2002, 19:32
AKA: orie
what i meant was a floating platform with seats, and a nice dashboard
Unread 02-07-2002, 16:06
Melancholy's Avatar
Melancholy Melancholy is offline
mmm... robots...
#0263 (Aftershock)
Melancholy is an unknown quantity at this point
Send a message via AIM to Melancholy
Once while some members of my team were taking apart a computer so they could play with the magnets, we made a G.I.Joe sized hovercraft. We used the computer's fan, a 9V battery, a platic bag, and some duct tape.
*Kimberly*
Melancholy <3 Chubtoad
What do you think about NEXT YEAR's GAME? Digo General Forum 20 17-04-2002 14:09
