Thread Tools |
Rating:
Display Modes |
#12
Re: Beginner team, where to begin?
One thousand bucks won't go too far with a mill less tooling, never mind the know how to use it. I would go in a different direction. Pre-buying some basic stuff will save you some time though during a limited build season.
A good idea for any team is to standardize the fasteners. We use 1/4" bolts for just about everything. You can buy steel ones in varying lengths, say about 1/2" to 4". Or you can splurge and go for aluminum ones to save on weight, but they are pricey. Get some 7/16" wenches and sockets for the heads and bolts and some 9/32" drills. Making the holes larger makes getting the bolts in easier. Get some 1/8" pop rivets and a gun to fill out the fasteners, with a range of 1/8" to maybe 1/4" fastening range. Tools: 1) A nice 18V cordless drill is good to have. A table top drill press will help drill holes more squarely through thicker material. ($250 or so) 2) I really like a nice belt sander. Here a good and cheap one. Order extra belts that are made for this machine. Regular 48" ones won't fit! $299.00 http://www.harborfreight.com/cpi/cta...emnumber=40643 3. You can use a hacksaw to cut aluminum, if you have lots of students it keeps them busy but a basic horizontal band saw saves a lot of time. http://www.harborfreight.com/cpi/cta...emnumber=93762 4. Try to find a quality used vertical bandsaw. 5. Hand tools like pliers of various types, mallet, drill index, wrenches, socket set, screwdriver set, measuring tools like steel rules or a tape measure, electrician's tool, tap and die set, punch set, jeweler's screwdrivers, chain tool; the list goes on and on... That's more than $1000 so look for donations from parents and businesses. Welcome to FIRST! |
| Beginner Electrical | DavidB | Electrical | 10 | 09-12-2008 21:25 |
| Where do I begin to get the robot to move using the camera? | Ianuser | Programming | 10 | 16-02-2007 17:55 |
| Beginner PHP Project | Raven_Writer | Website Design/Showcase | 3 | 23-05-2004 16:47 |
| Good Beginner Websites | mistresshawk | Programming | 27 | 18-01-2003 10:45 |
| Where do you begin??? | archiver | 1999 | 6 | 23-06-2002 22:58 |
