Go to Post The best legacy of this little machine is the inspiration she provided to a whole generation of future explorers who witnessed the unveiling of a planet through the eyes of a robot. - dlavery [more]
  #31   Spotlight this post!
Unread 04-08-2009, 02:37
biojae's Avatar
biojae biojae is offline
Likes Omni drives :)
AKA: Justin Stocking
FTC #5011 (BOT SQUAD) && FTC#72(Garage bots)&& FRC#0399 (Eagle Robotics)
biojae is a jewel in the roughbiojae is a jewel in the roughbiojae is a jewel in the rough
Re: Driver Station Usb
simple test program for arduino which i am using for the pots right now
#include <Wire.h>
void setup()
  Wire.begin(); // join i2c bus (address optional for master)
byte value = 0;
byte ch1 = 0x28;
byte ch2 = 0x29;
byte pot1 = 0xA9;
byte pot2 = 0xAA;
void loop()
 writePot(ch1, pot1, value);
 writePot(ch1, pot2, value);
 writePot(ch2, pot1, value);
 writePot(ch2, pot2, value);
  value++;        // increment value
  if(value == 256)
    value = 0;    // start over from lowest value
  delay(100);
void writePot(int chip, int pot, int val)
  Wire.beginTransmission(chip); // transmit to device 0x28)
  Wire.send(pot);            // sends instruction byte,
                               // write to potentiometer-0
  Wire.send(val);             // sends potentiometer value byte
  Wire.endTransmission();     // stop transmitting
FTC Team 72 - No site
FRC Team 399 - http://www.team399.org
2010 Rockwell Collins Innovation in Control Award - (Use of the CAN bus, among other reasons) Phoenix, Arizona!
  #32   Spotlight this post!
Unread 04-08-2009, 19:18
biojae's Avatar
here is the code for the arduino, the touchscreen has its own processor that talks over ttl serial to the arduino
the arduino takes the output from the screen to the DS io pins
#include <Wire.h>
#include <AFSoftSerial.h>
#define rxPin 3
#define txPin 2
AFSoftSerial touchscreen = AFSoftSerial(rxPin, txPin);
byte ch1 = 0x28;
byte ch2 = 0x29;
byte pot1 = 0xA9;
byte pot2 = 0xAA;
int stopPin = 4, newData = 5, validRx = 6;
void setup()
  pinMode(rxPin, INPUT);//set recieve as an input
  pinMode(txPin, OUTPUT);//set transmit as an output
  pinMode(stopPin, OUTPUT);
  pinMode(newData, OUTPUT);
  pinMode(validRx, INPUT);
  touchscreen.begin(9600);
int points = 0;
bool stop = false;
void loop()
   int x = 0, y = 0;
   boolean recieved = digitalRead(validRx);
   boolean changePoint = touchscreen.available() >= 2
               && (recieved || points == 0)
               && !stop;
   if(stop){
     digitalWrite(newData, LOW);
     digitalWrite(stopPin, HIGH);
   if(recieved){
       delay(100);
   if(changePoint)
     x = touchscreen.read();
     y = touchscreen.read();
     if(touchscreen.available() == 1 && touchscreen.read() == 's')
           stop = true;
     points++;
     if(points >= 50)
          stop = true;
     writePot(ch1, pot1, x * 2);
     writePot(ch1, pot2, y * 2); //
     writePot(ch2, pot1, points * 5); // point num
     digitalWrite(newData, HIGH);
  #33   Spotlight this post!
Unread 05-08-2009, 20:50
biojae's Avatar
digi pots on breadboard, just waiting to be soldered
  #34   Spotlight this post!
Unread 12-08-2009, 01:32
biojae's Avatar
now all thats missing is the screen and prototyping shield
The Pwm wires plug into the drivers station, which go to a db9 connector. the db9 is used so that the drivers dont have to unplug the PWMs to take it out of the box for strategy planning. because i would imagine that the pwms could get plugged in incorrectly and fry the screen
  #35   Spotlight this post!
Unread 12-08-2009, 18:45
biojae's Avatar
The Pwm cords go to the driverstation, the serial port to the screen
(and i just noticed how far away from USB I've gotten, the title is definatly incorrect)
The parts are definatly shipped
Driver Station S.O.S. M. Gildner Electrical 15 28-11-2009 19:35
Driver Station dnrobotics11 Control System 2 18-02-2009 21:35
driver station does not recognize usb 3 or 4... aksharma Technical Discussion 0 07-02-2009 12:57
Driver station only regognizes USB 1 and 2 cvxdes Programming 14 05-02-2009 14:40
