Go to Post Ultrasonic sensors will allow you to do fundamentally the same thing that the bump sensors do...so you can slow down and smoothly stop your robot just before it reaches the end wall, instead of running into it at full speed and then figuring out "ohh! there is a wall there!" - dlavery [more]
Unread 03-08-2009, 17:54
corps corps is offline
FRC #1158
corps is an unknown quantity at this point
driver station
We are having an issue with our driver station. We have had the station in storage and got everything out and hooked it up. Turned it on and first had the words Quick byte come up then the screen went blank with a curser in the upper left corner. It never goes any further then a flashing curser.
Can anyone help?
Unread 03-08-2009, 18:01
ATannahill ATannahill is offline
AKA: Alex Tannahill
Re: driver station
I am going to first ask some questions. How long do you wait for it? Have you tried reloading firmware (not sure if you could in that condition.)? What conditions is it stored in?
- Arizona North
Unread 04-08-2009, 09:41
Re: driver station
That does sound like you need to reload the Driver Station firmware.
The logo displayed means the bootloader is working, but the blank cursor means it doesn't have anything to load.
That happens occasionally and it's fixable, but you need a $22 special connector.
Follow the reimaging instructions.
You can check with other local teams to see if any already have one you can borrow.
Unread 06-08-2009, 17:31
biojae's Avatar
biojae biojae is offline
Likes Omni drives :)
AKA: Justin Stocking
FTC #5011 (BOT SQUAD) && FTC#72(Garage bots)&& FRC#0399 (Eagle Robotics)
biojae is a jewel in the roughbiojae is a jewel in the roughbiojae is a jewel in the rough
Re: driver station
Just note that the reflashing process takes just under an hour (ours took 47 min 39 sec) and that it cannot be interrupted once started. (or you will be in a worse place then where you started)
FTC Team 72 - No site
FRC Team 399 - http://www.team399.org
2010 Rockwell Collins Innovation in Control Award - (Use of the CAN bus, among other reasons) Phoenix, Arizona!
Unread 06-08-2009, 18:36
Re: driver station
Here's what I used: http://forums.usfirst.org/showpost.p...92&postcount=6
Unread 06-08-2009, 20:44
biojae's Avatar
Re: driver station
so do we have a complete pinout of the competition port?
Driver Station S.O.S. M. Gildner Electrical 15 28-11-2009 19:35
Driver Station Usb biojae FRC Control System 34 12-08-2009 18:45
Driver Station dnrobotics11 Control System 2 18-02-2009 21:35
Driver Station Help.. 1708xMr.Roboto FRC Control System 8 22-12-2008 15:24
Driver Station Setup?? Team 1708 Dave Programming 9 19-12-2008 23:09
