Re: Help saving current code
no, you dont have to install labview to get them off, the vis are just on the crio in one of the folders (not sure as i dont have access to crio right now)
the ftp ip is almost the same as the one you enter into your computer, 10.team.num.2 i am not sure how labview puts the program onto the robot, so installing labview may be necessary to put the program back on the CRIO |
| Help||Saving data to Flash memory & Encoder | Nimrod Beker | Programming | 5 | 11-02-2009 09:27 |
| LABVIEW CODES NOT SAVING!!!!!!! PLEASE HELP!!!!!!!!!!!! | GrammarNazi | Programming | 3 | 06-02-2009 14:26 |
| problems saving code | GrammarNazi | Programming | 1 | 06-02-2009 09:58 |
| Current Clamping Code and Hardware | Bochek | Electrical | 6 | 14-01-2008 07:48 |
| Navigate.c Current Sense code=only one polarity | Dale(294engr] | General Forum | 1 | 05-02-2004 16:25 |
