Go to Post "Don't you wish your drill bit was hot like mine?" - BariSaxGuy [more]
  #35   Spotlight this post!
Unread 13-08-2009, 00:10
biojae's Avatar
biojae biojae is offline
Likes Omni drives :)
AKA: Justin Stocking
FTC #5011 (BOT SQUAD) && FTC#72(Garage bots)&& FRC#0399 (Eagle Robotics)
biojae is a jewel in the roughbiojae is a jewel in the roughbiojae is a jewel in the rough
Re: The Only Constant is Change
Originally Posted by EricVanWyk View Post
Even if it is a touch screen class mate, your work is not at all wasted. You learned a lot, and your skills will definitely be relevant. Document it well and put it on your resume. Post on CD when it gets you a cool job!
the touchscreen actually is the easy part. the other 80% is getting the robot to follow the path correctly
and that involves physics! and math!
FTC Team 72 - No site
FRC Team 399 - http://www.team399.org
2010 Rockwell Collins Innovation in Control Award - (Use of the CAN bus, among other reasons) Phoenix, Arizona!
pic: The Constant March of Progress Eric K Extra Discussion 6 17-02-2009 13:48
Getting constant motor power with IR board Nightfall831 Programming 16 15-01-2008 11:20
The speed of light is NOT a constant?! A milestone in Physics? KenWittlief Math and Science 37 23-08-2006 00:49
Constant Force Springs - Data Sheets? Ben Piecuch Kit & Additional Hardware 1 06-05-2004 19:00
Getting the relays to stay constant Lord Nerdlinger Programming 2 19-02-2004 10:17
